RE: Lanier Radical 330 ARF
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> RE: Lanier Radical 330 ARF
Page: <<   < prev  1 2 [3] 4 5 6   next >   >>
Login
RE: Lanier Radical 330 ARF - 1/19/2008 4:51:13 PM
theo63
Status: offline
hey propspinner keep us posted on your progress i will not start mine untill tomm as soon as a clear some room on my other projects going on lol
_____________________________
steve
(in reply to theo63)
       Post #: 51
RE: Lanier Radical 330 ARF - 1/19/2008 5:55:13 PM
PropSpinner
Status: offline
Here are some pics of the Radical 330. I haven't accomplished much. I've cut away the center of the wing and masked one side for gluing. I think I will drill the holes for the engine before I glue the wing and the fuse together. That way I can use my drill press. I might drill servo screw holes to simplify construction. Maybe if I mount the conduit for the tail servos I can draw a line though the wing hole to get the curve right where the conduit meets the wing.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Licking County Radio Control Club*EF Yak
H9 Twist,Tiger II,GWS Tiger Moth,Senior Telemaster&Goldberg Extreme 330
       Post #: 52
RE: Lanier Radical 330 ARF - 1/19/2008 6:51:26 PM
hutchi
Status: online
well I'm about 95% done takes about 6 hrs to put togather nice arf for the money here some pic
Click for fullsize
Click for fullsize
(in reply to PropSpinner)
       Post #: 53
RE: Lanier Radical 330 ARF - 1/19/2008 7:54:05 PM
PropSpinner
Status: offline
Went ahead and mounted the Saito 82. Will remove it and mount the wing.
Great Job hutchi! Did you make any changes or modifications? I noticed the size of the engine bolts were wrong in the instruction book.
Click for fullsize
(in reply to hutchi)
       Post #: 54
RE: Lanier Radical 330 ARF - 1/19/2008 7:57:28 PM
decay
Status: offline
quote:
ORIGINAL: PropSpinner
Mount the engine last, then you can position it for correct CG.
You can still use a drill press , just let the nose on the rest and the
fuse & wing hang down while you drill. Thats what I do!
Posted too late!!
       Post #: 55
RE: Lanier Radical 330 ARF - 1/19/2008 8:35:09 PM
toro_0397
Status: offline
my radical os 55 ax
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by toro_0397 -- 1/19/2008 8:42:32 PM >
(in reply to decay)
       Post #: 56
RE: Lanier Radical 330 ARF - 1/19/2008 8:38:12 PM
PropSpinner
Status: offline
Thanks decay. I'm sure I'll still be nose heavy with that engine. I pushed it back as far as I could. I'll use your suggestion on my next plane. I plan to get EF Yak when they come in.
Here is how a friend of mine eliminated the square tube on a Extreme 300 which is the same plane. I added 4-40 push rods to the elevator and rudder.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to decay)
       Post #: 57
RE: Lanier Radical 330 ARF - 1/19/2008 10:50:45 PM
hutchi
Status: online
I did the same thing as your friend did just ran wires down the side did change bolts for mount but not that i notice they were with the engine was a 55 ax had in a harrier 46 will try an fly tomorrow if weather permits
       Post #: 58
RE: Lanier Radical 330 ARF - 1/19/2008 10:53:35 PM
hutchi
Status: online
Damm toro 0397 looks just like mine great job let's have some fun
(in reply to toro_0397)
       Post #: 59
RE: Lanier Radical 330 ARF - 1/19/2008 11:09:02 PM
toro_0397
Status: offline
i have mine about a month ago and is the best plane to fly, lots of fun.
nice inverted slow passes about two feet height.
have fun.
i will try to get a video tomorrow.
       Post #: 60
RE: Lanier Radical 330 ARF - 1/19/2008 11:50:07 PM
theo63
Status: offline
excellent guys looks like i got the pictures rolling in fantastic,now can we talk some set ups like what servos and what recievers did you use,any other mods
steve
       Post #: 61
RE: Lanier Radical 330 ARF - 1/20/2008 10:25:08 AM
PropSpinner
Status: offline
Toro, where is your Radical's CG?
I glued the wing in with gorilla glue.
< Message edited by PropSpinner -- 1/20/2008 11:41:19 PM >
       Post #: 62
RE: Lanier Radical 330 ARF - 1/21/2008 3:04:32 AM
toro_0397
Status: offline
sorry i dont really know where it is, i dont have the plane with me since i hung it from the roof of the place where i fly during the week. but i guess it is over the recomended cg range. today i shifted a little bit backwards the cg i added a few ounces. i will suggest to start with the recomended range.
       Post #: 63
RE: Lanier Radical 330 ARF - 1/21/2008 3:07:20 AM
toro_0397
Status: offline
theo63, in my radical i used all 3004 futabas for all surfaces and a mini hs 81 for throttle, also i used a tower hobbies reciver and a 1650 mah nickel metal battery. a mini is required for the throttle.
