RE: Skygate Collection Hawk - BUILD PICS!!!
Tower Hobbies
Logged in as Guest
Users viewing this topic: marclietzmann
  Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Skygate Collection Hawk - BUILD PICS!!!
Page: <<   < prev  1 2 3 4 5 6 [7]
Login
RE: Skygate Collection Hawk - BUILD PICS!!! - 5/16/2008 10:34:26 PM
Geoff White
Status: offline
Hi Mark,
Yeahs thats a bit violent!
I just think the strut is caught or jammed on something so the cylinder can't overcome the drag till the other strut is down and hence the pressure build up in the one cylinder is greater. I think I can hear the other strut coming down immediately. You can confirm this by pinching the pipe to the other main retract unit. I expect the unit to come down straight away with no delay.
The most common reason I see why retracts don't come down is that the strut or wheel are rubbing on the wing when they are in the retracted position. I guess you have looked closely and everything is in order here?
Also if the retract unit is being deformed when it is mounted, can you loosen the mount screws temoparily?
Also(again) I know its probably a pain in the arse but how about swapping the retract units to confirm it isnt one particular one?
Also(again again) how about taking the wheel and strut off to see if the retract unit works smoothly?
Geoff.
< Message edited by Geoff White -- 5/16/2008 10:41:14 PM >
(in reply to schroedm)
       Post #: 151
RE: Skygate Collection Hawk - BUILD PICS!!! - 5/17/2008 3:48:51 AM
Craig B.
Status: offline
Hi Mark,
I have encountered the problem that David mentioned on several retract systems over the years. The more precisely fitting the retract components, the more likely the problem. I have fixed the problem by waxing up the retract frames and mixing up a slurry of resin and talc (not microballoons, too soft), apply it carefully and minimally to the retract mounting rail and then insert the retract. Tighten the mounting bolts with minimal torque, ie two fingers lightly on the driver. Let the resin cure and you have a perfectly passive retract mount. My bet is that will solve your problems. As David has suggested, your symptoms suggest a high friction load in the retract mechanism while it is in the wing.
I would interested to hear how you go either way.
Kind regards,
Craig.
       Post #: 152
RE: Skygate Collection Hawk - BUILD PICS!!! - 5/17/2008 9:04:01 AM
schroedm
Status: offline
Cheers guys - will try this later and let you know.
Right now I'm off to pick up my new van so I can shift this big ol beast around easily
Rgds,
Mark
_____________________________
UK Comp-ARF Rep
(in reply to Craig B.)
       Post #: 153
RE: Skygate Collection Hawk - BUILD PICS!!! - 5/27/2008 10:28:46 AM
schroedm
Status: offline
moved post
< Message edited by schroedm -- 5/27/2008 10:47:24 AM >
UK Comp-ARF Rep
       Post #: 154
RE: Skygate Collection Hawk - BUILD PICS!!! - 5/27/2008 2:15:32 PM
The birdman
Status: offline
So Mark - does this mean you have now flown the beast?
       Post #: 155
RE: Skygate Collection Hawk - BUILD PICS!!! - 5/27/2008 2:19:07 PM
schroedm
Status: offline
Well, I was planning on testing it this Bank Holiday weekend but the 30mph winds and 2" of rain put pay to that.
It is sat charged, fuelled and ready to go. I just need work, weather and time to co-operate and we should have some air under those wheels! I may even skive a day this week if I wake up and the weather is looking good!
Pics and vid when it does happen!
Cheers,
Mark
UK Comp-ARF Rep
(in reply to The birdman)
       Post #: 156
RE: Skygate Collection Hawk - BUILD PICS!!! - 5/27/2008 3:10:33 PM
The birdman
Status: offline
Good old British bank holiday weekend weather!
I suppose it doesn't help if I tell you I had a great weekend of flying out here in the States - even with my deep medeterranian complexion - I ended up catching a little too much sun !
I used to be pretty good at saying I was working from home or at some sort of obscure meeting when the weather suddenly got good........
       Post #: 157
RE: Skygate Collection Hawk - BUILD PICS!!! - 6/23/2008 11:46:16 PM
Andrew Lumley
Status: offline
who did the painting for your plane schroedm?
       Post #: 158
RE: Skygate Collection Hawk - BUILD PICS!!! - 6/30/2008 12:08:35 PM
schroedm
Status: offline
Guy in the UK - Ray Habgood. Booked for eternity however
UK Comp-ARF Rep
(in reply to Andrew Lumley)
       Post #: 159
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.500RCU1
