aflipz
QC, CANADA Status: offline
Thanks! I use a PA thrust 30 with a castle creations phoenix 45. but Pa has a combo that is well worth it if you are buying all new and order an arf from them at the same time. This is the best way to go i think. Of course if you have a quality 40A or better esc with a 3A or greater bec you might as well use it. Other motors used: extreme flight rc torque 2818/900 apache apm30-18t There isn't much else in that KV, power and weight class out there, some heavier motors with higher kv will give more power but they will either tax the power system more or require propping down. The eflite power 10 for instance, it works but it takes something away from the intended overall balance of the plane. Power, flight time, weight, performance. Don't worry! with a quality 15C 2100 mah lipo and a 12x6 you will be getting unlimited vertical. For the pack, i feel since peak loads are roughly 30A on the recomended motor there is no better power and capacity to weight match for this plane than the thunder power 2100 pro lite. Unless you plan on using a 13x6.5 and using wot for extended periods or have something else similar on hand already. Of course, if you plan on using your packs on someting that requires more power i guess the compromise for heavier higher C rating packs will do.
