THE a123 charger
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> A123Racing Support >> THE a123 charger
Page: [1]
Login
THE a123 charger - 4/29/2007 8:48:18 AM
ramboman
Status: offline
Keep it simple and stupid!
Strictly following a123 specifications:
- buy a CCCV power unit (I use a 20amps 50volts from Tanic)
- set max current to 3amps per cell (or 10amp for fast charge)
- set max voltage to 3.6volts per cell
Just wait...
For my 10s2p I set it to 20amps 36volts for fast charge,
there is no alternative!
       Post #: 1
RE: THE a123 charger - 4/29/2007 9:55:38 AM
jasonwang3a
Status: offline
you are right, any lithium battery is dangerous with charging in wrong charge mode.
nimh and nicd battery is charged with CC, Lithium ion , lipoly , liFEPO4, lead acid or VRLA battery is charged with CC and then CV. Different electrochemical system has different charging mode...
_____________________________
Jason
(in reply to ramboman)
       Post #: 2
RE: THE a123 charger - 9/10/2007 12:06:37 AM
Ionikios
Status: offline
Is the LiFePO4 as critical as the other lithium batteries as far as fire or explosion danger?
I'm sitting up 6-RCR123As - (LiFePO4) -series parallel to 6V and using a 6v reg. for safety measure as Rx batt. setup and haven't seen any around. Will that work ok?
< Message edited by Ionikios -- 9/10/2007 12:09:20 AM >
(in reply to jasonwang3a)
       Post #: 3
RE: THE a123 charger - 10/15/2007 10:32:48 PM
skyrider2
Status: offline
Ionikios,
Sounds to me like you are building a 2S3P A123 battery pack. The A123 cell is rated 2.3 volts and 2300 mah. Doing the math (three parallel strings of 2 series cells) that's 6.6 volts at 6900 ampere hours. That's an awful lot of power for a receiver. Most are using just 2S1P for the receiver.
Remember, most receiver batteries that come with radio systems are 500-600 mah NiCad or NiMh packs.
skyrider2
< Message edited by skyrider2 -- 10/15/2007 10:36:09 PM >
(in reply to Ionikios)
       Post #: 4
RE: THE a123 charger - 10/15/2007 11:42:19 PM
Red Scholefield
Status: offline
quote:
ORIGINAL: Ionikios
So far than been no reported incidents with A123 technolgy.
Red S. AMA 951
R/C Battery Clinic
www.rcbatteryclinic.com
       Post #: 5
RE: THE a123 charger - 10/18/2007 1:06:02 AM
everydayflyer
Status: offline
As preveous post stated a 2S A123 is all that is needed for a receiver / servos power.
2300 mAh , more amps than 10 digital sevos can use and no regulator required as voltage will be very close to the same as a 5 cell Ni pack.
Charles
(in reply to Red Scholefield)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.344RCU1
