RE: Where to Run Nitro Boats in or near StLouis Metro Area?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - RC Nitro Boats >> RE: Where to Run Nitro Boats in or near StLouis Metro Area?
Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: Where to Run Nitro Boats in or near StLouis Metro... - 11/21/2008 6:10 PM
rageman
Score: 100
Last Login: 8/20/2010
Status: offline
quote:
ORIGINAL: bassfish
MISSISSPPI RIVER ? >>>-> Bassfish
Sure if you are ok with the current thing. A back water could work if you can fine one with suitable shore line access. Good luck and let us know what you find.
Hide Signatures
(in reply to bassfish)
       Post #: 51
RE: Where to Run Nitro Boats in or near StLouis Metro... - 3/13/2009 11:46 PM
rageman
Score: 100
Status: offline
quote:
ORIGINAL: rageman
I met with the StL County Park Supervisors responsible for the Unger Park facility. They clearly want to make Unger Park Lake suitable for RC Boat running. Based upon input from a number of RC Universe menbers as to what is needed in that regard (thank you all very much for the guidance) the following was agreed upon.
The brush along the Eastern two thirds of the southern shoreline of the lake along the gently sloping grassy field will be removed. The grass in this area will be kept cut low as well as a path from the road to this shoreline at the shortest distance between the two. A special parking area will be added along side of the road at this point sufficient for a few vehicles to start with and posted with "Parking For RC Boaters Only" signage. See the following ariel maps for reference:
http://www.google.com/maps?f=q&hl=en&geocode=&q=63088&ie=UTF8&ll=38.554387,-90.442216&spn=0.00362,0.00788&t=h&z=18
http://www.flashearth.com/?lat=38.554381&lon=-90.441369&z=18.6&r=0&src=msl
These improvements will be accomplished over the winter and are to be completed by spring 2009. This timing is do to the fact that the brush to be removed is still partially submerged by the lake's continuing high water level making removal more difficult and the fact that current demand for the improvements is limited to...........me..........and my boat will not be ready to run until spring at the earliest.
The Parks Department appears ready to provide the facilities appropriate for the demand. Right now it would appear that demand will be a few locals wanting to play with their boats so the proposed improvements are scaled to that demand. Should demand increase significantly the Parks Department indicated that they would respond and make the improvements to the grounds needed to support that as well. A clear example of this is nearby Buder Park which has a first class airfield facility for model airplanes and which gets a lot of use/demand daily.
Comments, suggestions, etc. please advise.
TBC
Update.
Unger Lake never receeded enough over the winter to allow cutting the eastern shore line brush so this is still to be accomplished. Hopefully before the spring flood.
The Parks Department put in a Disc (Frisbe) Golf course at the park and a portion is near Unger Lake. The Parks department were concerned that the intended special parking area for RC boaters would attract disc golfer vehicles as well and there would be problems. So plan for dedicated parking spots and signage for RC boaters has been cancelled. What they intend to do is to send notification to the Park Rangers that even though general parking along the road side is not allowed in the park that if there is/are RC boaters at the lake, to allow the parking of their vehicles along side of the road on the shoulder. TBC.
Hide Signatures
(in reply to rageman)
       Post #: 52
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 5/17/2009 9:12 PM
FastBoater
Score: 100
Last Login: 3/11/2013
Status: offline
Any update on the unger lake project?
< Message edited by FastBoater -- 5/17/2009 9:13 PM >
Hide Signatures
       Post #: 53
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 5/17/2009 9:46 PM
rageman
Score: 100
Status: offline
I checked the lake a few weeks ago.  The shore line was well cut at the designated area as well as to and from the road.  How ever the lake is still up into the shoreline brush so that has not yet been cleared, the main improvement needed.  They Stl County Parks Maintenance people made it clear that until the lake goes down so that they can brushhog the brush that will not be done.  There are lots of gaps in this shoreline brush that someone with a good disabled boat recovery capability good handle.  I am not one of those.  Beyond this rim of scattered shore line brush the lake is wide open.  Hope for a hot dry summer.  At least no new flooding this spring.  I will check periodically and post.  If you want the number of my Stl County Parks Maintenance contact let me know and I will PM you.
Hide Signatures
(in reply to FastBoater)
       Post #: 54
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 5/17/2009 11:01 PM
ozvena
Score: 100
Last Login: 8/27/2011
Status: offline
Thanks for the update! There is a flood warning as we speak. It will take some time to dry.
Are there any electric enthusiasts in the area?
_____________________________
http://groups.google.com/group/missouriRCboats/
Hide Signatures
       Post #: 55
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 5/26/2009 4:15 AM
FastBoater
Score: 100
Status: offline
Great! Thanks for the update. To retrieve dead boats, you can use a RTR Electric Sport boat and a fishing reel. Works Great!!  I was able to run a .21 outrigger at unger lake last year without a retrieve Boat. I hope everything works out for unger lake, I need a lake so I can test models and have fun with new model boat friends.   Keep the updates coming, have a great summer
Hide Signatures
(in reply to ozvena)
       Post #: 56
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 5/28/2009 8:42 PM
phil6019
Score: 100
Last Login: 5/21/2013
Status: offline
I'm close to the park and wondered if anyone has tried to run their boats in the lake yet ??  I might try and go down there this weekend, weather permiting.   Phil
Hide Signatures
       Post #: 57
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 5/29/2009 5:45 AM
ozvena
Score: 100
Status: offline
Do you have electric or nitro?
I went there but did not want take a chance with only one boat. Retrieving would be impossible for me. I go to small lakes around instead. I can do that with a quiet electric. I am booked Saturday but may find some time on Sunday.
