aeajr
Score: 190 Joined: 1/14/2003 Last Login: 2/6/2012 From: Long Island,
NY, USA Status: offline
If you want to learn close to home and don't have a huge field, then you want a slow flyer that will work in your space. With these you can train in the space of a little league baseball field, a football field or similar space. Once you get good you can fly in just the baseball infield or 1/3 of the football field, in front of your house, or even indoors. I always suggest that new flyers start in very calm conditions regardless of what plane they get. This way they can focus on the plane and not fighting the wind. If you can do this and be strong about avoiding anything above about 3 mph, then you can train close to home. Once you have 10-15 solid flights in a row, with safe landings, then you can move up the wind scale a little at a time as you gain confidence. This could be accomplished in a few 2 hour sessions. Or it could be done in a single 4-6 hour day if you have 3-4 batteries and have a charger or two you can use at the field. Of course, this assumes you don't smack up the plane. Some of these will tollerate 5 mph and some up to about 8. Slow-V RTF from Parkzone - $140 - Space Best flown in still to under 5 mph breeze. This is good for people want an RTF and who only have a small space to fly or who have an indoor place to fly, such as a gym or similar space. The Slo-V can take the X-port combat module and the bomb/parachute. tons of fun in a small space. http://www.horizonhobby.com/ProdInfo/Files/Parkzone_Slo-V_240x180_nb.wmv T-IFO - $75 including Motor http://www.flyifo.com/htmlpages/tifo.html Complete package with radio - $275 http://www.flyifo.com/htmlpages/ordertifo.html# Review http://www.rcgroups.com/links/index.php?id=4117 Slow stick - $35 - Can also be flown indoors in a gym or similar space. http://www.gwsexpert.com/product_info.php?cPath=2_53&products_id=2[/url ] or Slow stick Complete Package incl radio - $150 (need battery charger) [url]http://www.gwsexpert.com/product_info.php?cPath=56&products_id=602[/url ] The Slow Stick Info Site [url]http://mattsrc.rchomepage.com/ssir/index.shtml Discussion Thread http://www.rcgroups.com/forums/showthread.php?t=273180 http://www.horizonhobby.com/Products/Default.aspx?ProdID=GWS1040 http://www.skrogg.com/sun.wmv Souped up Slow sticks go verticle http://skrogg.com/wed.wmv Tiger Moth - $50 http://www.horizonhobby.com/Shop/ByCategory/Product/Default.aspx?ProdID=GWS1020 Review http://www.backyardflyer.com/BY/articles/tiger_moth.asp If you have the money I would recommend a comptuer radio like the Spektrum DX6 or the Futaba 6EXAS as entry level comptuer radios. GWS 12V Peak Charger - can charger from a car cig lighter - There are cheaper chargers, but this one looks good for this plane and future - $49 http://www.horizonhobby.com/Products/Default.aspx?ProdId=GWS3000 ========================================= Radios Starter Radios I have a very specific position on radios. Don't buy a Standard Radio!!! Computer radios are now so inexpensive and offer so much more than standard radios that it doesn't make sense to get anything but a computer radio. Don't get me wrong, there are many good standard radios, but for only a few bucks more you get a much more capable computer radio that can do more for you than any standard radio and can save you money by time you get the second plane. They can also make it easier to fly your plane, perform aerobatics and more. Below are five radios. All will fly your typical parkflyer. All but the DX6 can also be purchased with larger servos suitable for larger planes and gliders. Two are standard radios, for the uncommitted or low budget first time flyer. These will get your plane off the ground with very basic radio features for a low price. Each package I list include radio, micro servos, micro receiver. STANDARD RADIOS Hitec Neon 3 - 3 channel standard radio $59 2 micro servos, micro receiver, switch, etc http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXLGF4**&P=7 For $19 you can add a trainer port to this: http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXDEK8&P=V This package is such good value for that first 3 channel ARF or kit, if you can't afford a computer radio. ( more on that later ) If you bought the two servos and the receiver by themselves, that would come to about $60. So this is about as cheap as you can get into a hobby grade radio that will fly a three channel R/E/T or A/E/T parkflyer or 3 channel glider ARF or kit plane. It also does not include rechargeable batteries which the others do. You run this one on standard AA batteries. It includes mixing for flying wings or V-tail 3 channel planes as well as servo reversing. It does not have ATV/EPA or dual rates, however these can