RE: Lanier Radical 330 ARF
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> RE: Lanier Radical 330 ARF Page: <<   < prev  1 [2] 3 4 5 6   next >   >>
Login
RE: Lanier Radical 330 ARF - 1/16/2008 1:32:32 AM
nort
Status: offline
mine is comming today
dad's should be here by friday
(in reply to PropSpinner)
       Post #: 26
RE: Lanier Radical 330 ARF - 1/16/2008 6:42:39 AM
likestofly
Status: offline
Got mine today, howeverI`m still flying Radical#2, #1 kind of fell out of the sky when in a hover..,after the engine stopped..,because I ignored my flight timer..,I was having too much fun !Thanks for having my back, Nort, Guys, this plane is a winner ! don`t pass it by..,
By the way..,Last Sunday Nort was flying his Fusion and did a wall I believe,& the horizonal stab broke in two & fluttered to the ground as Nort landed.., it was spectaular !!!
(in reply to nort)
       Post #: 27
RE: Lanier Radical 330 ARF - 1/16/2008 10:35:17 AM
PropSpinner
Status: offline
Mine should be here today. Have you guys made any modifications? I think I'll change the landing gear, pushrods and mount the power switch on top of the wing. I'm trying to come up with a better way to run servo wires from the tail.
_____________________________
Licking County Radio Control Club*EF Yak
H9 Twist,Tiger II,GWS Tiger Moth,Senior Telemaster&Goldberg Extreme 330
(in reply to likestofly)
       Post #: 28
RE: Lanier Radical 330 ARF - 1/16/2008 2:18:51 PM
morgantwin11
Status: offline
Does anyone have any flight videos of the radical 330? Im thinking of getting one but I'd like to see one fly.
       Post #: 29
RE: Lanier Radical 330 ARF - 1/17/2008 1:27:27 AM
ekir
Status: offline
I am thinking about ordering the Radical 330. Once you receive the Radical, post a note on how the quality looks.
Will the weight of this profile be as advertised? I sure hope so.
(in reply to morgantwin11)
       Post #: 30
RE: Lanier Radical 330 ARF - 1/17/2008 1:39:19 AM
bajajrider
Status: offline
weight is not as advertised, unless you go with light servo's, small engine, dont worry, havent weighed mine but id say its around 4lbs with standard gear, likestofly's is about the same. the plane flys great,plenty of powa with a tt.46/os.46 w/tower pipes. opened up #2 for my dad last night, same great quality as #1 was, just a few wrinkles on 'rons' and top of fuse, nothing to worry about, no warps to be found.
should only take a few nights to assemble, got the wing and horiz on last night, using locktite 'sumo' poly glue for wing and horiz, dries faster and less foaming than gorilla glue or elmers poly, dries translucent white, awesome stuff. 'tested' the glue on my ef 74'' yak, hinged all surfaces (hinge points) with the 'sumo' glue, i've put it through every thing i can think of and no failures yet
(in reply to ekir)
       Post #: 31
RE: Lanier Radical 330 ARF - 1/17/2008 8:30:45 PM
hutchi
Status: offline
recevied mine today open bx starting the build going with a 55AX turning 13.25, 375, ds821 on all should be done by saturday
(in reply to bajajrider)
       Post #: 32
RE: Lanier Radical 330 ARF - 1/18/2008 12:24:44 AM
PropSpinner
Status: offline
I received mine yesterday and it looks well built and true. Did you guys have to open up the hole in the fuse for the wing to get it to fit? Any suggestions on the best way to do that? What servo for the throttle?
< Message edited by PropSpinner -- 1/18/2008 12:31:47 AM >
(in reply to hutchi)
       Post #: 33
RE: Lanier Radical 330 ARF - 1/18/2008 12:54:31 AM
hutchi
Status: offline
wing fit a little snug but is in an glued stabilizer done moveing on, not sure on the throttle yet,
       Post #: 34
RE: Lanier Radical 330 ARF - 1/18/2008 3:04:46 AM
toro_0397
Status: offline
for the throttle servo you should use any mini sized servo. i used a hitec.
i will get a video probably this weekend.
any questions email me.
       Post #: 35
RE: Lanier Radical 330 ARF - 1/18/2008 8:17:35 AM
PropSpinner
Status: offline
quote:
ORIGINAL: toro_0397
What model Hitec?
(in reply to toro_0397)
       Post #: 36
RE: Lanier Radical 330 ARF - 1/18/2008 3:56:31 PM
theo63
Status: offline
i just got mine a few minutes ago and my first impression was wow this for 55 bucks after my discount,i am going with a older 46 fx that runs real good just because i have it on the shelf,i have some s 3191 futaba servos laying around ill throw in it should be okay,,anything else someone might suggest
steve
       Post #: 37
RE: Lanier Radical 330 ARF - 1/18/2008 5:07:20 PM
gregziemba
Status: offline
does the wing remove?
(in reply to nort)
       Post #: 38
RE: Lanier Radical 330 ARF - 1/18/2008 5:23:34 PM
theo63
Status: offline
greg no it does not remove glued in
steve
(in reply to gregziemba)
       Post #: 39
RE: Lanier Radical 330 ARF - 1/18/2008 6:02:53 PM
ekir
Status: offline
I just ordered the Radical 330. Thanks Prop Spinner for the code information to received $15.00 off. I belong to the Super Saver Club and it appears that you can get a better deal with the codes.
I plan to use some Hitec servos that I have laying around as well as an OS 46 SF. I ordered an APC 12.25 x 3.75 Prop. I think this is one of the props that is used with 3-D profile aircraft with the 46 engines.
Mine is being shipped from the Nevada Warehouse, so it will be some time before it arrives in Florida. I hope it makes it undamaged.
I almost ordered a MoJo 40 Kit, but felt this was to good of a deal to pass up. The Mojo might be better, but this will be a good starting place.
       Post #: 40
RE: Lanier Radical 330 ARF - 1/18/2008 6:21:03 PM
theo63
Status: offline
ekir mine was tri[ple boxed so you should not have a problem
steve
(in reply to ekir)
       Post #: 41
RE: Lanier Radical 330 ARF - 1/18/2008 9:00:45 PM
HitecMan
Status: offline
I ordered mine yesterday! I saw this post and had never even heard of this plane but i saw the plane and the price and had to buy it. Guys I need pictures asap ! I am excited!
I bought a motor without a plane for it. I bought a plane without a motor for it...What has this hobby done to me?
(in reply to theo63)
       Post #: 42
