reyn3545
Joined: 7/1/2006 From: Alpharetta, GA, USA Status: offline
I'm a big fan of the QB series planes... for a plane that goes together over a weekend, they've always flown as well as any wood ARF at the field. With that said... you made me a little nervous reading about your elevator/rudder alignment. So, I went down to the basement, dug it out of the box, stuck the stab and tail surfaces on, mounted the lower wing, and started measuring. After maybe 30 seconds of alignment, it seems just fine. When the wingtip to stab measurements are equal, the elevators are positioned with equal spacing to the rudder. The rudder-to-stab measurement is equal on both sides. I should be able to glue this up without any sanding. Looks like mine will work out fine. The rudder/elevator hinges (all thousand of them) seem to be in proper alignment also, the surfaces hinge to full deflection without any bind. From just a visual perspective, the stab seems perfectly parallel to the lower wing. I guess time will tell how broad any alignment problems are, but if yours is that far out of whack, you should give AW a call to discuss. With biplanes, I'm always more concerned about the differences in incidence between the upper and lower wings. I'm not going to build this plane for a while, so I won't know if there is any, but with the way they set up the angle brackets, any minor twists should be easy to manage with washers or spacers. Mark - if you're reading these... are the wing incidences supposed to be identical on the top and bottom wings? Sometimes there is a little "up" built into the upper wing. I'd hate to adjust that out if its supposed to be there.
< Message edited by reyn3545 -- 12/25/2007 6:27:53 PM >
