12z throttle cut
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> 12z throttle cut
Page: [1]
Login
12z throttle cut - 5/2/2007 10:47:15 PM
meanrc
Status: offline
Being new to the 12z I have a question on throttle cut. I noticed that if you program this function and one might accidentally bump the switch you loose throttle control if you should bring the throttle down to the range of activation. If you remember to turn it off throttle will come back after a short delay.. The 8u and my 9c didn't have this scary feature. One could put it on the trainer sw. but I some times use this. Anyone have any suggestions. Thanks a bunch JK
       Post #: 1
RE: 12z throttle cut - 5/5/2007 9:26:48 PM
BR289
Status: offline
I have both the 14 and 12 and program throttle cut on the "B" switch. Pretty hard to bump in that spot.
(in reply to meanrc)
       Post #: 2
RE: 12z throttle cut - 5/30/2007 3:32:22 PM
grcourtney
Status: offline
I use a slider for idle trim just reasign the trim control never liked digital idle trim! or throttle cut switch!
gary
(in reply to BR289)
       Post #: 3
RE: 12z throttle cut - 9/25/2007 12:02:46 AM
sfsjkid
Status: offline
I'm like BR289, I have mine on the C switch (B switch on the other side). Only reason I've done that is on the 9C it is the only 3 position switch on the front. That way my 9C, 9Z and 12Z all have throttle cut on the same switch at the 'last' position. I have yet to bump either switch.
Addtitionally, here's a link to a thread "12Z and Logic Help" seems to me you can enable a safety switch.
http://www.rcuniverse.com/forum/m_6383167/tm.htm
Good luck!
(in reply to grcourtney)
       Post #: 4
RE: 12z throttle cut - 1/22/2008 3:06:46 PM
Steve
Status: online
A friend of mine uses the CD push button for the engine kill. Works great.
_____________________________
AKA,, "The Spleen"
If you want to see my Super Power,,, pull my finger.
(in reply to sfsjkid)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU1
