RE: RC Tank F.A.Q.
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> RE: RC Tank F.A.Q.
Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: RC Tank F.A.Q. - 3/6/2008 11:54 AM
wackywheelz
Score: 100
Last Login: 9/24/2009
Status: offline
Installing an S&S board (RX14) into non-S&S Pershing
Here is my guide with plenty of pics and wiring/plug detail, suitable for all tanks.
LINK
_____________________________
Tamiya Sherman | Matorro KT | Bandai Hummel | HL Tiger (x3), Pershing, PzIII, Bulldog | T34/76 | 1/12 M1A2 | T34/85 (x2)
Hide Signatures
(in reply to pzrwest)
       Post #: 51
RE: RC Tank F.A.Q. - 4/11/2008 10:35 PM
samarkh
Score: 100
Last Login: 6/14/2008
Status: offline
Complete Heng Long / Hen Long / HL Sound and Smoke (s&s) Technical Reference Manual.
Download the file of interest. dump the .txt extension, open with PDF reader, enjoy.
Yours Simon M.
PS If you claim it as you work I'll get guite mad!
Fc90218.txt = TK-RX13# Kf14318.txt = TK-TX11P (NonUK Controller) Wi59569.txt = TK-YL101 Receiver Tk76799.txt = Sound Protocol
Ed61537.txt = TK-TX11P (NonUK Controller) Zm62134.txt = Controller Protocol
Same order as below
Click to see the file in new window.Attachment.txt Click to see the file in new window.Attachment.txt Click to see the file in new window.Attachment.txt Click to see the file in new window.Attachment.txt
< Message edited by samarkh -- 4/12/2008 11:54 PM >
Hide Signatures
(in reply to wackywheelz)
       Post #: 52
RE: RC Tank F.A.Q. - 5/6/2008 1:37 AM
hdbeast
Score: 100
Last Login: 11/8/2009
Status: offline
ZIMMERIT:
by Donald Spalding
Production and Application Methods
This information is from a secret British Intelligence Objectives Sub-
Committee report. The information is now unclassified and entitled,
"Zimmerit" Anti-Magnetic Plaster for AFVs, which was reported by Major
J.W. Thompson and Mr. C.E. Hollis. The report is dated July 1945, and
is not complete due to insufficient information, or the failure to locate
persons with detailed knowledge of the subject.The investigation was
started with the hope that a way might be found to defeat magnetic mines
used against British armor in the war with Japan.
In 1943 the Germans adopted a thick coating for the vertical armored
surfaces of their tanks. This coating was designed to defeat the affects
of mines placed on armored vehicles, mainly tanks, by determined Russian
infantry assault teams. The mines were attached to the tanks and held in
place by magnets built into the bottom of the mines. The function of the
"zimmerit" was simply to provide a non-ferrous magnetic gap between the
steel armor and and the magnets, in other words a non-magnetic stand-off.
Early in 1944 samples of zimmerit were taken from captured vehicles and
instructions for its use obtained from prisoners of war. The composition
of zimmerit was analyzed by C.S.A.R. and found to be the following:
Polyvinyl Acetate-25%, as binder or glue Wood Fiber-10%, as filler
Barium Sulphate-40% Zinc Sulphide-10% Ochre Pigment-15%, for the
dark yellow color.
On August 14, 1945 the investigating team visited the Henschel Werke at
Kassel, Germany and interviewed the Director of Production and
Production Engineer. The following information was obtained. The
zimmerit was received in drums from Chemische Werke Zimmer in Berlin,
but they thought production had taken place in various centers because
of the large scale demands, and because of factory dispersal.
The material arrived in a consistency of soft putty (others have compared
it to paste, plaster or plastic). It contained a volatile solvent smelling
like acetone. No thinners were added before use as it worked very easily
even when handled by inexperienced personnel.
The surface of the tank did not need to be prepared before applying
zimmerit, but it was normal to coat the vehicle with anti-corrosive primer.
