how can i make my rs4 3 the fastest?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> HPI Racing >> HPI On-Road >> how can i make my rs4 3 the fastest?
Page: [1]
Login
how can i make my rs4 3 the fastest? - 4/18/2007 5:57:04 AM
wildchildbmx6
Status: offline
i want to make my rs4 3 stupid fast. how can i do this? i want to be able to hang with anything out there.
       Post #: 1
RE: how can i make my rs4 3 the fastest? - 4/18/2007 6:26:25 AM
HeLLsGoD
Status: offline
Strap a NASA space rocket..
No seriously, that question get asked too much. The answer is a BIGGER and BETTER engine will make you go faster. An OS .18CV-RX is what you need
_____________________________
- HPI RS4 - HPI sprint 2 -
Dream, Drive, Drift.
(in reply to wildchildbmx6)
       Post #: 2
RE: how can i make my rs4 3 the fastest? - 4/18/2007 4:07:01 PM
iexion
Status: offline
Or like apollo would say, you have to change your gearing..... "noob"
"All you read and Wear or see and Hear on TV Is a product Begging for your Fatas dirty Dollar So Shut up and... "
(in reply to HeLLsGoD)
       Post #: 3
RE: how can i make my rs4 3 the fastest? - 4/18/2007 7:05:46 PM
Dj New Dynasty
Status: offline
hahaha, hells.... good idea... the O.S .18 CV-R is an amazing engine, its what i run, i recommend if you get it to get a new exhaust system, i chose a dynamite, since its a pretty good price, and sounds great as well... if you do get it, get some high end loctyte cause mine spits out screws like water if i dont check em, and use good loctyte... i wouldnt go too crazy on mods though, tuning helps alot
---Super Series HPI RS4 {Alfa Romero}{GT}{WIP = C-5 Vette}
~Drift/Circuit/Drag~
(in reply to iexion)
       Post #: 4
RE: how can i make my rs4 3 the fastest? - 4/18/2007 10:49:19 PM
RCar
Status: offline
From what I see at the local track, it doesn't matter how fast your car is. What matters is how well it sticks to the ground, and how good a driver you are. A faster car means loosing control easier, and breaking easier. Nitro Star 18SS engine, is just about right.
DAMN people, I’m stating facts here!!!
(in reply to Dj New Dynasty)
       Post #: 5
RE: how can i make my rs4 3 the fastest? - 4/19/2007 1:19:43 AM
hpi apollo
Status: offline
quote:
ORIGINAL: iexion
very, very good iexion
wildchildbmx6, judging from the amount of posts that you have and your general question, you are not very experienced, therefore leading me to say that you dont need to make your rs4 the fastest, a good start would be to get an os 18cvrx and then get the red pinions, and the 41 and 37 tooth spur gears
95% of statistics are made up on the spot
       Post #: 6
RE: how can i make my rs4 3 the fastest? - 4/19/2007 2:18:41 AM
iexion
Status: offline
one thing to note on the 41x37 gearing. your going to need to modd your chassis engine holes in order to fit the gearing correctly
So to make it a bit more clearly, the transmission gears are smaller then stock so you would need to set the engine closer to the trans gears. I've drimmel'd my chassis some and if you dont do this step, your engine prolly wont even tuch the gears. And if it does you will surely grind those fresh gears in less then 5 seconds.
(in reply to hpi apollo)
       Post #: 7
RE: how can i make my rs4 3 the fastest? - 4/19/2007 2:23:19 AM
HeLLsGoD
Status: offline
So even if u push your engine mounts all the way to try fix the mesh it wont work?
       Post #: 8
RE: how can i make my rs4 3 the fastest? - 4/19/2007 2:58:52 AM
Allan Aguilar
Status: offline
Install an engine from a dragster, I am sure you will make it under 6 seconds.
Here is another option, get yourself a giant sling shot and strap your car in it.
< Message edited by Allan Aguilar -- 4/19/2007 3:52:48 PM >
Allan
Sponsored by : MY SECOND JOB ! ! !
       Post #: 9
RE: how can i make my rs4 3 the fastest? - 4/19/2007 3:31:59 AM
rs418ss
Status: offline
I just tried to install the os 18cv-r with pull start and i had a feeling that it would be close and hit's the rear chassis. I don't want to cut the carbon upper deck is there a back plate i can use and remove the pull start to make it fit
(in reply to Allan Aguilar)
       Post #: 10
RE: how can i make my rs4 3 the fastest? - 4/19/2007 3:36:19 AM
HeLLsGoD
Status: offline
I just installed my OS .15 CV-RX last night which is pretty much the same engine. You just have to cut out part of the Diff case and radio tray support. I cut mine out a little too much just a little under a cm( stage 1 lightweight yo!) still looks good though. It never went near the normal plastic radio tray at all, im not too sure about the carbon fibre one though
(in reply to rs418ss)
       Post #: 11
RE: how can i make my rs4 3 the fastest? - 4/19/2007 3:42:51 AM
hpi apollo
Status: offline
you have to grind the chassis slots about 3mm with a dremel
       Post #: 12
RE: how can i make my rs4 3 the fastest? - 4/19/2007 3:45:45 AM
Piero23
Status: offline
quote:
ORIGINAL: rs418ss
yeah you can get the back plate for the engine here its only six bucks but you will have to get a non pull flywheel, non pull
engine mounts, and a starter box which adds up to allot of money
however bump starting is the best method of all just expensive and annoying to carrying a starter box
       Post #: 13
RE: how can i make my rs4 3 the fastest? - 4/19/2007 3:49:11 AM
HeLLsGoD
Status: offline
You also need a new crankshaft if your going to use that backplate which is gonna be at least $150 for starterbox,batteries and all. I always thought the OS .18's were a straight bolt on
(in reply to Piero23)
       Post #: 14
RE: how can i make my rs4 3 the fastest? - 4/19/2007 1:58:15 PM
Dj New Dynasty
Status: offline
they are, you just need to buy the engine mounts for it, theres none built on it
