RE: Precision Aerobatics Katana MD Build and Fly
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> RE: Precision Aerobatics Katana MD Build and Fly
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Precision Aerobatics Katana MD Build and Fly - 6/3/2007 6:22:55 AM
aflipz
Status: offline
Great thread Itai! I saw some of your posts on the other forum. I decided to join this thread too if you'll have me on board
Here is some footage my friend shot of mine in some wind today;
http://www.youtube.com/watch?v=OkQEGtNC44U
(in reply to itai)
       Post #: 51
RE: Precision Aerobatics Katana MD Build and Fly - 6/3/2007 7:26:38 AM
itai
Status: offline
Hi aflipz
thanks for joining, no problem, I was waiting for some one that already flies the plane.
Do you think EF 35 A esc is good choice?
(in reply to aflipz)
       Post #: 52
RE: Precision Aerobatics Katana MD Build and Fly - 6/3/2007 7:29:27 AM
aflipz
Status: offline
I think it will be just fine with a 12x6E prop The esc will only be seeing very short bursts above 31-33A and it is rated for 35 continuous with bursts above that. With the good airflow this cowl has it will not be a problem.
(in reply to itai)
       Post #: 53
RE: Precision Aerobatics Katana MD Build and Fly - 6/3/2007 3:43:57 PM
itai
Status: offline
this is my reciver gws 8 gr
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 54
RE: Precision Aerobatics Katana MD Build and Fly - 6/3/2007 4:10:28 PM
itai
Status: offline
I like the battery tray, it is well mounted, it has sufficient holes to allow airflow to cool the battery and it has a groove that holds the Velcro from moving up and down.
The only thing I added is six foam rubber dots that I cut with a hollow punch tool. Then I pressed it to a double sided transparent tape and cut it round. Stick it to the battery tray and you're done.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to itai)
       Post #: 55
RE: Precision Aerobatics Katana MD Build and Fly - 6/3/2007 5:53:56 PM
aflipz
Status: offline
be carefull with that radio, it only has a 250 metre range if i am not mistaken... Possibly less! (especially with all the cf in this bird)
(in reply to itai)
       Post #: 56
RE: Precision Aerobatics Katana MD Build and Fly - 6/3/2007 10:25:06 PM
itai
Status: offline
Yes I think it is 250, but very light,
I will perform a few range checks, if there will be a problem I will change it.
I think 200 meters is good for a small 3D electric, after 100 meters it looks to small.
       Post #: 57
RE: Precision Aerobatics Katana MD Build and Fly - 6/3/2007 11:12:44 PM
aflipz
Status: offline
oh yeah without a doubt you will be able to keep it in range, you just have to remember what the range is. Using full range rx's in all but the smallest application myself i don't think about it anymore, if my KMD had a shortened range i might forget and exceed it one day inadvertantly, while chasing a seagull out of my airspace for instance!
(in reply to itai)
       Post #: 58
RE: Precision Aerobatics Katana MD Build and Fly - 6/4/2007 2:27:42 AM
aflipz
Status: offline
itai, you inspired me with the foam rubber battery tray pads. I just copied you and cut some thin strips that i applied to some of the diagonal parts on the cf battery tray. I glued them on with shoe goo; a rubber like adhesive that behaves a little like contact cement but is completely reversible (just scratch and peel it off if you need to) This will work great!
       Post #: 59
RE: Precision Aerobatics Katana MD Build and Fly - 6/4/2007 6:26:39 AM
itai
Status: offline
pics please
       Post #: 60
RE: Precision Aerobatics Katana MD Build and Fly - 6/4/2007 10:54:34 PM
Snootch
Status: offline
Itai,
Here is a test graph to help you decide on the ESC.
My setup:
- PA Thrust 30
- Castle Creations 45
- FlightPower 2170mAH 3s1p Evolution 25C
APC E prop 12x6
Max Amp Draw: 32.1 Max Watts: 339
APC E prop 13x6.5
Max Amp Draw: 38.8 Max Watts: 416
Ralph P.
< Message edited by Snootch -- 6/5/2007 3:18:38 AM >
(in reply to itai)
       Post #: 61
RE: Precision Aerobatics Katana MD Build and Fly - 6/5/2007 1:33:46 AM
aflipz
Status: offline
That proves with your 35A airboss esc you have absolutely nothing to fear on a 12x6, and a relatively safe 13x6.5 setup with good ventilation and some throttle management.
(in reply to Snootch)
       Post #: 62
RE: Precision Aerobatics Katana MD Build and Fly - 6/5/2007 5:53:27 AM
itai
Status: offline
ok 35 A airboss ESC is the one
Click for fullsize
Click for fullsize
       Post #: 63
RE: Precision Aerobatics Katana MD Build and Fly - 6/5/2007 5:55:24 AM
itai
Status: offline
thanks snootch ,aflipz
(in reply to itai)
       Post #: 64
RE: Precision Aerobatics Katana MD Build and Fly - 6/5/2007 1:38:40 PM
Red7fifty
Status: offline
Also, check the BEC specs......If one has a higher BEC output, I would choose that one for better power to the servos.
(in reply to itai)
       Post #: 65
RE: Precision Aerobatics Katana MD Build and Fly - 6/5/2007 2:57:15 PM
aflipz
Status: offline
Airboss has a 2A bec which should be good enough for the KMD even on the best servos out there.
Daniel Dominquez got away with a 25 A 1st gen castle creations with 1.5A bec, of course he did have problems with that esc but it's to be espected when youre running it over spec on both the bec and the motor power. I would use the airboss 35 in mine with no worries. But i did have a phoenix 45 with 3A bec so guess what i am using
nothing wrong with a bit of well placed overkill!
(in reply to Red7fifty)
