RE: Lee's vintage TA-03 R S TRF build thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric On-Road vehicles, race cars and more >> RE: Lee's vintage TA-03 R S TRF build thread
Page: <<   < prev  1 2 3 4 5 6 [7] 8 9 10   next >   >>
Login
RE: Lee's vintage TA-03 R S TRF build thread - 6/13/2007 8:25:50 PM
lee172
Status: offline
the replacement chassis parts turned up today (2x CF, just in case!) plus the last TRF is finally here.
Click to see fullsize image.
Click for fullsize
_____________________________
47 NIB and TA-03R/S TRF, F-103LM, M-04L as runners..
DF-01, FF-01, Volvo 1/14 being built
(in reply to Lunchboxer)
       Post #: 151
RE: Lee's vintage TA-03 R S TRF build thread - 6/15/2007 7:19:21 PM
lee172
Status: offline
took it out very briefly earlier, i couldnt seem to stop barrel rolling it! (at quite low speeds) ive changed the gearing, although its running even hotter now!
(in reply to rcluke)
       Post #: 152
RE: Lee's vintage TA-03 R S TRF build thread - 6/15/2007 7:49:19 PM
Lunchboxer
Status: online
You can roll a touring car?!?!? Weird...
LB | WW2 | TLT | TB02 | DF03 | TEgg | TC4FT | F103GT | TXT | Hornet | M03M | Frog | Scalpel | Leo 2A6 | Aeromax | WW1 | Clod
(in reply to lee172)
       Post #: 153
RE: Lee's vintage TA-03 R S TRF build thread - 6/15/2007 7:53:54 PM
lee172
Status: offline
i'd not managed it before today, quite spectacular really!
will have another go at re-gearing tomorrow..
       Post #: 154
RE: Lee's vintage TA-03 R S TRF build thread - 6/15/2007 7:58:11 PM
Lunchboxer
Status: online
The only time I roll my TCs are when I hit something or if I got hit...
       Post #: 155
RE: Lee's vintage TA-03 R S TRF build thread - 6/15/2007 8:07:14 PM
lee172
Status: offline
well it is short wheelbase (237mm vs 257mm) but its not much shorter than my Mi2, so i dont know whats causing it.
       Post #: 156
RE: Lee's vintage TA-03 R S TRF build thread - 6/15/2007 8:16:45 PM
Lunchboxer
Status: online
Is it pretty high off the ground? Not as wide? Hmm...
       Post #: 157
RE: Lee's vintage TA-03 R S TRF build thread - 6/15/2007 11:39:20 PM
C.A.R.
Status: offline
It's probably got a high C.O.G. because of its design. I always used to roll my TL01 with it's super grippy tyres, and that's the only reason I could think of.
Try Stiffer sway bars, or even try a softer spring weight, as this will absorb the corners better, but the stabilizer will pervent it rolling to far over.
Chris.
       Post #: 158
RE: Lee's vintage TA-03 R S TRF build thread - 6/16/2007 2:37:46 AM
lee172
Status: offline
the only thing ive changed since the last run, is gearing, and its never rolled previously..
(in reply to C.A.R.)
       Post #: 159
RE: Lee's vintage TA-03 R S TRF build thread - 6/17/2007 2:17:00 AM
lee172
Status: offline
the gearing is doing my head in, i'm using the black gear set and i see/feel no difference in temperature whether i use 19T or 23T pinion.
i wonder if the barrel rolling problem could be to do with the rear diff?? maybe the outer wheel isnt spinning fast enough?
       Post #: 160
RE: Lee's vintage TA-03 R S TRF build thread - 6/17/2007 10:40:04 AM
rcluke
Status: offline
quote:
ORIGINAL: lee172
there's only one way to find out
My Racer - Novak GTB 5.5T Brushless Tamiya TA-05
NOVAK OR NOTHING
       Post #: 161
RE: Lee's vintage TA-03 R S TRF build thread - 6/18/2007 11:39:14 PM
lee172
Status: offline
its gonna be TRF testing day tomorrow, i have 3 packs charged, tools and pinions at the ready! i WILL crack this gearing!
       Post #: 162
RE: Lee's vintage TA-03 R S TRF build thread - 6/30/2007 1:36:07 AM
lee172
Status: offline
i got the beloved TRF a new shell, its a bit girly, but with the help of a nice paintjob and good wheels, it should be okay..
       Post #: 163
RE: Lee's vintage TA-03 R S TRF build thread - 7/7/2007 7:05:55 PM
lee172
Status: offline
here it is, its a Mercedes SLK body, oddly it came with two sets of H parts (mirrors). ive cut the body out, sanded it and its just drying, i will apply the masks later.
maybe sanding is a bit OTT in some people's eyes, but i want this perfect, not a half assed job like the M-03R body..
and you may have noticed its been painted yellow! but its a true SLK colour, as ive seen one.
Click for fullsize
Click for fullsize
< Message edited by lee172 -- 7/7/2007 7:06:24 PM >
       Post #: 164
RE: Lee's vintage TA-03 R S TRF build thread - 7/7/2007 11:40:11 PM
