RE: Precision Aerobatics Katana MD Build and Fly
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> RE: Precision Aerobatics Katana MD Build and Fly
Page: <<   < prev  9 10 [11] 12 13 14 15 16 17 18   next >   >>
Login
RE: Precision Aerobatics Katana MD Build and Fly - 10/19/2007 9:31:28 PM
itai
Status: offline
Hey guys,
Here is a video of my katana md from yesterday
Tell me what you guys think!
http://rcuvideos.com/item/55FXLBYHYVMFQLF2
thanks
itai
Click to see fullsize image.
Click for fullsize
(in reply to aflipz)
       Post #: 251
RE: Precision Aerobatics Katana MD Build and Fly - 10/20/2007 5:58:45 AM
aflipz
Status: offline
Sweet vid itai, great flying and nice inverted flatspin!
(in reply to itai)
       Post #: 252
RE: Precision Aerobatics Katana MD Build and Fly - 10/21/2007 2:04:35 AM
vasmikey
Status: offline
Hey, just a little caution to those who have built the KatanaMD. Awesome plane and build, but my pull/pull servo arm broke out on one side during flight. No worries since it's pretty easy to land w/o the rudder, given it didnt stick to one side with a lot of force. Just keep a close eye on the integrity of the carbon/fiber control parts for weakness that's all. Because of my constant radical use of the rudder lately, I went with the nylon horn for the pull/pull and sleeping alot better.
       Post #: 253
RE: Precision Aerobatics Katana MD Build and Fly - 10/21/2007 3:09:41 AM
aflipz
Status: offline
there is some offset built into the cf double arm (pull pull) replacing this with a straight unit is said to be detrimental to performance.
That being said i have been running straight nylon since the very beginning mostly because i can optimize arm length so that full deflection = maximum over-atv. This maximizes torque and resolution.
(in reply to vasmikey)
       Post #: 254
RE: Precision Aerobatics Katana MD Build and Fly - 10/22/2007 5:59:30 PM
Scoubidou
Status: offline
What kind of receiver are you running guys? I fly JR and is this one too small for the Katana?
http://www.horizonhobby.com/Cart/ViewCart.aspx?TotalItemsAdded=1
_____________________________
Seneca Engineering
http://www.seneca.ca/
       Post #: 255
RE: Precision Aerobatics Katana MD Build and Fly - 10/22/2007 6:42:49 PM
Jeff_edge540
Status: offline
I am sorry to report that my Katana MD lasted only 4 flights...
I made two mistakes:
1) ignored a poor range check (getting glitches at about 20 paces) but I thought I wouldn't fly very far..
2) ignored the instructions to route the antenna across the wing - i ran it down the fuse.
I was using a Berg 7 and got radio lockout when up high in a flat spin. It spun into the ground. The cost of this ARF makes that a hard one to swallow. I'm not sure I will be replacing it until I go to 2.4ghz.
I just didn't see how to route the antenna down the wing when the wings are removable. I would have to either tape it down everytime or cut the antenna and use a bullet connector or something - neither were a good option IMHO.
But I paid the ultimate price for my lazyness and lack of good judgment.
(in reply to Scoubidou)
       Post #: 256
RE: Precision Aerobatics Katana MD Build and Fly - 10/22/2007 9:16:04 PM
albo752004
Status: offline
Hi Jeff
Very sorry to hear about your KMD, I must admit I found the antenna placement under the
wing to be a serious nusiance and opted to run it below the fuse. To date I have not experienced any noticable radio hits, and my range check was within acceptable limits.
I'm using a FMA Direct Encore reciever, I just looked at the berg 7 specs on the Inet
and it is definitely a top notch unit. Can't say why you experienced such a serious problem.
Hope you won't give up on the KMD it is truly an awesome aircraft.
Allen
(in reply to Jeff_edge540)
       Post #: 257
RE: Precision Aerobatics Katana MD Build and Fly - 10/22/2007 10:48:35 PM
Valve floater
Status: offline
Guys, i use an old electron 7. The little weight difference has no effect to me. Flies great. I have mine running in the fuse. I like a clean look. I have it exiting the fuse with 1/2 tail hotglued. Also hotglue throught the fuse with dots of hot glue to keep it away from the pull pull string. Not one problem in 80 flights. I like to have the ability to fly high as a dot if i feel the urge. Never had a glitch. Channel 34.
Full throttle at Full deflection, or stay home!
(in reply to albo752004)
       Post #: 258
RE: Precision Aerobatics Katana MD Build and Fly - 10/22/2007 10:55:41 PM
Greg Cothern
Status: offline
I am flying my Katana MD with a Berg RX and ran the antenna through the fuse and have had not a single glitch at all. The Berg is supposed to be a full range RX so I dont think one would have to do the under the wing trick, I feel that was probably suggested more for the shorter range RX's.
Sorry to hear of the demise of your Katana...
Some of the products I like
Smart-Fly Hangar 9 Wild Hare MVVS & DA Engine''s Futaba Radio Hitec Digital Servo''s
       Post #: 259
RE: Precision Aerobatics Katana MD Build and Fly - 10/23/2007 1:01:09 AM
aflipz
Status: offline
I have 3 berg 7p's 2 with vertical pins and one with horisontal pins. My first Katana MD had countless flights on it and i had never seen a glitch on it's vertical pinned 7P until it "died" in flight destroying my beloved MD (you can see images of the wreckage at the end of my last video)
Another one proving Murphy was right; whatever can go wrong...
Scoubidou; your link points to a shopping cart that was a temporary link; we can't see the item you had selected, to us it's just a message telling us our shopping cart at horizon hobby is empty. Just tell us the model number so we can share our views on it.
There is no such thing as too small though; just range... a berg microstamp 4L weighing less than 4 grams would be more than enough range for the Katana MD even with a shortened antenna (you do need 6ch for mixing so i won't recomend the 4L in the MD, i am just making a point)
(in reply to Greg Cothern)
       Post #: 260
RE: Precision Aerobatics Katana MD Build and Fly - 10/23/2007 12:43:15 PM
Scoubidou
Status: offline
I have already used the JR #JSP30610, 6-Channel UL Receiver w/o Crystal,POS Shift,JR/Air on a foamy without any glitch but i do not know if i could use it on bigger electric plane like the Katana MD ?
Daniel
Click for fullsize
Seneca Engineering
       Post #: 261
RE: Precision Aerobatics Katana MD Build and Fly - 10/23/2007 7:06:57 PM
itai
Status: offline
i think it will be ok.
but you need to have a rang check after the plane is done.
you can read few pages back that i changed my Receiver to Berg 7P 7Ch after i did a rang check.
       Post #: 262
RE: Precision Aerobatics Katana MD Build and Fly - 10/24/2007 12:08:29 AM
aflipz
Status: offline
Scoob, i have never used that rx and i can't find any info on it's actual range, i did see someone post about using it in a sailplane about as far as he could see it. If it range checks in the MD i'd go ahead and use it.
(in reply to itai)
       Post #: 263
RE: Precision Aerobatics Katana MD Build and Fly - 11/12/2007 8:25:01 PM
Born2Fly
Status: offline
quote:
ORIGINAL: itai
Almost finished,
My weight is 1007gr 35.5oz
Where did you guys take out the antenna from? Pictures please
Hi,
Is it with or without battery?
Thanks.
(in reply to itai)