The zimmerit was applied to the surface in two coats, using a sheetmetal
trowel. The first coat was 5mm thick and was marked out in squares using
the edge of the trowel. This coat was allowed to dry at ordinary
temperatures for 24 hours. The second coat was applied thinner and
marked in wavy lines with a metal comb. The criss-cross squares increased
the adhesion of the second coat, while the comb markings gave a camouflage
finish, plus poor contact for mines.
After the application of both coats, the surface was treated by a gas
blow-lamp to harden it. This took about an hour per tank and no difficulty
was experienced in getting satisfactory hardness without the zimmerit
becoming brittle. (I have seen samples of aged zimmerit and it reminded
me of compressed sawdust.) During the hardening process the solvent was
removed by the heat of the blow-lamp on the surface. The chief thing to
watch was not to leave any soft spots which could be brushed off the
vehicle if not hardened properly. If the zimmerit was not heated with
a blow-lamp it took eight days to harden. This was impractical considering
the urgent need of tank delivery to the front.
The Production Engineer of Henschel Werke said that the company did not
help in the development of zimmerit, but simply applied it to vehicles.
He thought that zimmerit was dropped late in the war due to the development
of better anti-tank weapons. No mention was made of how successful zimmerit
was, however, when the British Army captured the Henschel Werke they
removed about 100 tons of zimmerit.
The investigating team next visited the Karl Freudenburg A.G. in Weinheim,
Germany and talked with the companyÍs Polyvinyl Acetate experts.
Again, this company had not helped in the development of zimmerit, but
did work on the P.I.B. mineral oil adhesives for sticky bombs. The Polyvinyl
Acetate was used as an emulsion in camouflage paints and as a solvent such
as Ethyl Acetate and Toluene during the war. It was mentioned that C.W.
Zimmer of Berlin was well known for paint manufacture during that time,
and probably used Polyvinyl Acetate.
On visiting I.G. Farbenindustrie A.G. Hochst, Germany, the Plastics
Development Manager and Production Manager were interviewed. They said
that they had heard of the C.W. Zimmer Co., but also knew nothing of the
development of zimmerit. It was also mentioned that such things were kept
secret. After referring to the companyÍs records it was learned that
Mowilith 20 (a Polyvinyl Acetate) was sold to the C.W. Zimmer Co. in
July 1943, but they had no idea if the company or its personnel still
existed.
The general properties of Polyvinyl Acetate were discussed. Mowilith 20
was 50% benzene solution (this is what smelled and was burned off with
blow-lamps). It had an average MW of 3500 (Staudinger viscosity method,
1 - 2% solution) and a melting range of 40 to 50 degrees C.
It was also confirmed that the blow-lamp would remove the solvent and
adhere the zimmerit to the armor, thus increasing its resistance to shock.
In regard to adhesion, it was suggested that a clean or just painted
surface would be better than a greasy or rusty one. Also, that Polyvinyl
Acetate with a pigment mixture (zimmerit had 15% ochre) were somewhat
water-resistant, but due to thermal behavior of Polyvinyl Acetate its use
was limited in plastics as it became brittle when cold.
In conclusion, the team decided that the C.W. Zimmer Co. was responsible
for zimmerit and every effort should be made to contact them. They also
were wondering if zimmerit, thinned down, could have been sprayed on
vehicles to speed up application time. However, no follow-up research was
done due to the end of WW2.
I wish to gratefully acknowledge the help of the staff of the Imperial
War Museum who made this article possible.
HL Panzer III & IV, Persing, Bulldog, Jagdpather, T34/85 upgraded with HL, Tamiya Sherman and King Tiger.
Hide Signatures
(in reply to samarkh)
       Post #: 53
RE: RC Tank F.A.Q. - 5/15/2008 4:48 PM
samarkh
Score: 100
Status: offline
TK RX14 Circuit
Its basically a RX-13# with a MOSFET output stage.
