Problem with a pin switch??
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Smart-Fly (Quest Engineering) Support Forum >> Problem with a pin switch??
Page: [1]
Login
Problem with a pin switch?? - 4/23/2007 2:36:49 AM
3Dreaming
Status: offline
I'm having problems with my pin switch. I am using a Super Regulator with a pin switch. There have been some times when I turn my transmitter on I find the receiver already has power with the pin in the switch. Normally I don't hear any noise coming from the airplane, but today several time I would hear the servos buzzing from the wind pushing on the control surfaces. I would go to check the switch, and the pin seems to be in place. I'm I doing something wrong, or do I have a bad switch? Thanks, Tom
_____________________________
If you don't learn from it your doing something wrong!
       Post #: 1
RE: Problem with a pin switch?? - 4/23/2007 3:56:48 AM
MustangAce
Status: offline
I am having the same problem??
(in reply to 3Dreaming)
       Post #: 2
RE: Problem with a pin switch?? - 4/23/2007 4:17:51 AM
PropStriker
Status: offline
I use the same switch, When it was new, it was a little tough pushing the pin past the activation point.....it got easier after more usage. Make sure the pin goes into the switch 5/8"
Along these same lines, I am just a bit curious about MTBF (life expectancy) for this switch....One plane has over 400 flights on it!
Larry L.
<www.fortunemodelproducts.com>
(in reply to MustangAce)
       Post #: 3
RE: Problem with a pin switch?? - 4/23/2007 5:05:42 AM
rmflyfish
Status: offline
I agree with PropStricker, I've found mine activates in the last 1/16 to 1/8 inch, and as it's still new, it's kinda hard to push in the last little bit.
Be carefull and try pushing it in a little further.
BP
(in reply to PropStriker)
       Post #: 4
RE: Problem with a pin switch?? - 4/23/2007 3:15:59 PM
rrritchey
Status: offline
Hi,
The common problem is not pushing the pin in far enough. There is a slight detent early but you have to push past that. Let me know if you are still having problems.
Robert Ritchey
Owner, Smart-Fly
(in reply to rmflyfish)
       Post #: 5
RE: Problem with a pin switch?? - 4/23/2007 5:38:17 PM
3Dreaming
Status: offline
OK I checked and I was not getting the pin in all the way. By supporting the rear of the switch I was able to push it in all the way. Besides polishing the end of the pin to make it more rounded, (which I already did) is there anything else that can be done to help? I have some Dow Corning DC4 electrical silicone compound, would it be OK to lubricate it with that? My switch is mounted in balsa sheeted foam, and does not have a lot of extra support. Tom
(in reply to rrritchey)
       Post #: 6
RE: Problem with a pin switch?? - 4/23/2007 5:45:55 PM
rrritchey
Status: offline
Hi,
You might try grinding the end of the pin so there is more of a bevel all the way around. Pointier would be better than rounded. I don't think the silicon compound will do anything, in fact, it might make it less electrically conductive in the off position which would not be good.
Robert Ritchey
Owner, Smart-Fly
       Post #: 7
RE: Problem with a pin switch?? - 4/23/2007 6:15:55 PM
MustangAce
Status: offline
Thanks guys, that helps.
       Post #: 8
RE: Problem with a pin switch?? - 4/29/2007 2:41:34 AM
MustangAce
Status: offline
Oops, it failed today. It won't turn the plane off at all now. Can I still fly it like this???????????????????????????
       Post #: 9
RE: Problem with a pin switch?? - 4/29/2007 6:44:36 PM
rrritchey
Status: offline
I will get you a replacement out Monday. Send me your address and phone number at Info@Smart-Fly.com.
Robert Ritchey
Owner, Smart-Fly
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
9.047RCU1
