Sed. Freestyle/OS 70    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> Sed. Freestyle/OS 70 Page: [1]
Login
Sed. Freestyle/OS 70 - 2/23/2003 9:37 PM
Lusha
Score: 100
Last Login: 7/3/2009
Status: offline
Hi!
I'm setting up the Seduction Freestyle with an OS FS 70. I plan to install the tank at the CG. Will the engine work properly w/o adding a pump? I can imagine it will take a while to get it fired up with the long fuel lines but I intend to give it a try.
Hide Signatures
       Post #: 1
Sed. Freestyle/OS 70 - 2/24/2003 4:47 AM
BotleRocketWar
Score: 100
Last Login: 9/6/2003
Status: offline
You might want to shove the tank up to the firewall. There is a chance the O.S. .70 will work with the tank that far away (about 6-8 inches from the carb), but it will probably become a problem. The airplane was designed for the YS .63...
You're going to need a lot of weight in the tail of that thing. Hopefully you've built it with the battery in the tail. You will still need a couple ounces.
If you did not already fiberglass your wing joint, I would recommend that too...
_____________________________
Brian Richman
BotleRocketWar@Aol.Com
Hide Signatures
(in reply to Lusha)
       Post #: 2
Sed. Freestyle/OS 70 - 2/24/2003 5:12 AM
Lusha
Score: 100
Status: offline
Hi!
Thanks for the tip. I've got a 5 cell AA pack as far back as I could get it and it balances just fine. I did laminate the wing joint based on some hints I got here. Perhaps it would be wise to put the tank in the front. I don't think I will be able to notice the difference anyway.
Hide Signatures
(in reply to Lusha)
       Post #: 3
Sed. Freestyle/OS 70 - 2/24/2003 6:44 AM
BotleRocketWar
Score: 100
Status: offline
Sounds like you're all set... The engine might run fine where it is, I don't know. There has to be someone who has done this sort of thing with a 4 stroke...You might want to ask in the engine forum.
BTW, you're going to LOVE the Seduction!
Brian Richman
Hide Signatures
(in reply to Lusha)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.188RCU1
