RE: Precision Aerobatics Katana MD Build and Fly
Tower Hobbies
Logged in as Guest
Users viewing this topic: Rudder Dragger
  Printable Version
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> RE: Precision Aerobatics Katana MD Build and Fly
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Precision Aerobatics Katana MD Build and Fly - 5/17/2007 4:05:43 AM
aerofundan
Status: offline
awesome mod on the tail wheel! i love that tail wheel setup you got!
_____________________________
Daniel Dominguez
http://www.aerofun3d.com/videos/
(in reply to 3D-Flyer Kevin)
       Post #: 26
RE: Precision Aerobatics Katana MD Build and Fly - 5/17/2007 12:53:10 PM
itai
Status: offline
Thanks Daniel
itai
(in reply to aerofundan)
       Post #: 27
RE: Precision Aerobatics Katana MD Build and Fly - 5/20/2007 2:56:48 PM
itai
Status: offline
Installed the motor box
Click to see fullsize image.
Click for fullsize
(in reply to itai)
       Post #: 28
RE: Precision Aerobatics Katana MD Build and Fly - 5/20/2007 3:10:32 PM
JamieKerr
Status: offline
Yea I have to say out of all the 3D planes I have seen that one def looks the nicest. Looks good and I exspect will perform good 2 so great choice.
Jk
SPONSERD BY.........................NO ONE.
(in reply to itai)
       Post #: 29
RE: Precision Aerobatics Katana MD Build and Fly - 5/20/2007 6:37:58 PM
itai
Status: offline
I glued the aileron control horns in place using epoxy, fits perfectly into their slots
so did the rudder control horn and the elevator horn.
then i cut the supplied air scoops, glued them to the sides of the motor box using CA
to improve cooling and airflow to the motor
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to JamieKerr)
       Post #: 30
RE: Precision Aerobatics Katana MD Build and Fly - 5/23/2007 3:26:06 PM
itai
Status: offline
These are the servos that I am using
Futaba S3110 Micro High Torq Servo 7.7g
SPECS: Length: 0.9" (21.8mm)
( Width: 0.4" (11mm
Height: 0.8" (19.8mm)
(Weight: .27oz (7.7g
Speed @ 4.8V: .10 sec/60°
Torque @ 4.8V: 22 oz-in
The pull pull carbon fiber servo arm is supplied, and the other CF servo arms are extra, got them from PA.
I installed all the servo arms on the servos with small screws
Click for fullsize
(in reply to itai)
       Post #: 31
RE: Precision Aerobatics Katana MD Build and Fly - 5/23/2007 4:19:53 PM
OneHump
Status: offline
Hey this is a great thread. I appreciate the build photos you're putting up. Keep em going!
       Post #: 32
RE: Precision Aerobatics Katana MD Build and Fly - 5/23/2007 7:22:37 PM
itai
Status: offline
Thanks i will try to do that.
itai
(in reply to OneHump)
       Post #: 33
RE: Precision Aerobatics Katana MD Build and Fly - 5/24/2007 6:38:26 PM
itai
Status: offline
I decided to use Dubro Mini E/Z Connector instead of using the
supplied z- bends. I enlarged the hole to 2mm, closer to the bottom so I will still have
some thread left for the screws.( Dubro has Lightweight aluminum E/Z connectors
I will change these when they arrive)
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to itai)
       Post #: 34
RE: Precision Aerobatics Katana MD Build and Fly - 5/25/2007 8:20:04 AM
itai
Status: offline
Got the ailerons servo installed. Connected the carbon fiber pushrod. Inserted
the z-bend to the horn, and the Mini E/Z Connector to the CF servo arm.
Click for fullsize
Click for fullsize
(in reply to itai)
       Post #: 35
RE: Precision Aerobatics Katana MD Build and Fly - 5/25/2007 10:02:37 AM
gdm
Status: offline
keep it going i will build mine this weekend and if weather is good give you a flight report
this is one nice plane!
(in reply to itai)
       Post #: 36
RE: Precision Aerobatics Katana MD Build and Fly - 5/25/2007 12:47:17 PM
itai
Status: offline
Got the rudder servo in place, and the pull pull system all done.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to gdm)
       Post #: 37
RE: Precision Aerobatics Katana MD Build and Fly - 5/25/2007 7:18:47 PM
itai
Status: offline
Elevator servo and carbon fiber pushrod.
Click for fullsize
Click for fullsize
(in reply to itai)
       Post #: 38
RE: Precision Aerobatics Katana MD Build and Fly - 5/25/2007 7:44:59 PM
itai
Status: offline
Precision Aerobatics Thrust 30
PA 5mm Prop adapter
Apc 12X6E prop
1.5" e spinner
1.5" dubro plastic spinner
Still did not decide which spinner to use
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to itai)
