TBM Avenger/Charile Kellogg Plans
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> TBM Avenger/Charile Kellogg Plans
Page: [1]
Login
TBM Avenger/Charile Kellogg Plans - 4/17/2007 8:19:14 PM
P-40BRB
Status: offline
The first test flight is in and this is a keeper. It not only looks good but flies even better. We lost an alerion screw shortly after take off, yeah I forgot to tighten the screws on all the wing flight surfaces after setting them up for proper throws and function. The control arm was seen hanging by me after only the second turn and well the plane flies on one alieron so well that I could not even tell it was off. Landing gear by Serria work flawless and looked way scale. The big bird is just rock steady, even with me shaking it just flew straight as an arrow and smooth I mean it just dosen't get any better in a warbird. After four trips around the field I put the gear back down and put the flaps in at alttidude to check for any bad habits. This plane did not move it just contuined on flying straight, I came off the power to check for stall speed and did not get slow enough on the high pass to see just how slow it would fly, but I do know that it is very slow. I turned down wind and lost alttidude, off the power by half and made my final turn for the field. Now I'm lined up coming is quite nicely so off the power a little more, now she is getting close to the threshold and only about 30 feet high, over the runway all the way back to idle and she just grease's the landing at walking speed, I mean you would have thought I had been flying this plane forever. It lands great and almost on it own. I only kept cutting the power and it just settle in on it's own, I didn't even have to flair the elevator at all. It rolled out very nicely even with the close wheel spacing. This is a great flying warbird and very impressive in the air.
The photo's are before the plane was finished, we were waiting for the paint to dry on the 8 under wing rockets when the shots where taken. The planes flies with the rockets attached. The pedo tube and radar are removable for flight.
It weighs in at 49 pounds.
Power is a Brison 5.8-100cc
Melizx-22/10 three blade prop
Futaba 9cap for control
Serria gear
Robart wheel
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by P-40BRB -- 4/26/2007 4:08:57 AM >
       Post #: 1
RE: TBM Avenger/Charile Kellogg Plans - 4/17/2007 9:21:02 PM
Flakbait
Status: offline
Congrats!!!!
Very nice Avenger!!!
(in reply to P-40BRB)
       Post #: 2
RE: TBM Avenger/Charile Kellogg Plans - 4/17/2007 9:22:51 PM
Chad Veich
Status: offline
Very nice Turkey P-40BRB. Let's see some close-up shots of the detail.
Chad Veich
(in reply to Flakbait)
       Post #: 3
RE: TBM Avenger/Charile Kellogg Plans - 4/18/2007 5:46:35 AM
tora6
Status: online
Good looking A/C . The one I flew was like a kitty cat. 1to1 scale. If I can figure it out I 'll send a picture.
What is your real E-mail address?
(in reply to Chad Veich)
       Post #: 4
RE: TBM Avenger/Charile Kellogg Plans - 4/19/2007 3:33:52 PM
carlbecker
Status: offline
Another great Grumman!!! I saw one at WOD last year. Man I like their designs. Currently I'm building the Bates Wildcat.
Carl
(in reply to tora6)
       Post #: 5
RE: TBM Avenger/Charile Kellogg Plans - 4/21/2007 1:35:00 AM
P-40BRB
Status: offline
I also saw Charlie's Avenger at WOD last year, that is when I got the plans from him and he shipped all the cowls and canopys to me the following week. He was a big help with any questions I had about the build, he even remade the canopy and gave me a new for free. The orignal was 3/4 of and inch to long for scale. I also order the retracts from Serria at the WOD event and had them in two weeks.
Good luck with your Widcat project, keep-em flying straight and level.
Brian (P-40BRB)
(in reply to carlbecker)
       Post #: 6
RE: TBM Avenger/Charile Kellogg Plans - 4/22/2007 5:32:28 AM
fockewulf37
Status: offline
Hey Ya'll,
Here the video of it flying.....
