RE: Precision Aerobatics Katana MD Build and Fly
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> RE: Precision Aerobatics Katana MD Build and Fly Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
Login
RE: Precision Aerobatics Katana MD Build and Fly - 7/4/2007 4:15:34 PM
aerofundan
Status: offline
quote:
ORIGINAL: vasmikey
Daniel, you are one great pilot. I envy you. I belong to a new club with a lot of 3D fliers and they encouraged me to get my first 3D airplane and after reading your messages and seeing your video, I bought the Katana and it just arrived. So wish me luck. I have been flying for 20 years but mostly Sailplanes and fast sleek Pylon racers, some scale planes. So I'm learning new terms like, Lomchevok, Waterfall, Torque rolls, flat spins, etc.
Question:
My plane came with a Torque motor, by ExtremeflightRC. Do you know anything about that motor. Should I return it for AXI for another?
thanks,
michael
Hello Michael!, you will have a lot of fun with the Katana MD, the torque motor is good for it, no need to replace!, what servos you are going to use?, keep us informed!
Daniel
_____________________________
Daniel Dominguez
http://www.aerofun3d.com/videos/
(in reply to vasmikey)
       Post #: 126
RE: Precision Aerobatics Katana MD Build and Fly - 7/4/2007 7:39:48 PM
vasmikey
Status: offline
Daniel,
Here is what I ordered. I will start building tomorrow since I'm working today. Any suggestions before I begin are welcome.
Torque 2818-900
Phoenix - 45 ESC
HS-65 servos
(in reply to aerofundan)
       Post #: 127
RE: Precision Aerobatics Katana MD Build and Fly - 7/4/2007 8:52:44 PM
aflipz
Status: offline
that is a perfect setup.
1) take circlip off motor shaft
2) follow manual instructions carefully
3)Enjoy your plane!
       Post #: 128
RE: Precision Aerobatics Katana MD Build and Fly - 7/4/2007 11:09:27 PM
aerofundan
Status: offline
quote:
ORIGINAL: vasmikey
Daniel,
Torque 2818-900
Phoenix - 45 ESC
HS-65 servos
No mods needed, just get a good 1 mm drill bit for drilling the cowl / servos (remember they have CF so you have to drill them carefully), also if you are going to use a spinner consider shortening the motor shaft. With your setup you are going to have a lot of fun, what battery parcks are you going to use??
Daniel
Daniel Dominguez
       Post #: 129
RE: Precision Aerobatics Katana MD Build and Fly - 7/4/2007 11:41:55 PM
Greg Cothern
Status: offline
I have my gear for my Katana MD, here is the list:
GP RimFire 35-36-1000
Electrifly SS 45 amp ESC
Electrifly 11.1V 2100 Mah 20C LiPo
Futaba 3114 servo's
Castle Berg RX-7
I think should be a decent setup, any thoughts??
Some of the products I like
Smart-Fly Hangar 9 Wild Hare MVVS & DA Engine''s Futaba Radio Hitec Digital Servo''s
       Post #: 130
RE: Precision Aerobatics Katana MD Build and Fly - 7/5/2007 12:56:33 AM
aflipz
Status: offline
I dunno about those servos tell you the truth, the minimum servo for optimum performance is hs65HB which is more powerfull and is far more robust. Even it is pushed to it's very limits and must be setup carefully to optimize performance.
(in reply to Greg Cothern)
       Post #: 131
RE: Precision Aerobatics Katana MD Build and Fly - 7/5/2007 1:05:12 AM
aerofundan
Status: offline
its hard to tell as the specs of the servos are below the limit of the recommend servo, it will probably work if you won't use the plane for 3D, and also if you are going to use small servo arms, but if you use the big servo arms and going to fly 3D, there is a lot of chances that you will strip the gears, maybe not!, personally i don't have any experience with the futaba micro servos, but their bigger servos are very strong, so... you'll have to decide if not, i recommend you to get the BB 373MG servos that PA recommends, they have the same specs as the HS65, but the difference is that they are metal gear! i'm using them on my kmd now and they are excelent servos, and they cost less than the hs65!
Daniel
Daniel Dominguez
(in reply to aflipz)
       Post #: 132
RE: Precision Aerobatics Katana MD Build and Fly - 7/5/2007 2:05:45 AM
Greg Cothern
Status: offline
I checked the specs and here they are:
Futaba 3114
SPECS: 6V 4.8V
Torque: 23.5 oz-in (1.7 kg-cm) 20.8 oz-in (1.5 kg-cm)
Speed: 0.09 sec/60° .10 sec/60°
The PA 373
Torque At 4.8V (6.0V) 1.6kg/cm , 22 oz/in (2.3kg/cm , 28 oz/in)
Speed At 4.8V (6.0V) 0.13sec / 60 deg at no load (0.11sec / 60 deg at no load)
Is there really that much difference in 4.5 oz's???? Also I am going to have to reword the firewall to mount the RimFire, so I was thinking I would use it on another bird, but where in the USA can I order the PA Thrust motor??
       Post #: 133
RE: Precision Aerobatics Katana MD Build and Fly - 7/5/2007 2:39:39 AM
aerofundan
Status: offline
quote:
ORIGINAL: Greg Cothern
Futaba 3114
SPECS: 6V 4.8V
The PA 373
Hello Greg, the difference is not much in the torque, its in the gears, the PA is Metal Gear, and the Hitec is carbonite, the futaba is nylon!
I recommend to get the Thrust 30 if you can, you can order directly from PA, shipping isnt too bad i think, another alternative is to get the Torque from Atlanta Hobby. It has a bit less power than the Thrust 30, and doesnt has the rotorkool technology, but it will fit the plane without any mods!
Daniel Dominguez
       Post #: 134
RE: Precision Aerobatics Katana MD Build and Fly - 7/5/2007 3:32:17 AM
vasmikey
Status: offline
I ordered 2 each 2100 3 cell LiPos Yuntong batteries. Thanks for the building tips. I have a few good bits and have worked a little with Carbone Fiber. Funny, I set up a large network in a CF plant in Sacramento, CA some years ago. Little did I know....
thanks again!
michael
       Post #: 135
RE: Precision Aerobatics Katana MD Build and Fly - 7/5/2007 7:47:10 AM
Greg Cothern
Status: offline
Alright!!!! I broke down and ordered the PA Thrust 30, PA 40 amp ESC, 4x373 servo's, CF servo arms, prop adapter, 12 & 13" props for my K'MD...
Now hopefully it wont be on a slow boat. Now to pick out something for the RimFire and other goodies I have sitting here!!!
       Post #: 136
RE: Precision Aerobatics Katana MD Build and Fly - 7/5/2007 4:41:24 PM
aerofundan
Status: offline
Awesome to hear that!
Get a warbird for your other goodies P51 P51!!!!
Daniel Dominguez
       Post #: 137
RE: Precision Aerobatics Katana MD Build and Fly - 7/6/2007 1:01:35 AM
vasmikey
Status: offline
Worked on my Kantana MD this afternoon. Interesting build. Very delicate than most planes. Really have to be careful with CF. I got the aeleron servos done and LG bolted on. The silver solder screws were a difficult fit. That magnet cover was a real trip! Taking a break now will finish it tonight. Hey Daniel, my favorite video from your collection was the Goodbye one. Absolutely awesome! Gave me chills to watch. Very nicely done.
michael
Bloomington, MN
       Post #: 138
RE: Precision Aerobatics Katana MD Build and Fly - 7/6/2007 9:23:16 AM
