Skyshark me-109G
Tower Hobbies
Logged in as Guest
  Printable Version
Top Flite P-51D Mustang - 1/5 RTC - ARF
Seller:  chase67
Details:   $750.00   |  11/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> Skyshark me-109G
Page: [1] 2 3   next >   >>
Login
Skyshark me-109G - 4/27/2007 7:57:47 PM
check6ii
Status: online
Hello gang, this is my 1st post here so please bear with me! I have a skyshark 109g kit and am about to start the build. I recently finished and put a few flights on my Aerotech p-47 razorback with the Brison 4.2 gasser and love everything about gas engines as opposed to glow. So back to skyshark-
I am kicking around powerplants for the kit, and was going to use either a ys91 or saito 100 that I have avail. Then I thought about going to gas and poss. using a Zenoah 20cc gasser or BME 90 (actually a supertigre 90 gas conversion). The Zenoah 20cc is the smallest gasser I know of. I noticed that a gasser will be considerably heavier than glow, and am vasillating about what engine to use. I tend to favor YS engines, but am so tired of the mess! I dont want electric either. I also plan on using a 3 blade prop. Any input is greatly appreciated.
Horrido!
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: Skyshark me-109G - 4/27/2007 8:02:43 PM
Hellcat716
Status: offline
I would use the YS 91. The Zenoah would take a lot of cutting to fit in the cowl. I used a Saito 100 in mine and has plenty of power.
(in reply to check6ii)
       Post #: 2
RE: Skyshark me-109G - 4/27/2007 8:05:57 PM
check6ii
Status: online
I hear you. Im pretty sure a ys91 with a Slimline muff. will fit mostly inside the cowl too. I have that setup in my TF 190d9, and it has flown well for nearly 6 yrs now.
Click for fullsize
(in reply to Hellcat716)
       Post #: 3
RE: Skyshark me-109G - 5/9/2007 4:00:54 AM
check6ii
Status: online
So after 4 hrs of time, I have assembled the rudder, elevators, ailerons, stab(sheeted and shaped), and spent about 1 hr. on the wing center section and part of right wing. Haupt. Marseille is keeping a watchful eye......
Click for fullsize
       Post #: 4
RE: Skyshark me-109G - 5/9/2007 4:31:53 AM
camdyson
Status: offline
I've got an RCV 1.20 waiting to go in mine - will be totally enclosed and spin a nice big prop (even a big 3-blade!). Other than a bit of ducting work inside the cowl to aid cooling, it looks like it will fit nicely with no un-scale protruberances.
I HATE seeing rocker covers, mufflers and spark leads dangling out of the noses of warbirds! No offence anyone - practicality must come first I know.
Food for thought. Looking forward to this build - hopefully will get me motivated to get mine on the board.
Cheers,
Cam
       Post #: 5
RE: Skyshark me-109G - 5/18/2007 4:13:58 AM
check6ii
Status: online
Here is an update on the build-
So far I have completed the left outboard portion of the wing. There were a couple of parts of the build of that part that were somewhat vague, and required some re-reading of the instructions. But all in all, things are going well-albeit the pace has slowed a little. Here are a couple of pics.......
Kev
Click for fullsize
Click for fullsize
       Post #: 6
RE: Skyshark me-109G - 5/18/2007 3:35:02 PM
Jagdfleiger
Status: offline
Cam,
Got a question for you. I have a Skyshark 109G waiting in the wings (so to speak). I am finishing up on my 1/6th 190D at the moment. I also have an RCV 1.20 that I plan on putting in my 190D. Because of the anular radiator in the front of the cowl, cooling for the RCV 1.20 should not be a problem if I ensure proper airflow out. With a 109, thats a different matter. I think its the perfect engine for it if there were some way to cool it but, I don't know how to approach it. How did you plan on providing proper airflow for it in your 109?
_____________________________
Rob Johnson
"....I've been shot at, I've been shot up, but I havn't been shot down...."
       Post #: 7
RE: Skyshark me-109G - 5/18/2007 3:44:37 PM
SCALECRAFT
Status: offline
Hi
Just for the 109 fans.
Our all composite 49" span 109F.
Cooling. You have two points of intake, the oil cooler and the supercharger intake. to exit hot air, the back of the oil cooler. The trick is the fly on cool days and direct the air flow around your enigne.
Steve
Click for fullsize
(in reply to Jagdfleiger)
       Post #: 8
RE: Skyshark me-109G - 5/18/2007 4:56:54 PM
Tommy_Gun
Status: offline
Suggestion for the aileron servos.
DO NOT USE karbonite gears!! I have had three HS475HB servos fail in the gear train on this particular plane.
It really sucks when you are forced to land holding opposite rudder because an aileron servo jammed in a position other than neutral.
Yeeeeahhh seee.
Say hello to my leetle fren.
(in reply to SCALECRAFT)
       Post #: 9
RE: Skyshark me-109G - 3/19/2008 2:09:26 AM
check6ii
Status: online
quote:
ORIGINAL: SCALECRAFT
Hi
Steve
Steve, how did you do the "14" on your plane?
       Post #: 10
RE: Skyshark me-109G - 3/20/2008 7:59:57 PM
NoFlaps
Status: offline
hey Check6ii,
I found that the FPE 21cc is just a hare more powerful than the G20, and is actually a lil' smaller.
I haven't been able to get my hands on the BME 90, but if you look at my SIG P-51B ARF thread, I've got the FPE mounted in there.
Keep us posted...I've wanted to build this 109 with a gasser too.
Any landing you can walk away from is a good one.
       Post #: 11
RE: Skyshark me-109G - 3/21/2008 12:00:15 AM
wulf190
Status: offline
An ST .75 2 stroke does a nice job the plane I've found. Nice flying airplane, and a great plane to build. The ailerons and flaps won't match up at the joint b/n them because of the washout in the wing. Don't worry about it, doesn't affect flying traits whatsoever.
Click for fullsize
Click for fullsize
(in reply to NoFlaps)
       Post #: 12
RE: Skyshark me-109G - 3/21/2008 2:01:53 AM
check6ii
Status: online
quote:
ORIGINAL: NoFlaps
hey Check6ii,
WHOA! The BME 90 SuperTigre puts out a whopping 2.7 h.p.!!!!!!! Thats waaaaaay to much for the Skyshark 109G isnt it? I looked up the FPE and its expensive, but since its smaller than the Zenoah, its a better fit I think.
What do you think? Im leaning toward the FPE
I finished sheeting the wing this a.m.
       Post #: 13
RE: Skyshark me-109G - 3/21/2008 3:57:13 PM
