revo took a dump
Tower Hobbies
Logged in as Guest
  Printable Version
FS Racing Monster Truck 4WD 1/5 Scale Blue - RTR
Seller:  pmwtrading
Details:   $755.00   |  8/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> revo took a dump
Page: [1]
Login
revo took a dump - 5/4/2007 3:46:06 AM
zuch95701
Status: offline
i just bough a used revo 2.5 that guy has had it since 04 and probly about 3 gallons of fuel threw it. It ran fine the first 2 weeks i had it and now it has no bottom end tork when it gets warmed up. it will roll on the throtle and just screm in the top end but if you gas it and try to get power off the line nothing. just bogs. any ones input would be great.
one more question if that motor is toast i can put a 3.3 in it just fine right?
       Post #: 1
RE: revo took a dump - 5/4/2007 3:51:43 AM
weez440
Status: offline
yes you can put a 3.3 in it or better an os.18tm. if it has 3 gallons through it, it is possible the engine is weak and just upgrade you would be happier. and did you try replacing the glowplug?
_____________________________
98 percent of ppl avoid hitting the ditch, the other 2 percent say hold my beer this is gonna be FUN!!!!!!
(in reply to zuch95701)
       Post #: 2
RE: revo took a dump - 5/4/2007 3:54:51 AM
zuch95701
Status: offline
ya new glow plug new fuel line and cleaned the carb still no help also the thing is runing real rich but leaning it makes it run worse.
this is an unrelated question to the motor but my low battery light on the opti drive comes on like after 5 min or driving is that the opti drive freaking out or do i need to replace the battery
(in reply to weez440)
       Post #: 3
RE: revo took a dump - 5/4/2007 4:05:05 AM
blackoutsi
Status: offline
I know I say this a lot, but maybe check for a crack in the carb? Mine had one and I replaced the carb body...same thing happened within a day of running so I just ran the LSN a little rich to compensate and it's actually running pretty good.
That actually sounds like a worn motor, but just for kicks get it warmed up and do a pinch test and adjust your low speed needle accordingly. See what that does for you.
       Post #: 4
RE: revo took a dump - 5/4/2007 7:28:12 PM
zuch95701
Status: offline
i checked the sytem for air leakes the other day and no leakes so no crack in the carb. even with the pinch test dont and the low speed right still crapy bottom end
(in reply to blackoutsi)
       Post #: 5
RE: revo took a dump - 5/5/2007 1:38:52 AM
BRUSHLESS BASHER
Status: offline
It sounds like you need to learn to tune, if the motor was worn out (piston and sleeve) it would run fine at a low temp (when you start it up) but when it got warm and the piston a=nd sleve expanded it would lose almost all power. I think you need to learn to tune.
       Post #: 6
RE: revo took a dump - 5/5/2007 1:51:27 AM
ttoks
Status: offline
brushless, there is no need to be so harsh, he is learning, he only just got the car.
with your problem, i would think that the engine is worn out, the previous owner proberly thrashed it so i wouldn't be surprised if you needed an engine rebuilt soon, my suggestion? run that little barsted as lean as it will without dieing and give it hell it, then buy either an os .18 tm or a 3.3.
when the cop pulls you up doing 234 km/h and asks if you knew how fast you were going, say "yep i had cruise control on
(in reply to BRUSHLESS BASHER)
       Post #: 7
RE: revo took a dump - 5/5/2007 4:17:59 AM
BRUSHLESS BASHER
Status: offline
I wasn't trying to be harsh, but he should do a little research, learn to tune or at least what the charicteristics (sp) of a rich low speed needle are, or maybe take the head and backplate off to have a look inside, it's way cheaper than buying a new engine. And again I wasn't trying to be harsh, just keep him from spending money if he doesn't have to.
< Message edited by BRUSHLESS BASHER -- 5/5/2007 4:18:40 AM >
(in reply to ttoks)
       Post #: 8
RE: revo took a dump - 5/5/2007 4:48:37 AM
LSTVega28
Status: offline
quote:
ORIGINAL: BRUSHLESS BASHER
A little rude brushless......"you need to learn to tune".
www.lstforums.com
       Post #: 9
RE: revo took a dump - 5/5/2007 7:54:45 AM
weez440
Status: offline
brushless ppl like you make me stay away from this forum and dirtrider forum for my dirtbike. there are so many lil immature lil buttholes that are so quick to say do a lil research or you are stupid that it makes alot of good ppl go away and never post. if someone wants to post whats the difference between a trx 3.3 and an os.18tm we should happily post what our experiences are. i found one forum atvconnection.com where ppl aren't like that where i am and i go there more often then any other forum. and zuch i think you got a bad motor and with my personal experience i would get an os.18tm motor they are what 150 dollars now they hold an awesome tune and have the same or more power the the trx 3.3 and they are a direct drop in no add on's
(in reply to LSTVega28)
       Post #: 10
RE: revo took a dump - 5/5/2007 3:20:56 PM
DaveG55
Status: offline
I'm with ya brushless.
The way you said it may have been a bit blunt but I think that you're right on the money about the cause of his problem.
His symptoms do not sound like a worn out engine, it sounds exactly like a rich LSN
If any of that is not PC enough for ya sorry And if it makes somebody want to leave the fourm....
Sorry, see ya, have a good life.
Any technology, sufficiently advanced, will appear as magic
       Post #: 11
RE: revo took a dump - 5/5/2007 8:18:26 PM
BRUSHLESS BASHER
Status: offline
Weez, questions like "whats the difference between a trx 3.3 and an os.18tm" are usually not asking what the difference in performance, or ease of tune, or build quality, they are asking what the differrence in the motors are, meaning they think they are the same (maybe not so far in that direction), and to answer that I could say that a 3.3 is a .20 and an tm is a .18, instead of comparing dyno sheets, or expeireince. I haven't been on this forum for about 2 months and that is mainly because of posts like this and people like you and zuch who fill up the forum with questions that could be answered with the search button, the Traxxas support line, or google. I REALLY dont want to argue or start a flame war, or anything else, and I agree with the fact that I was being blunt and harsh, but he needs to crawl before he runs, learn to tune, or at least what the charicteristics of a rich or lean LSN/HSN are, before he sends it screaming down the street.
And thanks for the support Dave.
< Message edited by BRUSHLESS BASHER -- 5/5/2007 8:20:10 PM >
(in reply to DaveG55)
       Post #: 12
RE: revo took a dump - 5/6/2007 2:39:10 AM
hillbilly_jeeper
Status: offline
well guys i tore my engine down today and i found a air leak at the e start. also the motor was very dry. put it back together after cleaning everything and when a bit richer than normal to compesate for the motor behing warn. seems to be runing kinda ok. still laking bottom end powe rafter tuning but is runing. thanks for the help
(in reply to IceWindius)
       Post #: 13
RE: revo took a dump - 5/6/2007 2:44:59 AM
jarett 92
Status: offline
lol guys lets try to stay on topic here. maybe someone should make a fight thread and we can take all our anger out on eachother in there...while we stay on topic on the important threads like these.
And im glad u got ur truck running right. I highly suggest u print a manual off of traxxas.com if u dont have one and read it about 4 times there is SO much information in that thing its rediculas.
Revo 2.5/RB TM523
(in reply to hillbilly_jeeper)
       Post #: 14
RE: revo took a dump - 5/6/2007 4:33:21 PM
