Rezagh
CA, USA Status: offline
Jean-Claude, I would at least use a switch with over 6 amp continuous rating. I guess your regulator/switch rating is LOW for this plane! I think you have to get a good power system + good servos and regulator or it will be just a matter of time before something giving up! The least is you will not be enjoying the plane because your set up is not right. Thank you, Reza
_____________________________
Quique's Aircraft Company
