Li-Poly PACKS!!!
Tower Hobbies
Logged in as Guest
  Printable Version
Miniature Aircraft USA Ion-X - RTF
Seller:  1surfer
Details:   $5,000.00   |  10/5/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Electric RC Helis >> Li-Poly PACKS!!!
Page: <<   < prev  1 [2] 3   next >   >>
Login
Li-Poly PACKS!!! - 3/3/2003 7:49:21 AM
moos4bkfst
Status: offline
I bought them from [url]www.nwhobbies.com,[/url] I dont think there on the sight yet, but you can call them, they have some in stock, either go for the 880mah or the 1020 mah. They will build them for you free of charger,they work far better than nimh and alot lighter........ Ill try to post a link with the batteries.
_____________________________
"It's not a toy, It's a HOBBY"
(in reply to lvjax)
       Post #: 26
Century Hummingbird - 3/3/2003 8:36:25 AM
imeins
Status: offline
Steve: I am getting about 9-10 minutes on my 600mA/H packs as shipped with the Feda/HummingBird. All stock standard. I was playing in the wind this morning and almost dumped the Feda on it's side on the asphalt road. Blades hit the deck. Went over had a look and kept flying. Last night I hit a bookshelf (and almost cleaned up the wifes $x,000 crystal collection!) again it just went plop on the floor and I moved it to a clear spot and kept flying. Pretty tough..
Ingmar
(in reply to lvjax)
       Post #: 27
Century Hummingbird - 3/3/2003 4:24:13 PM
Hoverup
Status: offline
Ingmar - the heli may be tough, but if you break your wife's crystal you better be tougher. I am grounded from flying in any room but my home office and work shop unless I want to spend all my money on a solicitor instead of e-helis.
Cheers - Boyd
AMA 80393
Major - USAF
Retired
A night mission in the entertainment center room.............
Click to see fullsize image.
Click for fullsize
(in reply to lvjax)
       Post #: 28
Century Hummingbird - 3/3/2003 8:52:35 PM
deus1978
Status: offline
Moos,
What type of charger are you using for your Poly packs and how long does it take to charge? I'm new at Poly technology, I use aTekin digital charger for my NiMH... I doubt it will be able to charge the newer stuff.
Randal
(in reply to lvjax)
       Post #: 29
Century Hummingbird - 3/4/2003 7:05:19 AM
imeins
Status: offline
Boyd: the wife did mutter something under her breath, I think it was an ancient Finnish curse or something. I don't intend to repeat that performance in a hurry, at least not with her in the same room.
Ingmar
(in reply to lvjax)
       Post #: 30
Century Hummingbird - 3/4/2003 8:09:46 AM
skylark_man
Status: offline
what should i do if my training gear is shakeing on my skylark when i get off the ground. does anyone know what to do and its made out of wooden dowels please help.
(in reply to lvjax)
       Post #: 31
Century Hummingbird - 3/4/2003 12:50:12 PM
imeins
Status: offline
You could try the balancing I did.
http://www.rcgroups.com/forums/showthread.php?s=&threadid=96539
Ingmar
(in reply to lvjax)
       Post #: 32
NEEDED: Tips to set up the CSM HLG 200 HH gyro - 3/6/2003 9:01:07 PM
BriMan
Status: offline
Hoverup...
Could you provide some details around the proper setup on the CSM HLG 200 HH gyro?
I utilized your configuration and ordered similar parts for my Hummingbird. Looking to utilize your applied knoledge for this setup.
THANKS...
Brian
(in reply to lvjax)
       Post #: 33
Century Hummingbird - 3/7/2003 12:00:22 AM
Hoverup
Status: offline
Component layout on my HummingBird.
Click for fullsize
(in reply to lvjax)
       Post #: 34
Century Hummingbird - 3/7/2003 12:02:40 AM
Hoverup
Status: offline
Another pic without the callout labels.
Click for fullsize
< Message edited by Hoverup -- Mar 6 2003 7:09PM >
(in reply to lvjax)
       Post #: 35
Century Hummingbird - 3/7/2003 12:48:54 AM
Hoverup
Status: offline
Go here for hookup: http://www.pgoelz.com/piccolo_wiring_01.html
Where the diagram shows a BL motor controller just substitute the GWS main motor controller.
Cheers - Boyd
< Message edited by Hoverup -- Mar 7 2003 5:50AM >
(in reply to lvjax)
       Post #: 36
Century Hummingbird - 3/7/2003 7:05:31 AM
skylark_man
Status: offline
does anyone know what is wrong when i balanced my skylark and it still wobles when its in the air and how do i balance the main blades when they are free to twist, how would do it? and if the battery wasnt super solidly atached to the helicopter would it wobble because of that? Thanks.
(in reply to lvjax)
       Post #: 37
Century Hummingbird - 3/7/2003 7:21:14 AM
imeins
Status: offline
Have a look at my balancing photos. http://www.rcgroups.com/forums/showthread.php?threadid=96539
It's possible that if the battery is really loose then it could start shaking , making the wobble worse etc etc..
Ingmar
(in reply to lvjax)
       Post #: 38
HUMMINGBIRD ORDERED - 3/8/2003 2:06:51 AM
BriMan
Status: offline
Just wanted to give a big thanks to you all. I was able to aquire an abundance of information on these forums and finally placed my order.
FYI: These Helis are in high demand and are a bit hard to find!!!
Jeremy over at NorthWest Hobbies ( [url]www.nwhobbies.com[/url]) still had a kit and a combo in stock. Jeremy is a pleasure to work with and provided an excellent deal to get me started!!! You would be making a wise choice giving him a call if you are in the market for a heli.
NEXTUP:
Assembly and 1st flight!! I can't wait...
Thanks Again...
Brian
(in reply to lvjax)
       Post #: 39
Century Hummingbird - 3/8/2003 8:51:26 PM
