RE: Curare from Scratch
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> Classic Pattern Flying >> RE: Curare from Scratch
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: Curare from Scratch - 10/4/2007 2:34:47 PM
ppljr
Status: offline
quote:
ORIGINAL: Bashedit
Man this is a great thread to run across! I just purchased an old MK kit for the Curaure after looking for one for at least ten years! I can't wait to receive it and get started on it. Probably will just duplicate the kit and keep the original. So who has the short kits and what retracts are best used in this airplane? Any and all information is appreciated.
Ed
Don't worry about duplicating the parts...I threw in one of my CD that has all that done for you...enjoy.
Pedro
(in reply to Bashedit)
       Post #: 26
RE: Curare from Scratch - 10/4/2007 4:40:22 PM
nxtdoor
Status: offline
Yea, I know the nose gear coil is backwards. Did it on purpose to clear the retract housing. If your turn it around, it won't retract fully.
I fly off a paved surface, so it will not be an issue. Done it before.
If I had an MK kit I would build it. Why own it if you don't? Make patterns for everything first.
I have no idea what series the Spring Airs are. Bought on ebay cheap and they were brand new and fit. They seem to be a good match to Rhom Airs size wise.
I did the wing fillets (what a pain in the @$$) last weekend. Pretty close to glassing now. Plan to use polyester like the old days. It sands so easy compared to epoxy.
Jeff
(in reply to ppljr)
       Post #: 27
RE: Curare from Scratch - 10/5/2007 3:43:57 AM
Ed_Hartley
Status: offline
Hi All,
Here is a picture of my Curare which was made ready to cover by Steve Byrum. It has an OS-91 and weighs 6 lb 11oz ready to fly. The wing is the standard Curare wing and it has more than enough power. I use it for Senior Pattern competition to try and beat Bruce Underwood. Nice Plane!
The one with the long AMA number is Steve Byrums. This one is a bit closer to 7 lbs. Both fly quite well.
Ed Hartley
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Ed_Hartley -- 10/5/2007 4:02:17 AM >
_____________________________
Ed Hartley
(in reply to nxtdoor)
       Post #: 28
RE: Curare from Scratch - 10/5/2007 5:06:37 PM
stg61abc
Status: offline
wow, great plane and very pro construction!!!!!
Please post more pics often....
       Post #: 29
RE: Curare from Scratch - 10/5/2007 8:21:48 PM
Bashedit
Status: offline
Ed H,
Are those fiberglassed or just monokote covered? They look great!
Ed J
(in reply to stg61abc)
       Post #: 30
RE: Curare from Scratch - 10/6/2007 3:20:15 AM
Ed_Hartley
Status: offline
Both are Monocote, Is there any other way! <GRIN>. I like wooden airplanes and Monocote is so much easier than silkspan and talcom powder and/or fiverglass. It also makes it so easy to repair when you have a accident.
Ed H
Ed Hartley
       Post #: 31
RE: Curare from Scratch - 5/22/2008 1:49:03 AM
nxtdoor
Status: offline
Well, it's been one year now to get to this point... primer. Ready for paint finally. Things always seem to get in the way and being OCD about my building doesn't help.
Here are some pics of the plane prior to final color application.
Plan to work on laying out the scheme on the plane this weekend. Will be too windy to fly likely this weekend.
Jeff
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Ed_Hartley)
       Post #: 32
RE: Curare from Scratch - 5/22/2008 2:34:33 AM
Atlanta 60
Status: offline
Looking Great!!
"A Superior Pilot uses his Superior Judgment to avoid using his Superior Skills." - astronaut Frank Borman
       Post #: 33
RE: Curare from Scratch - 5/22/2008 3:39:44 AM
rainedave
Status: online
Looking great Jeff! There's lots of inspiration at casniffer's image database.
Beautiful plane, Ed. That is amazingly light for a design that usually weighs over 7lbs. Where does Steve cut the weight? Of course, no retracts account for around a pound, I guess.
David
< Message edited by rainedave -- 5/22/2008 3:40:20 AM >
(in reply to Atlanta 60)
       Post #: 34
RE: Curare from Scratch - 5/22/2008 5:59:54 AM
pimmnz
Status: online
If you keep the foam and 'glass well away from the airframe the retract equipped ones come out about 6lb 12oz without really trying.
Evan.
(in reply to rainedave)
       Post #: 35
RE: Curare from Scratch - 6/14/2008 7:34:15 PM
nxtdoor
Status: offline
Hey, there Jeff, your plane looks just like the one I used to fly. Good to see you are using the air brake on the wing. It works. If you need help wirh a paint design, just let the old man know. Dad
       Post #: 36
RE: Curare from Scratch - 6/17/2008 1:08:08 AM
nxtdoor
Status: offline
White base coat on. I forgot how much I hate painting! Argh! What a PITA.
Here is my proposed paint scheme. White, Red, Blue and Silver.
Now all I need is some 1/8" fine line tape.
I ran my Jett Fire 90 yesterday; HOLYSHIZEL! 16,000 rpm blubbering rich on an 11-7 break in prop. I am thinking at this rate the 11-9 will turn 15,000 easy in the air. Should be fast to say the least.
Maybe do some color application this weekend.
Jeff
       Post #: 37
RE: Curare from Scratch - 6/17/2008 1:11:38 AM
nxtdoor
Status: offline
Pics didn't upload.
Lets try again.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 38
RE: Curare from Scratch - 6/17/2008 2:38:46 AM
dhal22
Status: offline
nice scheme there! can i borrow that scheme? i have a couple of planes almost ready for painting practice. it looks better than i'm considering.
thx, david
       Post #: 39
RE: Curare from Scratch - 6/17/2008 3:33:09 AM
Atlanta 60
Status: offline
That's Awesome Dude...
What paint are you using?? What primer did you use also?? You glassed both the fuse & wings?? If so was it with .5oz cloth & epoxy resin??
Sorry for all the questions...
Chuck