be added later at extra cost. . You can also add a trainer port for use with an instructor or to connect to a flight simulator. You can add a 4th channel but it is limited so don't think of this as a 4 channel radio. It can't fly a 4 channel plane. Hitec Laser 4 - 4 Channel Standard Radio $100 http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXLGF5**&P=ML My minimum recommended 4 channel standard radio for A/E/R/Throttle parkflyer, glow plane or 4 channel glider. Radio, micro receiver, 2 micro servos, Switch harness, etc. It will fly a 4 channel aileron plane. Includes V-tail and Elevon mixing, servo reversing, ATV on ch 1&2 . Also has a trainer port that can be used with fight simulators or a buddy box. While the Laser is a good radio, pick the Laser 4 only if you are unsure you will continue in the hobby and want to spend as little as possible to get a 4 channel plane into the air. Not my recommendation for a committed flyer who plans to continue in the hobby. COMPUTER RADIOS - Much Better Choice In short, computer radios give you things like model memories, exponential, a variety of surface mixes and more; features not found on standard radios. Your computer radio can store the profile for many planes and reset itself for each plane by just selecting the model. Standard radios don't have model memories or a lot of the other features that computer radios offer. With a computer radio, you only need one radio to fly a bunch of planes, rather than dedicating a radio to each plane, or resetting the radio each time you change planes. Computer radios are great! In the end, they are cheaper. more convenient AND can make it easier for a new flyer to learn to fly. These are all 6 channel radios so they will let you fly more advanced planes then either of the radios above. Spektrum DX 6 - $199 - For the committed Parkflyer pilot http://www.horizonhobby.com/Shop/ByCategory/Product/Default.aspx?ProdID=SPM2460 Review http://www.rcuniverse.com/magazine/article_display.cfm?article_id=623 If your plans are to fly small to medium sized electrics, often called parkflyers, hand launched gliders with wing spans under 60 inches, this might be your best choice. The DX6 is suitable for flying within 2000 feet out. That is about 5-7 football fields away. This is more then enough for these plane and further than most people will fly them. It has a nice mix of features, 10 model memories and is backed by Horizon Hobby, so you can be confident of good service. You will never worry about channel conflict again. This promises to be the RC technology of the future. Digital DSMT Spread Spectrum Modulation 10 model memories, dual rates, exponential, 6 channels, 8 standard mixes and three programmable mixes. No crystals needed and no channel conflict control needed DX6 Flight experience thread http://www.rcgroups.com/forums/showthread.php?t=452817&page=2&pp=15 More information on DX6 - Spektrum http://www.spektrumrc.com/DSM/Better/DX6.html AMA on 2.4 GHz SS http://www.modelaircraft.org/spreadspec.asp Futaba 6 EXAS - Entry Level 6 Channel Computer Radio - $150 micro receiver, 3 micro servos, Switch- Receiver in this package is not appropriate for sailplanes or glow planes. OK for parkflyers/low speed electrics. http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJUV7**&P=ML The Futaba 6EXAS is an entry level computer radio for the committed flyer who also plans to fly glow planes, thermal duration gliders or electrics over 60" wing span. Six channels, 6 model memories, a good mix of features and convenience that will carry you a long way. The link is to a package that is good for parkflyers, but there are other packages if you need larger/stronger components for larger planes. For about $30 more than the Laser 4 radio you are miles ahead in capability! Airtronics VG 6000 - $165 http://www.airtronics.net/VG6000.htm http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXEUY5**&P=7 This particular package is very attractive for small electrics. Comes with two small servos AND a 20 amp ESC. 6 channels, 4 model memories, a good mix of features to carry you forward. The VG 6000 is also available with larger components so it can also fly glow planes, and TD gliders that need greater range than the DX6 offers. There are lots of other good choices in computer radios that have more channels, more features and a higher price. however these would be excellent choices for the first time radio buyer or someone stepping up from RTFs who knows they will continue in the hobby. ===========================================================
< Message edited by aeajr -- 4/21/2007 8:28 PM >
_____________________________
Long Island Silent Flyers www.lisf.org Newsletter Editor, Eastern Soaring League www.flyesl.com
Hide Signatures
