new to the tornado xl worth the money    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> new to the tornado xl worth the money
Page: [1]
Login
new to the tornado xl worth the money - 4/15/2007 2:26 AM
preston093
Score: 100
Last Login: 4/26/2007
Status: offline
hey everybody i am new on here but i read your forums on the tornado xl before it got here for my son but i went through tightined every thing and i have ran through tanks of gas and me my son son have flipped it a number of times and it is holding up good i have other cars and it seems to be just as good so thanks alot if there is any thing else i need to know about these cars post it on here ..............jerome....................
Hide Signatures
       Post #: 1
RE: new to the tornado xl worth the money - 4/15/2007 2:57 AM
BOBCAT45
Score: 100
Last Login: 7/28/2007
Status: offline
Welcome to the forums !!!!!! I have a tornado xp 2 speed and the car is worth the money,if you do the rite maintnence they r great cars. Once again welcome to the forums!!!!!!
Bobcat
Hide Signatures
(in reply to preston093)
       Post #: 2
RE: new to the tornado xl worth the money - 4/15/2007 4:03 AM
ehroof
Score: 105
Last Login: 6/6/2013
Status: offline
glad to hear you like it bro, is your clutch bell aluminum, if so change it to the hpi one and put a traxxas 4146x spring and you will be fine
_____________________________
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to BOBCAT45)
       Post #: 3
RE: new to the tornado xl worth the money - 4/15/2007 6:54 AM
RangerArlin
Score: 100
Last Login: 11/3/2010
Status: offline
Hey ehroof, what HPI clutchbell are you suggesting? I need one, could you post a link? Also, I read that if you go to a clutchbell with more teeth it will add to your speed on the high end. Is this true and if so would you also have to change to a different spur gear that would fit with your new clutchbell? Sorry for neverending questions! haha! Thanks man! arlin.
Hide Signatures
(in reply to ehroof)
       Post #: 4
RE: new to the tornado xl worth the money - 4/15/2007 7:04 AM
preston093
Score: 100
Status: offline
hey ehroof i seen on here where yall was talking about those parts i have already wrote down those part numbers also i bought a master vhx5 buggy for my son a while back they are like the tornado( from china )the spring in it broke and i matched it up with a duratrax clutch and spring and it works great we just bought these to play around the house because we dont want to tear up our race trucks, i have alot of time and money in them so you can understand but thanks alot i will stay in touch on here thanks ....jerome.......
Hide Signatures
       Post #: 5
RE: new to the tornado xl worth the money - 4/15/2007 7:05 PM
ehroof
Score: 105
Status: offline
quote:
ORIGINAL: RangerArlin
i dont remember what car you have but if its a single speed you use this one, http://www.clermontmotorsports.com/servlet/the-200/Hpi-17-tooth-vented/Detail
the more teeth the better top end but worse low end, the opposite is the same, the less teeth the more low end and less high end
you use the stock spur gear with the hpi clutch bells
Hide Signatures
(in reply to RangerArlin)
       Post #: 6
RE: new to the tornado xl worth the money - 4/15/2007 11:02 PM
preston093
Score: 100
Status: offline
hey ehroof what gear can i put in my sons tornado to make it not rev so high in top speed it has the single speed but in the top speed the rpms seem real high if so do you know where and the part number and what teeth thanks jerome ...
Hide Signatures
       Post #: 7
RE: new to the tornado xl worth the money - 4/15/2007 11:23 PM
ehroof
Score: 105
Status: offline
you need to get more teeth on the clutch bell, i think you cant fit anything bigger than 18 tooth on the engine without having to make the engine mount holes longer. i think the stock one is 16 tooth, give a count and see, if so get 17 or 18 tooth. it will give more top end. Whats wrong with the engine rev at top speed, high rpm's isnt really a problem as long as your running rich engoug.
here is a link for an hpi clutch bell with bearings: http://www.clermontmotorsports.com/servlet/the-200/Hpi-17-tooth-vented/Detail
Hide Signatures
       Post #: 8
RE: new to the tornado xl worth the money - 4/15/2007 11:28 PM
preston093
Score: 100
Status: offline
hey thanks my son like the botom end part of the car any way but i thought we might change it out every now and then and i do run a little rich any way but i was just wondering thanks jerome
Hide Signatures
       Post #: 9
RE: new to the tornado xl worth the money - 4/15/2007 11:33 PM
ehroof
Score: 105
Status: offline
your welcome jerome, good luck and let me know what you get and how it works out
Hide Signatures
       Post #: 10
RE: new to the tornado xl worth the money - 4/16/2007 12:07 AM
RangerArlin
Score: 100
Status: offline
Hey ehroof, thanks for the link man! Im gonna go and get one. Thanks again. Arlin.
Hide Signatures
       Post #: 11
RE: new to the tornado xl worth the money - 4/16/2007 3:35 AM
ehroof
Score: 105
Status: offline
your welcome, thats a good deal too since it comes with the bearings.
Hide Signatures
       Post #: 12
RE: new to the tornado xl worth the money - 4/16/2007 8:55 PM
preston093
Score: 100
Status: offline
has any one heard of putting marval mystrey oil in tha carb and turn the motor to ciculate it into the motor after you run it it takes a couple of more cranks to re start it back up but it save your motor maybe that is something to think about for some of the newer guys that just starting out .............jerome...........
Hide Signatures
       Post #: 13
RE: new to the tornado xl worth the money - 4/16/2007 9:53 PM
ehroof
Score: 105
Status: offline
marvel mystery oil is ok to use but i prefer nitro after run oil, it too makes it a little harder to start but well worth the effort.
Hide Signatures
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.407RCU1
