Ruralflyer
Well, this wasn't really a plane, I considered it a toy that my parents got me for Christmas. It was a Cox easyflyer and it was a piece of **** with only 1 channel. Engine and up elevator took it up to altitude while you operated rudder control. Engine ran out of fuel and you gilded down, (in theory!! ). One day decided to try new engine, old one puttering out very bad so we kept fixing the elevator higher, and higher, and higher just to fly level with this thing. Well, new engine went on, power difference between new and old engines was about 400 % i think. Didn't even think to adjust the fixed elevator. Start engine, starts on first try and runs true. We both stare at each other in disbelif we were so used to the old crummy one. My father grabs plane and tosses it with me at the controls of my two button (yes buttons) tx,,, ack! Anyway, it's obvious that something is wrong when it flys vertical 30 feet and then stalls, falling 30 feet, pulling out and then repeating the process. No power control, no elevator control, just left and right. I frantically pushed buttons and the porpoising demon obeyed, yet it still was pulling out inches above ground and then rocketing up to 30 feet again. At one of those peaks it barely clears a powerline, falling down the other side again. I guide it towards higher land, hoping that it will somehow land at full power by pulling out above higher land and nicking the ground at its trough. Yet I was expecting the worst. But, ground effect keeps it from ever touching the ground. It flys away from me over the hill. Lost, It dissapears below the horizon of the hill. I put down the cruddy button Tx, knowing that it had finally met the Earth. But, a full 1.5 seconds later, it rises vertically far behind the hill, faster, but then sloows down. It mocks me, hovering a what had to be 50 ft. high. Unassited, it executes a perfect hammerhead out of its brief hover, points earthward, and......................... Nevertheless, now I have two .049 engines that won't run. My parents now never get me anything for Christmas without asking me what I want and what I don't want! Never really considered that toy a plane anyway.
_____________________________
Perhaps I should of pulled up then?
