reyn3545
Joined: 7/1/2006 From: Alpharetta, GA, USA Status: offline
I'm using a Sullivan pump (4 ounces) a Troy-Built 3-cell lipo battery (another 4 ounces) and I guess the tank, lines, etc.. might weigh another 4 (probably not that much). So, this explaines most of 1 pound. I am running dual batteries and regulators to the receiver (another 5 ounces). I think with 7 digital servos (5985) and 2 analogs, I certainly don't want to find out the hard way that I needed a little more power through the receiver. Also, instead of a choke rod through the cowl, I'm running a servo on the choke, so there's a couple of ounces there. All in all, I guess there's a pound I could shave off if easily, if I need to. I'll try another prop first. I think the smoke thing is a temporary "want".. I'll probably remove it once I get tired of cleaning it off! I set the plane up so that I can take the smoke pump and batteries out pretty quickly, and since the pump is up front and the battery is back, it should have limited effect on balance. If props don't fix the problem, and I get tired of smoke, go to a manual choke, and its STILL too heavy, I guess I could start looking at titanium links, lighter wheels, tailwheel assembly, etc.. but I hate to start throwing dollars at fractions of ounces! I think the 18 pound range is about as good as this plane is going to get. That's not really bad for a 50cc biplane, its not supposed to be a hovering machine. Well, I got the fuel and smoke dots installed today, that's everything except the pull-pull turnbuckles for the rudder, the new wheels and wheelpants. Those should all be in by the time I get back home next weekend. I took it out in the backyard this afternoon to start it and check the smoke system. Thank God for tie-downs... yep, I forgot to check and reverse the throttle servo! Also, the Sullivan smoke pump was running backwards. No problem, I just swapped the tubes on the pump. Everything seems fine, so now its just a waiting game until I'm at home for a weekend and the weather is nice.
< Message edited by reyn3545 -- 1/1/2008 11:21:35 PM >
