RE: Precision Aerobatics Katana MD Build and Fly
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> RE: Precision Aerobatics Katana MD Build and Fly
Page: <<   < prev  5 6 [7] 8 9 10 11 12 13 14   next >   >>
Login
RE: Precision Aerobatics Katana MD Build and Fly - 7/9/2007 4:27:21 AM
vasmikey
Status: offline
Funny story today whilst I was doing the final assembly of my Katana MD; I put it on the balance after installing the battery and my wife drives up and takes a look. She says, "honey, notice anything interesting about those wings?" "What?" I cried. She continues, "what are those aileron servos doing on the TOP of your wings?" "You never put them there!" She then called me a huckleberry and went inside. sigh! I looked more closely and guess what? I installed the wings backwards/upside down. The strange thing is that the wing is perfectly symetrical and that it fit backwards and the guide pins and nylon screw fit perfectly too! duh! Anyway, reversed them in about 10 minutes and I was doing some test taxi stuff in my front yard. I'm sticking to the excuse that I was tired.
(in reply to itai)
       Post #: 151
RE: Precision Aerobatics Katana MD Build and Fly - 7/9/2007 4:44:42 AM
aflipz
Status: offline
Should have said "It's meant to be like that honey, shows what you know" then turnaround raising your nose...
A guy did that on his seagull extra (inverted the wings) because he was making it a belly lander and didn't want to break servo gears with arms, rods and horns grabbing in the grass. I top
mounted the servos on top on my modified ultrafly extra300s also for that reason.
(in reply to vasmikey)
       Post #: 152
RE: Precision Aerobatics Katana MD Build and Fly - 7/9/2007 5:24:09 PM
vasmikey
Status: offline
Does anyone know what a high pitch sqeeky sound coming from my outrunner means? It squeeks when I first start moving the throttle stick upward then ceases as the RPM increases. Any thoughts gentlemen?
(in reply to aflipz)
       Post #: 153
RE: Precision Aerobatics Katana MD Build and Fly - 7/10/2007 2:55:22 PM
lucky9910
Status: offline
Guys what is your fight time with TP 2100 & 40amp esc? Trying to decide which plane to purchase with my current set up.
       Post #: 154
RE: Precision Aerobatics Katana MD Build and Fly - 7/10/2007 8:43:40 PM
aflipz
Status: offline
flight time; 10-12 minutes of mixed flying easy.
vasmikey; the "squeek" you hear is from the electric pulses the esc sends to your motor to start it up, i think the sound is caused by some mis-timed or counter productive pulses that are inevitable starting from a dead stop or from very low rpm's. These can be pretty noisy, they use the same type of pulsing to emit programming tones out of the motor (note your esc has no beeper or speaker on board, it uses your motor as a speaker!) Cool eh!
anyway it is nothing to worry about.
(in reply to lucky9910)
       Post #: 155
RE: Precision Aerobatics Katana MD Build and Fly - 7/11/2007 3:57:11 AM
aerofundan
Status: offline
quote:
ORIGINAL: lucky9910
8-10 minutes safe. some people say over 10 minutes, depends on how hard you fly it.
_____________________________
Daniel Dominguez
http://www.aerofun3d.com/videos/
       Post #: 156
RE: Precision Aerobatics Katana MD Build and Fly - 7/12/2007 8:01:03 PM
itai
Status: offline
Almost finished,
My weight is 1007gr 35.5oz
Where did you guys take out the antenna from? Pictures please
Click to see fullsize image.
Click for fullsize
(in reply to aerofundan)
       Post #: 157
RE: Precision Aerobatics Katana MD Build and Fly - 7/17/2007 1:37:04 AM
TNTtrucks
Status: offline
Does anyone have, or have a link to a Katana MD for G3 or 3.5? I found the mini on the Swap Pages but wanted to try the MD. Thanks.
(in reply to itai)
       Post #: 158
RE: Precision Aerobatics Katana MD Build and Fly - 7/17/2007 2:27:07 AM
Greg Cothern
Status: offline
My goodies from PA arrived this evening, motor is installed, working on the servo's (making extensions for the ailerons and elevator). Hope to have quite a bit done tomorrow evening.
Some of the products I like
Smart-Fly Hangar 9 Wild Hare MVVS & DA Engine''s Futaba Radio Hitec Digital Servo''s
(in reply to TNTtrucks)
       Post #: 159
RE: Precision Aerobatics Katana MD Build and Fly - 7/17/2007 5:49:43 AM
aerofundan
Status: offline
quote:
ORIGINAL: TNTtrucks
There isnt any YET, hopefully soon someone will do one for us
Daniel Dominguez
       Post #: 160
RE: Precision Aerobatics Katana MD Build and Fly - 7/17/2007 5:51:20 AM
aerofundan
Status: offline
quote:
ORIGINAL: Greg Cothern
Keep us informed about your build and how you like the plane!
Daniel Dominguez
(in reply to Greg Cothern)
       Post #: 161
RE: Precision Aerobatics Katana MD Build and Fly - 7/18/2007 12:55:59 AM
Greg Cothern
Status: offline
Well I had wanted to finish the K-MD but alas probably wont happen today.... I ordered the CF servo arms, while I like them and they are cool and will work good, I am very frustrated with them, for the cost and such it would have been nice for them to come drilled to fit the PA servo's, or atleast with the appropriate sized drill bits to make them fit.
I LOVE the CF control horns they are great...
I hope to have the radio gear finished this evening, with only to finish up the ESC, motor, air scoops, and cowl mounting tomorrow..
       Post #: 162
RE: Precision Aerobatics Katana MD Build and Fly - 7/19/2007 3:50:30 PM
vasmikey
Status: offline
I finished my Kantana MD. It flew great. Only needed one click of up trim and lateral balance was perfect.. (see if I can make my PICs appear.) thanks all for the super advice.
Click for fullsize
       Post #: 163
RE: Precision Aerobatics Katana MD Build and Fly - 7/19/2007 3:54:40 PM
Greg Cothern
Status: offline
I would like to see some PICs of how folks mounted their ESC's in the K-MD please??
       Post #: 164
