bajajrider
CA, USA Status: offline
weight is not as advertised, unless you go with light servo's, small engine, dont worry, havent weighed mine but id say its around 4lbs with standard gear, likestofly's is about the same. the plane flys great,plenty of powa with a tt.46/os.46 w/tower pipes. opened up #2 for my dad last night, same great quality as #1 was, just a few wrinkles on 'rons' and top of fuse, nothing to worry about, no warps to be found. should only take a few nights to assemble, got the wing and horiz on last night, using locktite 'sumo' poly glue for wing and horiz, dries faster and less foaming than gorilla glue or elmers poly, dries translucent white, awesome stuff. 'tested' the glue on my ef 74'' yak, hinged all surfaces (hinge points) with the 'sumo' glue, i've put it through every thing i can think of and no failures yet