This gives ups it to at least 10A, but only 2W.
I cannot identify the 'LL6' SMD, if anyone is aware of what it is I'd be grateful.
Yours Simon M.
Download the attached and dump the .TXT
< Message edited by samarkh -- 5/15/2008 4:50 PM >
Hide Signatures
(in reply to hdbeast)
       Post #: 54
RE: RC Tank F.A.Q. - 5/28/2008 8:52 PM
ErichB
Score: 100
Last Login: 10/4/2009
Status: offline
I've got an S & S HL Tiger 1 and it suddenly began to make a loud, whine when the smoke switch is turned on. It's not affected by the volume control, and is nearly as loud as the engine noise, and the unit does not appear to be smoking (although I've not had it on for very long with the whine). I've used this only for maybe 1 hour since receiving it 6 months or so ago. I've never taken one of these tanks apart, but will if it's necessary.
Any help would be welcome!
ErichB
Hide Signatures
       Post #: 55
RE: RC Tank F.A.Q. - 7/4/2008 8:53 AM
mackem
Score: 100
Last Login: 6/3/2009
Status: offline
Not mundane at all. I like my tanks to look as realistic as possible.
One of the best sources for tips and tricks on painting, camouflage etc are scale model web sites.
This one is excellent: http://www.missing-lynx.com
That looks finished to me. Mmm, but what if I..........
Hide Signatures
(in reply to 123Splat)
       Post #: 56
RE: RC Tank F.A.Q. - 7/4/2008 9:28 PM
pim
Score: 100
Last Login: 11/7/2009
Status: offline
Q: what kind of wear and tear can I expect concerning the tracks of a tamiya tank (king tiger)?
Should i expect to reguarly to but replacement's or do they last forever, because I just can't seem to find cheap replacements. I don't mind buying the verry expensive metal ones, but not on a regular basis.
Hide Signatures
(in reply to mackem)
       Post #: 57
RE: RC Tank F.A.Q. - 7/7/2008 1:48 PM
TigerI
Score: 100
Last Login: 11/1/2009
Status: offline
The regular nylon tracks that come with the kit are fine for now. After awhile they will wear out or they will stretch forcing you to adjust the tension until you cannot adjust them any further and force you to replace them. Metal tracks will probably last forever and add a lot of weight to the tank which gives it a more realistic movement. Impact and Kenny Kong probably make the best metal tracks. Not cheap but a great upgrade!
Greg
Xray 808
Hide Signatures
(in reply to pim)
       Post #: 58
RE: RC Tank F.A.Q. - 7/26/2008 7:44 PM
cmryan
Score: 100
Last Login: 9/21/2009
Status: offline
quote:
ORIGINAL: Richard L.
Q: How do I remove the road wheels from an HL Tiger I?
A: Insert a wide flat blade screwdriver between the suspension arm and the back of the road wheel. Then twist the screwdriver to pry out the road wheel. Once the wheel axle is loose, hold the suspension arm with the fingers on one hand while pulling the wheel straight out with the other hand. It is important not to exert any pulling force on the suspension arm because it might break. You can also use a small pair of bent nose pliers to pry the wheel out from the back.
Don't do this with the later versions - use a hex key to remove the bolt.
Hide Signatures
(in reply to Richard L.)
       Post #: 59
RE: RC Tank F.A.Q. - 9/20/2008 3:59 AM
blitzkrieg65
Score: 100
Status: offline
Here we can ADD a list of forum post links that keep coming back every 3 months!
The DEAD HORSE or R & D idea in progress
1} Brushless Motors
http://www.rcuniverse.com/forum/m_7963841/tm.htm
Hide Signatures
(in reply to cmryan)
       Post #: 60
RE: RC Tank F.A.Q. - 9/27/2008 4:44 PM
kevlar22
Score: 100
Last Login: 9/27/2008
Status: offline
Hi Guys!
