RE: Lanier Radical 330 ARF
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> RE: Lanier Radical 330 ARF
Page: <<   < prev  1 2 3 [4] 5 6   next >   >>
Login
RE: Lanier Radical 330 ARF - 2/1/2008 12:35:15 PM
ekir
Status: offline
My Radical 330 arrived last night by UPS. I opened the box and was impressed with the 3-D Profile. Covering was excellent. Will start assembling today.
I have been flying an AirfoilZ Foamy Electric Yak. This was my first 3-D electric. I have enjoyed flying it as well. Looking forward to seeing how a glow powered 3-D is different to the electric.
I have one of the E.F. Chinn Yak on order. That being said, I probably will build a Mojo Kit sometime in the future. It seems that everyone that flies 3-D Profile Aircraft, have a MoJo!
I guess I have the 3-D Bug?
(in reply to plane-o-joe)
       Post #: 76
RE: Lanier Radical 330 ARF - 2/2/2008 1:39:23 AM
PropSpinner
Status: offline
ekir,
all good choices.
_____________________________
Licking County Radio Control Club*EF 74" Yak
H9 Twist,Goldberg 67" Edge,Senior Telemaster&Goldberg Extreme 33
(in reply to ekir)
       Post #: 77
RE: Lanier Radical 330 ARF - 2/5/2008 3:03:56 AM
bajajrider
Status: offline
MOJO Baybee!!!
mojo's are the BEST profile for learning on bar none.
get the kit,shake the box and out comes a mojo
its easily one of the easiest kit built planes i've touched
probro has a build for dummies thread if you need help.
oh yeah, still flying the radical, check your clevis' one split on me, made the rudder 'feel' weird in the air, lucky it didnt come off, maybe change them out to the dubro safety clevis or at least put some ca on em'
(in reply to PropSpinner)
       Post #: 78
RE: Lanier Radical 330 ARF - 2/5/2008 12:59:14 PM
plane-o-joe
Status: offline
Thanks for the heads up on the clevis! Just started my assembly and will probably replace most, if not all, hardware. I want a mojo so bad! New house with major clutter, Employer purchased by another company=more work, and barely enough time to assemble, much less to build=NO MOJO It sucks when you can't get your mojo on!
You can lead a horse to water, but if you get him to float on his back you have done something!
(in reply to bajajrider)
       Post #: 79
RE: Lanier Radical 330 ARF - 2/7/2008 4:41:18 AM
foresterxt
Status: offline
Well I just ordered one! I was wondering if I would be off my rocker to use a Tower .75. I don't have a .46 handy, but I've got the tower 75 all broke in and no where to go.
       Post #: 80
RE: Lanier Radical 330 ARF - 2/7/2008 10:30:37 PM
bajajrider
Status: offline
sure
mo-powa the betta.
prob. going to be overweight though
(in reply to foresterxt)
       Post #: 81
RE: Lanier Radical 330 ARF - 2/7/2008 11:20:18 PM
PropSpinner
Status: offline
quote:
ORIGINAL: bajajrider
MOJO Baybee!!!
I always replace the clevis' on my planes. I like the Dubro ones.
       Post #: 82
RE: Lanier Radical 330 ARF - 2/10/2008 1:23:17 AM
forktail devil
Status: offline
im about to order one and i would like suggestions on a prop. I will be using a magnum 70 4stroke. whats the best 3d prop for it?
       Post #: 83
RE: Lanier Radical 330 ARF - 2/10/2008 2:31:30 AM
plane-o-joe
Status: offline
You might try an APC 13x4W. I used this on a Magnum 70 that was mounted on an Accel Katana. It had a nice sweet spot for hovering that was slightly more than half throttle. I did try the APC 14x4W, but I found I didn't like the way it would spool up when pulling out. I'm sure you can get many more opinions...just my .02
(in reply to forktail devil)
       Post #: 84
RE: Lanier Radical 330 ARF - 2/10/2008 11:15:40 AM
PropSpinner
Status: offline
I'm putting a 15x4W on my Saito 82. I'm waiting on my servo and servo extension order to finish building. No rush. It's too wet and cold here to fly.
       Post #: 85
RE: Lanier Radical 330 ARF - 2/12/2008 2:03:40 AM
rickandjayne
Status: offline
Having Problems mounting fuel tank on LANIER 330 RADICAL, ANY SUGGESTIONS !!!
       Post #: 86
RE: Lanier Radical 330 ARF - 2/12/2008 4:20:51 AM
bbagle1
Status: offline
Does anyone have a rtf weight of this plane? If so what is your setup? I will be using a 2 cell 640mah lipo and a magnum 52 2 stroke. I just ported the magnum and will be running it on 30% with a macs pipe and header. I am hoping for 15000 rpm on an apc 12x4.
(in reply to rickandjayne)
       Post #: 87
RE: Lanier Radical 330 ARF - 2/13/2008 12:44:44 AM
toro_0397
Status: offline
i dont have my plane here with me but as far as i remember, the top of both tie wraps go through the lightening holes. drill the whole for the tiewrap as low as possibe since there is a small piece of wood, which will stop the covering from ripping off.
any questions you can pm me.
(in reply to bbagle1)
       Post #: 88
RE: Lanier Radical 330 ARF - 2/13/2008 1:47:33 AM
ekir
Status: offline
I am getting close to finishing the 330. All servos installed and the control rods are all finished except one. Landing gear is on the plane. Need to install engine and fuel tank, then balance. Hope to fly later in the week.
I am setting up the throws to be 45 degrees on high rate and about 20 degrees on low rate. Expo at 50%. Does that sound correct????
(in reply to toro_0397)
       Post #: 89
RE: Lanier Radical 330 ARF - 2/13/2008 3:12:18 AM
