Low idle RPM, car still rolling
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> HPI Racing >> HPI On-Road >> Low idle RPM, car still rolling
Page: [1]
Login
Low idle RPM, car still rolling - 4/25/2007 9:14:35 PM
RCar
Status: offline
My RS4 is equipped with the Nitro Star 18SS. The problem is that even though the RPM, when the car is idleing, are very low, the wheels just wont stop spinning. It just wants to go forward. If I lower the RPM even more, using the idle screw, it'll just die.
Why are the wheels spinning? Do I have it tuned the wrong way or something?
_____________________________
DAMN people, I’m stating facts here!!!
       Post #: 1
RE: Low idle RPM, car still rolling - 4/25/2007 9:25:10 PM
Foxy
Status: offline
Clutch springs need replacing. Prob got at least one broken one in there.
Milas ellinika pio aneta? Kane mou PM ama theleis...ta clutch elatiria omos einai sigoura to problima.
Foxy. RCU Car Forums Moderator.
"Artificial Intelligence is no match for genuine stupidity".
Check out my Large Scale Gas RC Car Vids... www.youtube.com/foxy4242
(in reply to RCar)
       Post #: 2
RE: Low idle RPM, car still rolling - 4/25/2007 10:04:51 PM
nitro_man
Status: offline
cheack ur idle trim
(in reply to Foxy)
       Post #: 3
RE: Low idle RPM, car still rolling - 4/25/2007 10:25:41 PM
Foxy
Status: offline
quote:
ORIGINAL: nitro_man
cheack ur idle trim
He's already said that with the idle set so low it stalls, the wheels still move, how can it be the idle trim? It's definitely the clutch. Can't be anything else.
Anyway, it's not a tuning issue.
(in reply to nitro_man)
       Post #: 4
RE: Low idle RPM, car still rolling - 4/26/2007 2:20:59 AM
HeLLsGoD
Status: offline
My guess is its his LSN, too lean will make it rev higher, no matter how you set your idle. Richen your LSN 1/4 and then let it run around the block for a minute to let the new settings kick-in. Let it idle and see if its still revs high and creeps up
Next would be the clutch then maybe an airleak.
- HPI RS4 - HPI sprint 2 -
Dream, Drive, Drift.
(in reply to Foxy)
       Post #: 5
RE: Low idle RPM, car still rolling - 4/26/2007 3:38:05 AM
magnus213
Status: offline
If the engine speed is low enough at idle, which I'm assuming it is, then it's a constant and the problem must lie somewhere between the crankshaft and the wheels. I second the clutch motion, check it out.
MIT 2011
HPI RS43 Evo, Micro
(in reply to HeLLsGoD)
       Post #: 6
RE: Low idle RPM, car still rolling - 4/26/2007 2:31:40 PM
IARacer
Status: offline
If the engine is actually idling, not revving, then it would be a clutch problem.
(in reply to magnus213)
       Post #: 7
RE: Low idle RPM, car still rolling - 4/26/2007 8:55:25 PM
RCar
Status: offline
One of the Clutch springs was just a bit looser than the other. I'm not sure if that would make such a big difference, but since I had a new set, I replaced everything.
Anyone has one of these?
Is this a good upgrade?
(in reply to IARacer)
       Post #: 8
RE: Low idle RPM, car still rolling - 4/26/2007 9:29:04 PM
IARacer
Status: offline
I had one of those on my Racer 2, didn't really like it, but it is easier to adjust when the clutch engages with it. I guess I just like having three clutch shoes, and I never really adjust my engagement time on my touring car.
(in reply to RCar)
       Post #: 9
RE: Low idle RPM, car still rolling - 4/27/2007 1:18:58 AM
HeLLsGoD
Status: offline
Yes its a good upgrade compared to the stock clutch shoes. Just set it to mid-point engagement (the middle hole). It made a big noticable difference compared to the stock clutch. Taking off feels alot tighter and launches your car like a missile
       Post #: 10
RE: Low idle RPM, car still rolling - 4/27/2007 1:30:10 AM
companykid91
Status: offline
check the throttle trim on the controller
       Post #: 11
RE: Low idle RPM, car still rolling - 4/27/2007 9:04:27 AM
Foxy
Status: offline
quote:
ORIGINAL: companykid91
If he is winding out the idle and the revs are dropping until it stalls (as he said), it's got nothing to do with trim. This has been suggested AND discounted earlier in this very thread.
So, you replaced the springs, the clutch shoes looked ok? Not too much build up of crap on the inside of the clutch bell? What happened then, was the problem resolved?
< Message edited by foxy42 -- 4/27/2007 10:17:08 AM >
(in reply to companykid91)
       Post #: 12
RE: Low idle RPM, car still rolling - 4/27/2007 2:41:44 PM
RCar
Status: offline
The clutch shoes looked just fine, but I thought since I opened everything up, I might as well replace them too. Like I said, one of the 2 springs was a bit loose. So before I install the new shoes/springs set, I squeezed the new springs to make them even tighter. I'll give it a try on Sunday at the track and update this thread.
(in reply to Foxy)
       Post #: 13
RE: Low idle RPM, car still rolling - 5/3/2007 3:21:24 AM
420Speedster
Status: offline
From reading his orginal post, this would be the logical thing to do. Even electric cars will roll with no throttle if the throttle trim isnt set right.
       Post #: 14
RE: Low idle RPM, car still rolling - 5/3/2007 5:20:15 AM
RCar
Status: offline
Sorry for not replying earlier. The problem was solved with the new springs. Now is very convenient. I can play with my idle rpm as much as I want and the car wont move unless I push the throttle. I guess every once in a while, those springs loose their power and must be replaced.
Thanks everyone
(in reply to 420Speedster)
       Post #: 15
RE: Low idle RPM, car still rolling - 5/3/2007 5:51:51 AM
HeLLsGoD
Status: offline
You should have bought a racing clutch instead, it will last you alot longer than the stock clutch and improve performance
(in reply to RCar)
       Post #: 16
RE: Low idle RPM, car still rolling - 5/3/2007 5:56:55 AM