I need replacement track parts for my HL Tiger, where can I find them??
thanks,
Hide Signatures
       Post #: 61
RE: RC Tank F.A.Q. - 9/28/2008 1:22 PM
pzrwest
Score: 100
Status: offline
What parts are you looking for? You can always contact www.matotoys.com/canada requesting parts
Hide Signatures
(in reply to kevlar22)
       Post #: 62
RE: RC Tank F.A.Q. - 9/30/2008 6:32 PM
grim_marmazet
Score: 100
Status: offline
quote:
ORIGINAL: ErichB
ErichB
Hi, I just got my first tank, a Pershing (a Tiger is on the way!), and im getting the same problem. The whine from the smoke generator is incredibly loud. I am getting smoke, and a nice amount too, but I cant use it with the noise.
Is this normal, and if so, is there any way to dampen the sound?
Also, when I turn up the volume, it only makes the engine sounds louder, not the gun or MG.
Cheers,
Rik
Hide Signatures
(in reply to ErichB)
       Post #: 63
RE: RC Tank F.A.Q. - 10/1/2008 6:55 AM
mackem
Score: 100
Status: offline
The smoke unit is a nice idea but it has caused problems for many of us.
If you do a search on this forum you will find a few threads were members have customized the smoke unit to run with a PC cooling fan instead of the noisy motor and piston unit that it comes with. Your other option is to switch it off.
Hope this helps
John
Hide Signatures
(in reply to grim_marmazet)
       Post #: 64
RE: RC Tank F.A.Q. - 10/13/2008 5:59 PM
Dongskie
Score: 100
Status: offline
Whenever I accidentally leave the battery connected in the tank and switch it on after a few hours it doesn't respond to the controller.
Has anyone encountered this incident?
Tiger 1, M41A3 Bulldog, M26 Pershing, Panzer III Ausf.L, Futaba 9CHP, 3PKS
Hide Signatures
       Post #: 65
RE: RC Tank F.A.Q. - 11/23/2008 5:57 AM
SoulAssassin
Score: 100
Status: offline
Hi Im new here and to rc tanks in general. I dont know squat about them Im planning on getting a Tamiya Tiger 1 very soon and have been looking at videos of them. One video I saw of the TK1 had a moving machine gun that moved left and right when it fired. However it was the only one I saw that had that feature. i wanna know if that upgrade is available or if it was a custome job?
here is the video Im talking about:
http://www.tomsrctanks.com/images/tiger1b%20win.WMV
Hide Signatures
(in reply to Dongskie)
       Post #: 66
RE: RC Tank F.A.Q. - 12/8/2008 7:42 PM
JIDM
Score: 100
Status: offline
Hi John.
John, i've got reduce the noise in the pump system of HL smoke generator by bending a little be the pump axis. I've attached a picture with the Normal axis - "n" and the bended one - "b".
In addition, one difficult thing that I think is , after the repair of this generators - burning element- re- seal the unit, avoiding leaks of smoke.
This will finish with the new model of smoke generator that came with my las Sutg III from Mato. Take a look in the unit.
Regards,
JEferson
Hide Signatures
       Post #: 67
RE: RC Tank F.A.Q. - 12/8/2008 7:46 PM
JIDM
Score: 100
Status: offline
quote:
ORIGINAL: JIDM
Hi John.
Regards,
JEferson
Sorry, here are the pictures.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to JIDM)
       Post #: 68
RE: RC Tank F.A.Q. - 12/27/2008 2:37 AM
Delta 3
Score: 100
Last Login: 6/22/2009
Status: offline
What is a good quality tank for around 100 to 200 bucks, and is the air soft versions all cracked up to what they say thay are?
