Bought a Rs4 3 on ebay (starting at max SPEED!!!....)
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> HPI Racing >> HPI On-Road >> Bought a Rs4 3 on ebay (starting at max SPEED!!!....)
Page: [1]
Login
Bought a Rs4 3 on ebay (starting at max SPEED!!!....) - 4/18/2007 6:21:33 PM
sebhitman
Status: offline
hey guys
I bought a Car on ebay
i started it after receiving it..
& THEN made SO MUCH NOISE just like if it was at full idle , or throlle... the wheels were a little running...
so i pinched the GAZ LINE IMEDIATLY....
i then retryed it was worst so i pinched it again....
I was scared to broke the motor...........
now im trying to unclockwise turn the idle see if it helps + shut the air trim on controller.....
any suggestion i wanted to try it out see how it runs
if i keep or sale it
thanks!!
       Post #: 1
RE: Bought a Rs4 3 on ebay (starting at max SPEED!!!....) - 4/18/2007 6:51:21 PM
Dj New Dynasty
Status: offline
did you check and see if the engine mounts are loose or if sprockets are getting conection? mine gets like that when the motor mounts get loose
_____________________________
---Super Series HPI RS4 {Alfa Romero}{GT}{WIP = C-5 Vette}
~Drift/Circuit/Drag~
(in reply to sebhitman)
       Post #: 2
RE: Bought a Rs4 3 on ebay (starting at max SPEED!!!....) - 4/18/2007 6:52:21 PM
thedub88
Status: offline
with the radio and reciever on, make sure the arm on the carb is at idle position. If it is, then do what you said, turn the idle screw counter clockwise until it stays running with out the wheels turning. If the engine stalls while turning, make sure to turn it clockwise 1/2 turn or it will not start back up
Always start your car on a 2x4 or something to get the wheels off the ground
       Post #: 3
RE: Bought a Rs4 3 on ebay (starting at max SPEED!!!....) - 4/18/2007 7:25:21 PM
sebhitman
Status: offline
but is a 15fe supposed to make that much noise i mean i got a .12 too & it doesnt do half that
(in reply to thedub88)
       Post #: 4
RE: Bought a Rs4 3 on ebay (starting at max SPEED!!!....) - 4/18/2007 7:47:03 PM
iexion
Status: offline
when you buy anything off ebay (anything nitro) your better off putting the engine settings back to factory tuneing. As far as noise, it could be a few things to look at. did you change the exhaust system? and does it idle ok or die out after a few seconds?
< Message edited by iexion -- 4/18/2007 7:53:48 PM >
"All you read and Wear or see and Hear on TV Is a product Begging for your Fatas dirty Dollar So Shut up and... "
       Post #: 5
RE: Bought a Rs4 3 on ebay (starting at max SPEED!!!....) - 4/18/2007 8:13:15 PM
Dj New Dynasty
Status: offline
yeah... check the venturi screw and see how its tuned, the mixture may be part of it as well, like iexion said, set it back to factory, that may make a difference.... i dont trust anything from ebay normally, so i tend to stay away from it, but if u do keep usin ebay, talk to the seller and see how much he knows about the stuff
(in reply to iexion)
       Post #: 6
RE: Bought a Rs4 3 on ebay (starting at max SPEED!!!....) - 4/18/2007 8:25:26 PM
sebhitman
Status: offline
YEs the exhaust system is changed
you know the TUBE where normally goes into the pipe?
now it's only hanging & theres a CHROME PIPE with 2 muffler going straight to the motor.........
I don't get it
Crap %/?/%5
hehe
NExt time ''BUYING BRAND NEW for christ sakes!''
you guys are so right sometime a 150$ deal can be a %?%?% ****
(in reply to Dj New Dynasty)
       Post #: 7
RE: Bought a Rs4 3 on ebay (starting at max SPEED!!!....) - 4/18/2007 8:35:40 PM
Foxy
Status: offline
Yeh, man, unfortunately 2nd hand RCs tend to be money pits...here's what you need to do to solve your problem anyway...
1) check the fuel lines (including the pressure line between the exhaust nipple and the fuel tank lid).
