Multiplex Royal 9 EVO
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Multiplex Royal 9 EVO
Page: [1]
Login
Multiplex Royal 9 EVO - 4/18/2007 12:59:37 PM
Props4ever
Status: offline
I recently purchased this radio from another modeler, its virtually new in condition. I only bought TX and no servos or receiver with it.
Finally tonight i tried it on for the first time on my Aerofly simulator, everything works ok except for right ailerons seems to be mixed with gears!, now i tried to program and authorized "N" switch to gears in TX's programming but its not working out on sim, i also tried to find mixing for ailerons with gear, i can't find that either!.
I am not sure what seems to be the problem here but i hope this is not when i want to use this TX on my actual models at the field!, any help will be appreciated, Thanks in advance...
Sammy
       Post #: 1
RE: Multiplex Royal 9 EVO - 4/18/2007 9:08:06 PM
mglavin
Status: offline
Have you tried to setup the TX with an actual model-RX-servos?
More likely than not there is a programming issue with the TX and or the simulator I suspect.
_____________________________
Michael Glavin
RCU Community Moderator
Hitec * Multiplex Field Representative
(in reply to Props4ever)
       Post #: 2
RE: Multiplex Royal 9 EVO - 4/18/2007 10:01:50 PM
Props4ever
Status: offline
quote:
ORIGINAL: mglavin
No i haven't as yet, but i will do it in next few days, last night was my first time operating it.
I couldn't understand what you said in bold, can you please re explain it to me.
Do you suspect TX's programmin issue
Problem with Sim itself?...
Just so you know i have been using this sim on my Futaba Super 7 TX for months now, its been working perfectly all along.
(in reply to mglavin)
       Post #: 3
RE: Multiplex Royal 9 EVO - 4/18/2007 10:36:38 PM
mglavin
Status: offline
Your Aerofly simulator may have a programming and or setup issue. Try the TX with a RX and servos and see what happens.
Michael Glavin
       Post #: 4
RE: Multiplex Royal 9 EVO - 4/19/2007 7:19:16 AM
Props4ever
Status: offline
Ok i will get back to you after this test...Thanks for now
< Message edited by Props4ever -- 4/19/2007 7:20:14 AM >
       Post #: 5
RE: Multiplex Royal 9 EVO - 4/20/2007 10:32:46 PM
Props4ever
Status: offline
Michel,
I want to use Hitec Electron 6 RX and Futaba S148s with 9 EVO as a starter, how can i program this info into my TX?, I can't find any info in the instruction booklet. Thanks
       Post #: 6
RE: Multiplex Royal 9 EVO - 4/21/2007 3:48:30 AM
Props4ever
Status: offline
Hi Michael,
Today i did your suggested TX with Rx test on one of my everyday models, initially i had to learn how to set up TX channel with RX channel, it took a bit of reading and finally i got it set up. Secondly i turned the TX on again and then turned on RX switch!, well i got channel 20 that i selected but servos in the model started to jitter crazily and ub-normally!, I am on mode 2 but on left stick there is no throttle signal up or down being received by RX, then as i turned stick to right rudder, ailerons started to work!, plus when rudder stick is pushed to right it jitters in that position with both rudder and aileron in right position!. When i turned stick to left, left aileron gets operated to left and rudder is moved back to center position and jitters!.
Now on right stick there is no elevator up and down signal received when stick is moved in up or down directions, yet when stick is pushed to left and right direction elevator in starts to move up and down!.
I am going through instruction booklet but seems as i have to calibrate all servos and enter flight phases in assignment programming section of TX, its very complicated set up as its turning out to be, what can you help me with. I need help and support for setting up first model then once learned i will ok with second or 3rd set ups in future. Can you also tell me what am i doing that is not right.
Thanks in advance.
Sammy
       Post #: 7
RE: Multiplex Royal 9 EVO - 4/24/2007 11:40:49 AM
Props4ever
Status: offline
Its been 4 days now since i last posted my test with RX and servos hooked up in a model, i need help here and seems as no one care in Multiplex customer service about my problem, its now really starting to make me wonder if i took right decision by purchasing MPX Vs AR brands when MPX's customer service is like this!!!!.....
       Post #: 8
RE: Multiplex Royal 9 EVO - 4/24/2007 7:26:51 PM
MikeMayberry
Status: offline
Props4ever- Sorry! While we try to help people as quickly as possible, we can't always get here everyday.
Programming questions are difficult to diagnose via e-mail or over the forums. I would suggest you call our customer service center @ (858)748-6948 and we can try to pin down the problem.
Please note that our presence in these forums is a courtesy to our customers with simple questions; for our full blown customer support you should contact us directly and we will be happy to do whatever is needed to solve your problems.
Mike Mayberry
Hitec RCD USA
Hitec RCD Rep
http://www.hitecrcd.com
       Post #: 9
RE: Multiplex Royal 9 EVO - 4/24/2007 9:16:43 PM
Props4ever
Status: offline
MikeMayberry,
Thanks for the reply, i will now be contacting your customer service department very shortly.
Regards,
Sammy
(in reply to MikeMayberry)
       Post #: 10
RE: Multiplex Royal 9 EVO - 4/26/2007 9:18:28 AM
Wiker
Status: offline
The throttle function has to be assigned to the left stick, unless you select an assignment list that already have it assigned.
All this and more is explained in the Tutorial:
http://www.multiplex-rc.de/cms/vorschau/upload/d_anleitungen/t_re_9_12_tutor_gb.pdf
       Post #: 11
RE: Multiplex Royal 9 EVO - 5/5/2007 8:31:03 PM
Bo Ingram
Status: offline
I am a three year user of a Multiplex Evo 12 and I am having trouble getting a 12X Syn receiver to set.
I am doing the following:
1) Turn TX on.
2) Hold RX set button down.
3) Turn Rx on.
All it does is blink and not take the freq from the TX. It just keeps flashing.
The RX is NIB.
RX Batt full charge.
Any help will be appreciated.
Bo
       Post #: 12
RE: Multiplex Royal 9 EVO - 5/7/2007 5:14:40 PM
martin salgado
Status: offline
quote:
ORIGINAL: Bo Ingram
1) Turn TX on.
3) Turn Rx on.
The RX is NIB.
Bo
Hello Bo,
It sounds like you are doing everyting right. Unfortunately sounds like something is wrong. Please send the transmitter in for service and we will talk a look at it for you for no charge.
Below is a link for a service form.
http://www.hitecrcd.com/Support/service%20form.pdf
Hitec / Multiplex USA
Customer Service
(in reply to Bo Ingram)
       Post #: 13
RE: Multiplex Royal 9 EVO - 5/7/2007 6:22:02 PM
Bo Ingram
Status: offline
Martin,
Thank you very much for your reply.
My Tx works fine with all my other Mplex Rx's. Could it be the receiver since it is new? I have six Rx and no problems. Do I perhaps need to try resetting the factory defalts.
This Rx is going in a TF Cessna 310 so it needs to be right.
Bo
(in reply to martin salgado)
       Post #: 14
RE: Multiplex Royal 9 EVO - 5/7/2007 9:40:17 PM