Hide Signatures
(in reply to JIDM)
       Post #: 69
RE: RC Tank F.A.Q. - 1/4/2009 3:42 PM
shenlonco
Score: 100
Status: offline
quote:
ORIGINAL: shenlonco
the perfect airsoft battle ammo!
paint balls that work with your tanks
http://www.pyramydair.com/cgi-bin/pellet.pl?pellet_id=315
http://www.airgunwarehouseinc.com/py-p-315.html
https://www.sportsmans-depot.com/products/UHC-Precision-Ground-Premium-BB-Pellets%252dPaintball.html
RED paintballs http://www.bbgunworld.com/store/item510.htm
GREEN paintballs http://www.bbgunworld.com/store/item511.htm
Truly 100% biodegradable bb's they degrade in a few days and explode on impact...NO MORE MESS!
Can be purchased here.100% biodegradable bbs
Vedios showing paintballs breaking at 20ft they and break from over 30ft! and the Bio BB's exploding on impact leaving a white chalk like mark on another tank.
They do break at 35ft i tested this with my 1/24 VS tank video bellow
Paint ball testing
35 feet test
http://www.rcuvideos.com/video/marui-tiger-paintball-wmv
Bio BB testing exploding on impact
< Message edited by shenlonco -- 1/4/2009 3:46 PM >
Shenlonco
Hide Signatures
(in reply to shenlonco)
       Post #: 70
RE: RC Tank F.A.Q. - 2/24/2009 9:23 PM
TrackmaintainerMike
Score: 100
Last Login: 4/3/2009
Status: offline
How does one get the cannon on a Heng Long 1/16 snow leopard more powerful?
Is there a spring mechanism, or is it air powered?
Mine is so weak, it won't even shoot through the paper target.
Hide Signatures
       Post #: 71
RE: RC Tank F.A.Q. - 2/24/2009 9:25 PM
TrackmaintainerMike
Score: 100
Status: offline
quote:
ORIGINAL: shenlonco
paint balls that work with your tanks they can be found on the web or on E-bay here
paint balls
Vedios showing paintballs breaking at 20ft they can break from over 30ft! and the Bio BB's exploding on impact leaving a white chalk like mark on another tank.
Paint ball testing
Great info to know.
The stock b.b.'s that came with my heng long are not that great.
Hide Signatures
       Post #: 72
RE: RC Tank F.A.Q. - 2/26/2009 8:57 PM
casey.glynn
Score: 100
Last Login: 2/26/2009
Status: offline
I have a H.L. panther tank. I am looking to replace the rear idler wheels. I saw your description on the site but im still foggy on how to remove the pressed in axel. mine looks diffrent than picture. thank you
Hide Signatures
       Post #: 73
RE: RC Tank F.A.Q. - 3/7/2009 4:45 AM
skitt
Score: 100
Last Login: 11/5/2009
Status: offline
Decided to add pics from the inside of a Walker Bulldog tank. May help someone else to see the layout before you open yours up
Skitt
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 74
RE: RC Tank F.A.Q. - 3/26/2009 12:02 AM
Icemaster2111
Score: 100
Last Login: 11/3/2009
Status: offline
Hello to all!
I'm doing some upgrades in my HL Tiger I, now i have recoil on the gun barrel and i hope can shoot using CO2 soon , the recoil it's
programmed under a lynxmotion Atom Mini Bot Board and a Bx24, soon i'll post photos to give new ideas to everybody
My questions are about motor and HL electronics...
I'm 99% sure that HL motors from factory are two 380, it's truth?
I want to change these motors for a pair of truck puller 2, i know these motors are bushless i'm rigth?
If these motors are brushless needs a speed controller so it's possible to keep the old control board without change the HL factory and use a speed controller? or exist a brushed high torque motor for this control board without burning the HL electronics at max speed? (I know exist some new boards like RX18 but i'm not interested)
A graupner 750 can burn HL electronics?
Thank you for all your answers
< Message edited by Icemaster2111 -- 3/26/2009 10:10 AM >
Hide Signatures
(in reply to skitt)
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.672RCU1
