RCV 120 static thrust?
Tower Hobbies
Logged in as Guest
  Printable Version
90 Degree Muffler Adapter
Seller:  RC Specialties
Details:   $17.95   |  5/19/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> RCV Engines Support >> RCV 120 static thrust?
Page: [1]
Login
RCV 120 static thrust? - 4/29/2007 1:59:04 PM
Captain_YAK
Status: offline
Hi all!
I am considering a RCV SP 120 or an RCV SP 90 for a 72 inch warbird estimated finished weight will be 10 - 10.5 lbs
Has any one done any tests on static thrust on these engines?
Any information apreciated.
Captain_Yak!
       Post #: 1
RE: RCV 120 static thrust? - 5/1/2007 12:38:00 PM
RCV Engines
Status: offline
Hi
We have tested a SP90 which will give a static thrust of around 8-8.5 lbs. These tests were carried out using a 18 x 12 two bladed APC prop. A SP120 would be slightly too large for this application.
I hope this helps.
Best regards
Stephanie
_____________________________
Technical Support
RCV Engines - UK
(in reply to Captain_YAK)
       Post #: 2
RE: RCV 120 static thrust? - 5/2/2007 12:23:24 PM
Captain_YAK
Status: offline
Thanks Stephanie!
Since I am looking for a 1:1 (Or there abouts) Thrust to weight ratio the 120 with a 3 blade prop should workout great (Scale size is close to 15 inch 3 blade) . The IL-2 I am building will cary external dumy "Drop bombs" so the additional thrust should be handy!
Regards
Captain_Yak
(in reply to RCV Engines)
       Post #: 3
RE: RCV 120 static thrust? - 4/1/2008 3:56:41 AM
IL2windhawk
Status: offline
quote:
ORIGINAL: RCV Engines
Hi
This is good information.
Do you have any similar information regarding performance with a 3-blade propellor?
Fly War-Clouds.com
IL2//Pacific Fighters Full-Real WWII Air Combat Server
       Post #: 4
RE: RCV 120 static thrust? - 4/1/2008 12:36:48 PM
Captain_YAK
Status: offline
I used a 3 Blade prop APC it was 15.75x13 pitch and the thrust was 9 - 9.5 lbs @ 5800 RPM .......... not enough to fly the IL2 (Came out at 11.5 lb) runway is not long enough.
I then used a 18x12 2blade and the thrust was 9 lbs but the speed was just enough for take off ..........
Hope this helps
Captain_Yak
(in reply to IL2windhawk)
       Post #: 5
RE: RCV 120 static thrust? - 4/1/2008 3:49:59 PM
Tripower455
Status: offline
I have never measured the static thrust of my 120SP, but I have been flying my CMP Zero (71" span, 13 lbs) for over a year with it.
It pulls it around great. I've used the 15.75 x 13, 3 blade which turns about 4800-5000 and a 17x13 2 blade which spins a smidge faster.
It pulls this heavy thing around at well over scale speed, and has plenty of power for big loops. I usually use the 2 blade as they are cheaper, but the 3 blade flew it the same.
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.441RCU1
