schroedm
Joined: 7/9/2002 From: SevenoaksKent, UNITED KINGDOM Status: online
Well, barring setting up the radio she is ready to fly. As most people predicted it went over 20kg soooo, I had to put her on a diet. Switched from 4 8711s on the elevs to 2 saving around 6oz with the associated wiring etc Dropped from 3300 RX packs to 2500packs saving around 4oz Removed the PB Royal LCD screen and mounts etc saved around 4oz Stripped out a load of spiral wrap, ties, clips and bling type internals saved 2.5oz Ditched the 10oz Booster 160 ECU pack for a 5oz lipo pack (will use std pack as a 'booster' start battery) saving 5oz You CANNOT build this model with 'standard' gear and hit the WJM 20kg limit - trust me, I tried Weighing her again she tipped the scales at 43lb 13oz (average of 3 weighing sessions) Turbine start tomorrow, final radio setup and then a wait for some decent weather!!! Rgds, Mark
_____________________________
UK Comp-ARF Rep
