Greg Cothern
TX, USA Status: offline
HI I have a Thrust 30 and Quantum 40 amp ESC from you about late June or early July last year, along with 373 metal gear servo's for my PA Katana MD. I have about 35-40 flights on the combination, after the 4 or 5 th flight one of the servo's stripped a gear, figure oh I must have bumped it or something. SINCE then I have had to replace another 3 servo gear sets OR the entire servo due to the fact IT is completely unacceptable for servo's to strip while in normal flight!!!!!! YEP I have quadriple checked to make sure NOTHING is binding that could cause a problem. I have since had a servo CASE crack, YEP case has separated and spreading apart thus allowing the gears to no longer mesh properly. I finally replaced with HITEC 65's and not a single problem whatsoever in the past 15 flights, equal or longer than ANY of the previous # of flights on the SAME surface, SAME radio setup, SAME type flights... HITEC is as smooth as silk and tight as the day I pulled it out of the box, the 373 mg's have an incredible amount of slop in the gear train and or broken cases. I am NOT happy at all with the 373's and unfortunately will NEVER buy another one. SORRY but completely unacceptable servo for this application, maybe for a indoor slow fly foamy.. NOW the ESC has for some unexplained reason went up in SMOKE. SAME 2100 11.1v LiPo packs I have flown in it since the combination arrived, they show to be completely normal and perfect packs, NEVER a problem with them. AGAIN no binding, no hard abusive long runs, only depleteing packs about 50-60% of MAH ratings. I fly slower speeds with some minor 3D flight, basically some inverted spins, harrier, and 20-30 second hovering flight at safe altitudes. Rest of the time is spent performing touch and goes and learning rolling circles. Most of my flights last about 7-9 minutes. MUCH less aggressive flights than shown on PA videos. OH 12.6 prop that was ordered WITH the motor, ESC, and prop adapter that was recommended for this setup. With this all said, I must say I REALLY like the Katana MD and Thrust 30, I even plan to purchase another motor/esc (assuming my esc issue was a FLUKE) combo for the PA Extra 260 that I am going to buy in a few weeks
_____________________________
Some of the products I like Smart-Fly Hangar 9 Wild Hare MVVS & DA Engine''s Futaba Radio Hitec Digital Servo''s