Ty
http://rcuvideos.com/item/H4S7F8KS4VLP518Z
       Post #: 7
RE: TBM Avenger/Charile Kellogg Plans - 4/23/2007 11:15:34 AM
rcfanuk
Status: offline
Nice job, just going to start one as we have received the kit and cowl, canopies etc from Charlie. Retracts will be our own design, machined in the workshop.
Ref the weight, was there any additional strengthening or detail, as it came out quite a bit heavier than Charlie's originals. I need to keep this one under 20 Kgs (44Lbs)to make life a bit easier.
Retract thread is here http://www.rcmf.co.uk/4um/index.php/topic,35934.0.html
Build thread is here (not started yet) http://www.rcmf.co.uk/4um/index.php/topic,35919.0.html
Steve
(in reply to fockewulf37)
       Post #: 8
RE: TBM Avenger/Charile Kellogg Plans - 4/26/2007 3:31:26 AM
P-40BRB
Status: offline
Sorry for the delay on the reply, but we made several changes to Charlie's plans, there is nothing wrong with his plans and if you build right by his plans it will turn out just fine. We made changes to the wing tube area by adding ply ribs at all points that the tube ran through and also added an end block and made the tube run to the next wing rib on the plans. Just a little extra beef up for the 5.8 that we new was going to give the plane a good shake. We also added an extra tail post to give us the needed room to fit the elevator controls internally, only the rudder control rod exits the fuselage at the rear. The evelator was made one piece by adding a huge piece of music wire and adding a welded on control horn in the middle. Thats two more nice size hardwood blocks in the tail one in each evelator half for the wire. We also added a 1/4 scale servo under the ball turret , it holds the turret on and operates on channel 9. We used up all 9 channels. That also is behind the CG, see where this is going, yep straight to the added box on the fire wall for all that lead to balance the plane. It all added up but did not hurt the planes flight performance at all. Good luck with your build, we had a lot of fun building this plane and it turned out nice and flies quite well.
(in reply to rcfanuk)
       Post #: 9
RE: TBM Avenger/Charile Kellogg Plans - 4/26/2007 3:11:35 PM
rcfanuk
Status: offline
Thanks for the update, I like the idea of internal elevator servo's and we will look at that, and I also wouldn't mind a removable tailplane for transport.
If you can think of any other hints in the build process please let me know, but it looks pretty straight forward
Steve
       Post #: 10
RE: TBM Avenger/Charile Kellogg Plans - 6/4/2008 8:58:32 PM
do335pilot
Status: offline
Im starting the construction of the Avenger from Kellogg plansand have concerns about the washout on the wing panels - they appear to be washin. Did you encounter this problem? Your plane is absolutely beautiful, I'm sure you will win many trophies!!! I am considering a Zenoah 80T twin for power to reduce vibration encountered with single piston engines.
Comments??!! Kim
       Post #: 11
RE: TBM Avenger/Charile Kellogg Plans - 6/5/2008 4:05:12 AM
51-D GUY
Status: offline
Hi P-40BRB,
Great job on the Avenger !
what type of paint did you use,
Thanks, 51-D GUY
       Post #: 12
RE: TBM Avenger/Charile Kellogg Plans - 6/5/2008 12:51:51 PM
Nickrc3
Status: offline
Brian,
Nice work on the Avenger. Will you be campaigning it at this year's WOD?Wonder if the designer will attend also. Love to see it fly!
Please provide some specifics about the model, particularily build time, finish and the question regarding wash-out.
Myself and another local modeler have comtemplated building this model.
NICK
(in reply to 51-D GUY)
       Post #: 13
RE: TBM Avenger/Charile Kellogg Plans - 6/16/2008 4:32:18 AM
Flyin Hwn
Status: offline
Anybody know the site for this kellog plans
Flyin Hwn
(in reply to Nickrc3)
       Post #: 14
RE: TBM Avenger/Charile Kellogg Plans - 7/22/2008 2:51:30 AM
redtail
Status: offline
Charlie has a new website: www.kelloggplans.com and his phone number is: 267-688-5453 Chic
(in reply to Flyin Hwn)
       Post #: 15
Page:   [1]
Page: [1]
