DelRay
IA, USA Status: offline
Mikael,Nice looking plane,and congrats with the maiden flight, it's a rush ,for sure. I hope you get the vibration problem sorted out, thanks for the link to the pic. I'm not at all familiar with this plane, but like you mentioned, it sounds like all of your problems are with the less than adequate motor mounts. I would use a piece of aluminum .125 flat stock stock, drilled and tapped for the bottom side of the motor mounts if you don't modify the firewall to use the standard mounts available. Jim
_____________________________
AMA # 173709 Have traveled to the East I.M.A.A. # 4971 Amateur call WB0KFB
