RE: KMP Flycat
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: KMP Flycat Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: KMP Flycat - 7/15/2007 2:27:05 AM
p-80
Status: offline
nice work crash pro thanks for the update
(in reply to CrashPro)
       Post #: 51
RE: KMP Flycat - 7/15/2007 8:55:08 AM
CrocEnd
Status: offline
CrashPro
Good to see it working.
Where is the wheel centre now in respect to the original forward or rear from the fixed gear.
Will see what retracts fit.
Cheer's
< Message edited by CrocEnd -- 7/15/2007 8:56:45 AM >
(in reply to p-80)
       Post #: 52
RE: KMP Flycat - 7/15/2007 11:09:20 AM
CrashPro
Status: offline
quote:
ORIGINAL: CrocEnd
CrashPro
Cheer's
hmm,...not quite sure I understand your question CrocEnd?.....the only thing that has changed is the retract servo tray has been moved forward about half an inch. The front gear will be fixed until I figure out which retract will work in this airplane. I know nothing about retracts so all suggestions welcome.
(in reply to CrocEnd)
       Post #: 53
RE: KMP Flycat - 7/15/2007 11:56:00 AM
CrocEnd
Status: offline
Right I have no retact area it is a fixed carriage I have to put retract system in,the wing mounting blocks in mine run length wise with fuse not the wing.
       Post #: 54
RE: KMP Flycat - 7/15/2007 12:20:47 PM
CrashPro
Status: offline
oh.....ok....I see what you're saying.....Serge had already set up the wings for retracts when he gave me the plane,...so I don't know what it was like before he did that.
       Post #: 55
RE: KMP Flycat - 7/17/2007 12:15:21 AM
CrashPro
Status: offline
Well, Serge gave me a .61 O.S. to mount on this thing,..however...it just isn't going to work. The engine mount isn't wide or tall enough, which wouldn't be that big of a deal to modify,...but, the problem is, the vertical fin is at such an angle, that unless the engine is way back on the mount, the engine hits the vertical. Heres a couple pictures with a .46 sitting on it. With a 11 inch prop on it, there is only 1/4 inch clearance to the ground. Only takes about 10-15 degrees rotation and the prop is on the ground. Also,...is a picture from the manual,..showing where they mounted their engine,..BUT,...without the vertical fin attached. I guarantee you, the fin did NOT go on after they mounted the engine in that place. Not sure if this thing is ever going to fly.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by CrashPro -- 7/17/2007 12:28:26 AM >
       Post #: 56
RE: KMP Flycat - 7/18/2007 12:23:49 PM
dragraces
Status: offline
Hang in there Crash cant give up yet !!
Now you know why Serge gave it to you huh ??
Hey Ithink Im running A 10 in prop on my 46fx for the Bobcat that will give u a little more clearance
Jason
< Message edited by dragraces -- 7/18/2007 12:26:20 PM >
       Post #: 57
RE: KMP Flycat - 7/18/2007 12:33:20 PM
CrashPro
Status: offline
yea,....I've got 10X6 props on order,...should be here today or tomorrow....I'm gonna go ahead and finish putting this thing together and see what happens....probably will fly Sunday
(in reply to dragraces)
       Post #: 58
RE: KMP Flycat - 7/19/2007 10:21:25 PM
TommyNad
Status: offline
Well it looks like I will not be able to fit my DA-50 in it I am hoping to put an OS 55 in it. I think I can put a higher pitch prop and cut it down a bit.
       Post #: 59
RE: KMP Flycat - 7/19/2007 10:59:29 PM
CrashPro
Status: offline
yea...that DA-50 might be just a tad too much for this thing.
I've only got a few minor things to finish up and it will be ready to fly.
Me being the only guy at the field that does any videoing, I'm gonna have one of the other guys do the maiden flight Sunday so I can make a good video of it. Its actually a pretty cool looking little plane.
Hope it flies as well as it looks.
< Message edited by CrashPro -- 7/20/2007 4:23:40 AM >
(in reply to TommyNad)
       Post #: 60
RE: KMP Flycat - 7/20/2007 3:23:33 AM
p-80
Status: offline
cant wait crash pro i have to agree its cool looking could you get some final product full pictures of the plane for us thanks
       Post #: 61
RE: KMP Flycat - 7/20/2007 3:37:41 AM
CrashPro
Status: offline
hey...funny you should ask p-80....I was just outside taking some pictures....here ya go
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to p-80)
       Post #: 62
RE: KMP Flycat - 7/20/2007 3:52:18 AM
CrashPro
Status: offline
By the way p-80.....you asked me if it has rudder control,....and I told you yes it does.....that is not correct. I had read thru the manual and saw this ( see picture )thats why I told you it did......what they are referring to as the 'rudder', is actually the elevator. There is no rudder.
Click for fullsize
       Post #: 63
RE: KMP Flycat - 7/20/2007 5:33:51 AM
p-80
Status: offline
coool thats an interesting looking plane for shure it kinda remindes me of the long ez from the reer a no rudder thats a bummer but i stil think its prety awsome nice job cras pro
       Post #: 64
RE: KMP Flycat - 7/20/2007 4:49:44 PM
