rudder setup on 86" yak
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Quique's Aircraft Support >> rudder setup on 86" yak
Page: [1]
Login
rudder setup on 86" yak - 4/12/2007 1:01:51 AM
Zman39
Status: offline
Hey all,
Well my 27% yak showed today along with the Da50 and other stuff. I have done pull pull rudder setups in the past and found them somewhat a pain with weather and other stuff causing the tension to change sometimes. I was wondering if anyone has instead just mounted a servo near rear and used a pushrod for rudder?
Thanks for any help
Mike
       Post #: 1
RE: rudder setup on 86" yak - 4/12/2007 1:09:55 PM
SJS
Status: offline
If you mount a servo in the rear, you will change the c/g of the plane. MY 86" came out a little tail heavy, so you would have to add weight to the nose. What I do is pre-tension the wire before installing it. Put one end in a vise and pull on the wire, stretching it out. This way, when you install the wire, it dosen't stretch.
SJS
(in reply to Zman39)
       Post #: 2
RE: rudder setup on 86" yak - 4/12/2007 4:47:33 PM
Rezagh
Status: online
Hello Mike,
Mounting the servo in the tail of our Yak is not a good idea for two reasons: 1. you need to do an extensive modification 2. you can have major problem balancing it.
Pull-Pull cables do stretch after first 5-10 flights but when you re-tighten them, it will take a while before they stretch again.
Thank you,
Reza
_____________________________
Quique's Aircraft Company
(in reply to SJS)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU1
