servo's
Tower Hobbies
Logged in as Guest
  Printable Version
25%Yak54 with SPE26 COMBO - ARF
Seller:  peakmodel
Details:   $499.00   |  10/9/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> IMAC >> servo's
Page: [1]
Login
servo's - 4/11/2007 5:23:56 PM
zx32tt
Status: offline
I'm starting to gather all the bits & pieces for a 35% Jtec Panzl. Servo's will be a big portion of the overall expense for this plane.
Are 5955's overkill for all surfaces? I'm more concerned about gear wear /slop than actual torque. What are you guys using?
Z
< Message edited by zx32tt -- 4/11/2007 5:24:37 PM >
       Post #: 1
RE: servo's - 4/19/2007 2:15:32 AM
Jake Ruddy
Status: offline
Personally I could see 5985s in the wings since there are going to be 4.. but it's not really going to save you much so it's a tough call.
Def 5955 on rudder.. could also do 85s on El. but really in the long run you will prob save some money in gears so may com close to breaking even.
I dont really see something like this as overkill... its the guys who put this type of servo on a 74" or 78" plane that I consider overkill
(in reply to zx32tt)
       Post #: 2
RE: servo's - 4/19/2007 12:09:15 PM
zx32tt
Status: offline
Yes, the 5985's and the 5955 for the rudder was exactly what I was looking at. But, at $26.29 a set for gears, (5985) you wonder if its really worth it. After the 1st season, the 5955's would be a bargain. I just wish there was an alternative.
Z
< Message edited by zx32tt -- 4/19/2007 12:25:20 PM >
(in reply to Jake Ruddy)
       Post #: 3
RE: servo's - 4/19/2007 7:24:15 PM
tony/amps
Status: offline
9153 futaba two years use and still going strong with out any slop and 9152 on my elevators either one holds up real well.
Tony Fandino
_____________________________
2005 IMAC Sportsman National Champion
2005 Bennett Cup winner
       Post #: 4
RE: servo's - 4/19/2007 10:44:17 PM
thewrap
Status: offline
There is always Jr. They have great servos. They do run a little expensive but they work great. And I think if you wanted you could use a Seiko servo for the rudder. If you using pull pull.
(in reply to tony/amps)
       Post #: 5
RE: servo's - 4/20/2007 12:15:39 PM
zx32tt
Status: offline
I would like to stay with Hi-Tec, at least on the ailerons, for the programability. I have the have the Hi-Tec programer and can use it to match the servo's. Servo's are a big investment for me, & I want to do it only once. Thanks for all the feed-back
Z
(in reply to thewrap)
       Post #: 6
RE: servo's - 4/21/2007 8:07:08 PM
aegis
Status: offline
I'm using 5955's all around on a 33% Extra; 2 on each aileron, 1 on each elevator, and 1 on the rudder. I have more torque than what's required on the elevators and definitely more than required on the ailerons. I never used Hitecs before but thought I would give the 5955's a try. I bought them not because the plane required the torque (on the ailerons especially) but because I had heard good things about the tight geartrain and lack of wear with the TI gears. I definitely have crisp control surface response. When looking at the initial cost of going with 5955's everywhere versus a combination of 5985's and 5955's, there wasn't that much difference.
Dan
       Post #: 7
RE: servo's - 4/21/2007 10:47:50 PM
zx32tt
Status: offline
That's exactly what I was thinking. The lack of gear wear, and the ability to program/match throws for the ailerons are big factors for me, Aegis. What type of power supply are you using for all those digitals?
Z
(in reply to aegis)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.484RCU1
