sfsjkid
CA, USA Status: offline
Hey ChuckA, that is a good idea. Sounds like sage advice resulting from your many years in RC and not having model memory in the Proline era. I might try implementing in some of my models. I say some because approximately half of my stable is set up with dual aileron, elevator servos for 3D, a couple are wing setups, one heli, and even a car (for use with the proper ground module of course). In this particular crash, while having the ailerons going the right way would have given me half a chance, the throws were such that I didn't have enough stick to counter the trims for the other model (3D w/dual aileron). The other crash I mentioned I was using a Zagi mix on a conventional model. Again, fortunately there were no moments endangering anyone, nor is any sympathy trying to be generated. I've been in the hobby long enough to modify Tom's Cruise's line from Days of Thunder, ie "Crashins' Flying". Someone mentioned feeling bad about not recommending Spektrum to the newbies. Yes, Model Match would have saved me too, but a secondary feature IMHO given my numbers. Also, in all of those flights I mentioned, I've "only" been hit once, and 72mHz has been rock solid for me. There seems to be a QC issue at the very least, and at our field has a car track and sandwiched between office buildings, so it will be interesting how things will turn out in the long run. Also having a JR box means some problems finding a suitable buddy box at our field. This is the long winded version of saying, the resposible thing to do is not to recommend a specific system, but info the newbie about the various merits of different systems. I've always done this even before SS. Now, this has gone way off topic, apologies. As you may have gathered, I'm a cautious adopter of new tech, I didn't use lipos until they "caught up" with safety technologies in other industries, for example. I'm excited about not having to worry about frequency control, but need to prove to myself it is reliable. However, I am enjoying all of these new products that are being introduced. So any word on Hitec? (ohhps, off topic again )