< Message edited by ozvena -- 5/29/2009 5:46 AM >
Hide Signatures
(in reply to phil6019)
       Post #: 58
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 5/30/2009 8:58 PM
rageman
Score: 100
Status: offline
With all the recent rain the lake may have been flooded again by the Meramec river.  Thay would be good and bad news.  The good news is that the shoreline brush may now be mostly submerged.  The bad news is that depending on flood level access to the lake itself may be a problem.  If you go please post what you see?
Hide Signatures
       Post #: 59
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 8/6/2009 1:51 AM
FastBoater
Score: 100
Status: offline
Any updates on the pond?
Hide Signatures
       Post #: 60
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 8/6/2009 2:10 AM
phil6019
Score: 100
Status: offline
I went there about a month ago and the grass was cut back and I was able to walk down to the lake and run several of my boats. Lots of sticks and junk floating in the water.
Hide Signatures
       Post #: 61
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 8/6/2009 3:27 AM
rageman
Score: 100
Status: offline
quote:
ORIGINAL: phil6019
With all the rain this summer the lake level has probably been rising so that will generate the floating debris. The earlier high levels of the ajacent Meramec river may well have flooded Unger lake as well. This is two very wet spring and summers in a row.
Hide Signatures
       Post #: 62
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 1/4/2010 9:03 AM
FastBoater
Score: 100
Status: offline
Looks like Unger Lake is DEAD in the water for R/C Boats.
Hide Signatures
       Post #: 63
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 1/4/2010 9:07 AM
ozvena
Score: 100
Status: offline
Is it the lake or the hobby in St. Louis? It feels like both...
Hide Signatures
       Post #: 64
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 1/4/2010 4:54 PM
phil6019
Score: 100
Status: offline
It's the lake, there are much better places to run in the STL area. Frank Holten State Park right across the river in Illinois. Huge lake great parking and restrooms. I live right by unger park and I would rather drive 15 min to Holten. There is another lake in Valley park that is ok if you only want run FE. Simson Park ( I think ) very nice location. I went to unger a few times with several other members and we just didn't get to excited about the location, bad parking, lots of debris in the water, ect. Right now we need the ice to go away. If you ever want to go when the weather gets nicer give me a call. 314-258-5436 Phil
Hide Signatures
       Post #: 65
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 1/4/2010 6:04 PM
ozvena
Score: 100
Status: offline
Phil, are you into FE or nitro? If the earlier than I definitely will call you when it warms up...
Hide Signatures
       Post #: 66
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 1/4/2010 8:09 PM
rageman
Score: 100
Status: offline
Phil, Are you a member of the Saint Louis Thunder Boaters? I believe that they use Frank Holten State Park.
Hide Signatures
       Post #: 67
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 1/4/2010 9:20 PM
phil6019
Score: 100
Status: offline
ozvena, I have several of all types of the boats. FE, Gas, and Nitro.
Rageman, I have been running at Holten for several years with the Thundrboaters. There is a great bunch of guys that go to Holten on the weekends. We need some warm weather 40-50 and we will get back out there.
Have a good New Year, Phil
Hide Signatures
       Post #: 68
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 1/4/2010 9:47 PM
ozvena
Score: 100
Status: offline
Where do you guys go to buy/sell local used RC stuff?
Hide Signatures
       Post #: 69
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 1/7/2010 7:09 PM
rageman
Score: 100
Status: offline
Phil,
I am a complete newbe and yet to even get the boat wet. I have been looking for someplace close and less busy to do the hours of motor breakin and various learning curve work and not be under foot of the more seasoned boaters. That is why Unger Park lake is appealing to me versus Holden.
Hide Signatures
       Post #: 70
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 1/7/2010 7:49 PM
phil6019
Score: 100
Status: offline
What type of boat are you going to run ?? I was new several years ago and I think the value of being around seasoned rc boaters was priceless for me it helped me learn the hobbie and kept me from making a lot of rookie mistakes. Most of the people I know are very willing to help out the newer boaters. Call me anytime if you have any ? 314-258-5436. Phil
Hide Signatures
       Post #: 71
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 1/7/2010 8:05 PM
rageman
Score: 100
Status: offline
Well that is encourging to hear about the Thunderboaters. I have heard horror stories about some local RC plane people
from my neighbor that caused him to quit the sport in disgust before he really even got started.
Mine is a Thundercat 31. Except for needing a couple of balloons to waterproof the electrics I think it is ready to go. Thanks for your number. Bill
Hide Signatures
       Post #: 72
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 1/7/2010 8:33 PM
phil6019
Score: 100
Status: offline
The first thing I would do to your boat is to make sure it has plenty of flotation ( pool noodles work great ). I have seen a few boats crash and sink because the factory does not always use enough. Its a cheep upgrade. When you run the boats they ARE going to blow over, rollover, crash and die out in the middle of the lake. Its good to plan and be ready for it to happen. Its also good to have a cheep electric retrevial boat. I use a Shockwave 26 and can hook a fishing line to the rear of the boat and run the small boat out and drive it around the dead boat and then crank them both back in with the real. Just a few ideas for you. Phil
Hide Signatures
       Post #: 73
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 1/7/2010 11:53 PM
rageman
Score: 100
Status: offline
OK, thanks. Will do. Bill
Hide Signatures
       Post #: 74
RE: Where to Run Nitro Boats in or near StLouis Metro A... - 2/22/2010 2:23 AM
dirt1car
Score: 100
Status: offline
rageman, if your still looking for a place to run boats here is a thought. the old lakehill race track fills with water and maybe you can look into runing the boats in the infield . it was under water for the last 20 years  and was pumped out  a couple of  years ago for a reunion . it might  be worth looking up the owner  and inquiring about it.
Hide Signatures
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.234RCU1
