traxxboy
AL, USA Status: offline
quote:
ORIGINAL: rusty_y2k2 haha, cheers guys! And yeah, I'm faily sure they frown upon me landing the real things on their noses, upside down and at about 3x normal landing speed too. Live and learn eh. I'm hoping the flaps do allow it to come in much slower, and steeper. The thing really rips along when you're trying to land! it'd be nice to be able to land on the strip of tarmac at my field that i take off from, but it has tennis court side fences at one end and a building at the other, i reckon a skilled r/c pilot could do it with the stock plane but a skilled r/c pilot I am not. Currently landing on the grass, which is okay but not as fun, plus taking off again is covering my underside in a lovely grass green from the prop playing lawnmower. I figure that I love the way this thing flies, and i enjoy messing with stuff (as shown by the fact that i've had that thing a couple days and it;s already got a new paintjob!) so why not put some extra features like flaps and retracts for extra fun. If the motor and esc needs upgrading as a result then so be it, but seems to have lots of power currently! I haven't flown the PZ spitfire, although I have seen it fly along with the FW 190 and both seemed to fly very well to be honest. I was close to buying one of them when i saw the trojan, and since it already had brushless, a lipo and rave reviews (plus landing gear out the box) I decided to take the plunge on one of them instead. I wonder if you guys could help though - I'm mid way through fitting flaps, and with a symmetrical install (ie both servo's with the tops pointing towards the inside of the plane, one moves in the correct sense and one moves the wrong way. How can I get the annoying bugger to reverse? Is it as simple as just switching the positive and negative (obviously leaving signal where it is) on the servo plug? From my limited understanding of electronics - wouldn't that burn out the servo? And don't say turn the servo round, because a) I'm a git when it comes to wanting things the way i want them, and b) i already cut the **** hole - haha EDIT - yup it would lol. pop. Lucky I have a spare eh.... still turns the wrong way mind. Found a Y-harness online that has a reversing module on one side, sounds perfect since i needed a y-harness anyway... so ordered that and a pair of extension leads. Hopefully be here before the weekend along with the UBEC and i'll be able to get going. Double EDIT - while i'm asking, how does one disable the BEC of the standard ESC, because I have a standalone UBEC (3Amp) on the way to take care of my servos and reciever for me. cheers! Here's some quick pics of the the flap mod so far (had to do some extra painting dammit). Obviously the underside needs the servo wire running and a bit of tidying up - should be near invisible once done i think. I added back the red decals just on the underside by the way, it was difficult to tell what way was up on dull overcast evenings! Flaps fully down (i'm guessing about 40 degrees) Flaps Fully up: Underside: Im sorry of you already said but.....What did you use to paint this?
