Wheel size for 1/4 scale Tiger Moth ?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Scale Aircraft >> Wheel size for 1/4 scale Tiger Moth ?
Page: [1]
Login
Wheel size for 1/4 scale Tiger Moth ? - 5/2/2007 10:44 AM
nashtm
Score: 100
Last Login: 2/19/2013
Status: offline
Hi all
I am building Pacific Aero Tiger Moth but I don't want to use the wheels that came with the kit - could some one please tell em what size the full scale had or which size to use _ I am tending to the Du Bro Big Wheels 4.5" .
thanks
Tim
_____________________________
regards
Tim
Hide Signatures
       Post #: 1
RE: Wheel size for 1/4 scale Tiger Moth ? - 5/7/2007 3:03 AM
flipstart
Score: 100
Last Login: 5/17/2010
Status: offline
I built that arf about 3 years ago for a friend-think I used the inflatable Dubro big wheels in 4-4.5" size-they worked out nice. I hope Pac Aero has up graded the hardware by now-I had to redo the pull pull cables and throw out all hardware-clevis broke and/or stripped out on threaded couplers-very poor quality stuff.
Also be sure and iron down the wall paper covering around the firewall-his has almost been recovered from firewall back to cockpit where covering came loose. Plane flys fairly well, just get ready to use plenty of rudder on take off or put some right thrust in the engine mount. His tends to climb like crazy when throttle is applied, but most biplanes have this tendency. We ended up putting in some more down thrust.
REAL AIRPLANES HAVE MACHINE GUNS
Hide Signatures
(in reply to nashtm)
       Post #: 2
RE: Wheel size for 1/4 scale Tiger Moth ? - 5/7/2007 5:18 AM
V2PLUS10
Score: 100
Last Login: 4/12/2013
Status: offline
I used a set of 1/4 scale Cub wheels, made hub caps/covers from aluminum sheet....maybe a little wide but they look good....
Randy
Hide Signatures
       Post #: 3
RE: Wheel size for 1/4 scale Tiger Moth ? - 5/7/2007 8:33 AM
tailskid
Score: 199
Last Login: 5/19/2013
Status: offline
Here are mine....Arizona Models ARF
Click to see fullsize image.
Click for fullsize
Click for fullsize
# 93 in Club Saito
Carl Goldberg Ultimate Brotherhood # 12
Hide Signatures
(in reply to V2PLUS10)
       Post #: 4
RE: Wheel size for 1/4 scale Tiger Moth ? - 5/7/2007 11:19 AM
nashtm
Score: 100
Status: offline
Thanks all
flipstart - I replaced all coplers and clevises - they were all 2mm Metric stuff, the quality was fine but 2mm Metric in brass is not a good choice for this sort of thing. The build quality of this arf is very good except that the covering is , like you said "Wall paper".
Tim
regards
Tim
Hide Signatures
(in reply to tailskid)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.282RCU1