2) remove air filter, and reset idle screw until you see approx 1mm gap, go more closed if in doubt as to what is 1mm.
3) reset factory needle settings.
4) Turn on the radio and center the throttle trim. Is the carb gap now more than you just set it? If so, adjust the trim for now so that it just closes again back to 1mm-ish.
5) Test the brakes and steering. Replace the air filter. Start her up.
If it then does not start, increase the idle screw, adjusting the controller trim as you do so, so that the idle setting and throttle servo are not fighting each other. Increase the carb gap very slowly (1/4 turn at a time) until it starts.
Let me know how that goes...
Foxy. RCU Car Forums Moderator.
"Artificial Intelligence is no match for genuine stupidity".
Check out my Large Scale Gas RC Car Vids... www.youtube.com/foxy4242
       Post #: 8
RE: Bought a Rs4 3 on ebay (starting at max SPEED!!!....) - 4/18/2007 11:22:38 PM
sebhitman
Status: offline
Maybe i will just sale them?
I nhave 2 cars now that needs love
I guess 390$ us + ship
would be good?
a rs4 2 + rs4 3 .?
with both remotes6
maybe i could finance a new car & REALLY START In the hobby?
what do you guys think?
(in reply to Foxy)
       Post #: 9
RE: Bought a Rs4 3 on ebay (starting at max SPEED!!!....) - 4/19/2007 9:06:29 AM
Foxy
Status: offline
I think you should persevere with what you bought already, maybe sell one of them to put some money into the other. Try the steps I told you above, then if it really turns out to be a PITA to run, you learned your lesson about 2nd hand, and yes, probably you should just get a new one. At least now you have radio, etc...you can go for a kit.
       Post #: 10
RE: Bought a Rs4 3 on ebay (starting at max SPEED!!!....) - 4/19/2007 6:29:48 PM
sebhitman
Status: offline
Just turned the valve
where the fuel line is until it blocks & gaive it 2 clock wise turns & started it
didn't work until i rech a certain point then ITM BEGAN RACING ITSELF BIG TIME!
& the valve was HOT even after
so im $?&$?&$? PISSED right now at my ''auction'' bought....
the car looks very good i can'T understand WHy it does that ;(
(in reply to Foxy)
       Post #: 11
RE: Bought a Rs4 3 on ebay (starting at max SPEED!!!....) - 4/19/2007 9:12:05 PM
Foxy
Status: offline
did you do the steps I described above? If you have a problem with any of them I'll explain in more detail if you like, it has to be either an idle, tune or trim issue, which those steps should help you resolve.
       Post #: 12
RE: Bought a Rs4 3 on ebay (starting at max SPEED!!!....) - 4/20/2007 1:10:57 AM
sebhitman
Status: offline
im pretty sure it's a iddle problem as the AIR & throttle is CLOSED....
.it just starts like a BOMB
Crank it BOOM! full speed out of control i freak out each time
+ the neighboors are like **** is happening there a weed eater not able to start?
hehe
(in reply to Foxy)
       Post #: 13
RE: Bought a Rs4 3 on ebay (starting at max SPEED!!!....) - 4/20/2007 1:42:34 AM
HeLLsGoD
Status: offline
You realise your problem is so simple, cant believe you still havent figured it out. The only way your car could start out sounding like its out of control is because your carb opening is too much.
Heres the quickest way to test it:
1)Take off you filter
2)Turn on your radio gear dont touch it and leave it at neutral
-At this point there should be at least 1mm opening on the carb
3)Apply the trigger to full throttle
-The carb opening should be fully open and u should see a nice round circle
4)Apply the trigger to full brakes
-The carb opening should return to the starting 1mm and NO more NO less
Easy as that. Now go do it and tell me what your results are
- HPI RS4 - HPI sprint 2 -
Dream, Drive, Drift.
       Post #: 14
RE: Bought a Rs4 3 on ebay (starting at max SPEED!!!....) - 4/20/2007 10:05:34 PM
Dj New Dynasty
Status: offline
nice hell i wouldnt have thought of tellin him that, lol
(in reply to HeLLsGoD)
