RE: What pipe?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> RE: What pipe?
Page: <<   < prev  1 2 [3]
Login
RE: What pipe? - 5/5/2007 10:31:03 PM
JB COMP
Status: offline
I don't how much you like dealing with ebay, but you can find a JP-2 on ebay for around $35-$55 for one new or used a little.
_____________________________
LX Comp: STS21B, JP-3, DX3.0 - CRT: STS 30 Rev2 or Mach 427, STS 0702, DX3.0 - T-maxx: TRX2.5
Airtronics. BlueBird.
(in reply to dbuggyracer )
       Post #: 51
RE: What pipe? - 5/6/2007 2:30:05 AM
jelly bean
Status: offline
alright and the jp2 has good mid to top end power?
Cars
ofna mbx 9.5 axial .28 spec 1s with jr ST126MG, venom minigiant with all venom mods, greatplanes slinger airplane
(in reply to JB COMP)
       Post #: 52
RE: What pipe? - 5/6/2007 3:36:47 AM
JB COMP
Status: offline
yes the JP-2 gives mid-top with out taking away bottom end, and I heard (don't know if this is true but I heard it) that the JP-2 gives the same bottom as the JP-1 and has more mid-top. like I said don't know if its true that just what I heard. so please nobody get mad if this wrong.
(in reply to jelly bean)
       Post #: 53
RE: What pipe? - 5/6/2007 2:40:12 PM
jelly bean
Status: offline
alright so i guess ill look for either a jp2 or a 086.
Cars
       Post #: 54
RE: What pipe? - 5/6/2007 9:25:34 PM
jelly bean
Status: offline
i ordered those big blocks tires off ebay so now all i have to do is sell my boat so i can afford a pipe.
Cars
       Post #: 55
RE: What pipe? - 5/6/2007 9:48:08 PM
jonnymac
Status: offline
Whats going on mate? I'm sure you started this thread looking for a low end pipe? You've decided to get a high end one now?
You really need to think where your engine makes its power and enhance that and gear to suit is what I say.
What engine was it again?
Xray XB8 TQ, Hyper 7 TQ, Monster GT
       Post #: 56
RE: What pipe? - 5/6/2007 10:14:18 PM
jelly bean
Status: offline
axial .28 spec 1s.
Cars
(in reply to jonnymac)
       Post #: 57
RE: What pipe? - 5/6/2007 10:24:09 PM
JB COMP
Status: offline
quote:
ORIGINAL: jonnymac
What he can't change his mind???? if he was forsure he was going with a low end pipe he wouldn't need to ask what pipe then.
the peak power on that engine is up past 22,000 rpms, so I don't thank a low end pipe would be that good on that engine, and if he runs on/ or the track he runs on changes to a more open track then he has to buy another pipe, or he can a mid-top end pipe that will work great with that engine and then put a smaller CB for a tight track and then if he runs on a more open track then all he has to do is get a bigger CB and put on there and he's good to go.
       Post #: 58
RE: What pipe? - 5/6/2007 10:39:18 PM
jelly bean
Status: offline
i think jonnymac was kidding, but yes i also changed my choice to a mid-top end pipe because someone that has the engine i have said it has plenty of bottom end to run a top end pipe.
Cars
       Post #: 59
RE: What pipe? - 5/6/2007 10:52:05 PM
JB COMP
Status: offline
jelly bean if you more power than that engine has (which I don't thank that will be soon but when that time comes) you might want to look in to the STS 28 and 30. or if theres somone that that you just can't beat then just get the STS 30, and a 16-18 tooth CB and smoke them.
the STS 28 is about the same price, and I thank is might be a little bit cheaper.
The STS 30 is a little bit more but not much.
       Post #: 60
RE: What pipe? - 5/7/2007 12:24:08 AM
jelly bean
Status: offline
alright thanks, i think i might need a new piston and sleeve i was running it in dusty conditions and somehow it got some dirt in the throat of the carb so i gotta pull it apart and hope that nothing got to the piston and sleeve yet.
Cars
       Post #: 61
RE: What pipe? - 5/7/2007 3:23:34 AM
JB COMP
Status: offline
yeh I know that feeling. Once I was running mine in the backyard and the air filter popped off, and had to pull the hole engine apart and clean it, but I saw it quick anouph no dirt got in the piston/sleeve. so no damage done, hope the same for you, and no damage done to yours either.
       Post #: 62
RE: What pipe? - 5/7/2007 8:02:22 PM
jelly bean
Status: offline
i think it ruined the piston and sleeve because when it gets hot it gets really hot and the engine shuts off even though its still got 1/4 of a tank of gas left. and this is what happened to my old stock ofna engine with the same airfilter so i think this airfilter is junk. i can get a new piston and sleeve off ebay for 38.00 though so i think im gonna get that and a new airfilter and then save up more for a pipe again.
Cars
       Post #: 63
RE: What pipe? - 5/7/2007 9:44:30 PM
JB COMP
Status: offline
for a airfilter get the Jammin 2-stege filter, and then get a small hose clamp and clamp the air filter to the carb to keep it from coming off.
       Post #: 64
RE: What pipe? - 5/7/2007 11:05:59 PM
jelly bean
Status: offline
alright ill probably get that if its a good one then. and im not sure if im still gonna be able to get a pipe soon.
Cars
