Saito 125 Fuel Mix    Gallery
Logged in as Guest
    Search This Thread
Printable Version
90 Dgree Muffler Adapters
Seller:  RC Specialties
Details:   $19.95   |  4/12/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Saito 125 Fuel Mix
Page: [1]
Login
Saito 125 Fuel Mix - 5/7/2007 4:07 PM
mikuk
Score: 100
Last Login: 4/13/2009
Status: offline
Hello, Have just fitted a Saito 125A to a Funtana, I need to know what fuel mix, the engine instructions say 10-20% nitro and synthetic oil (no castor), anyone have any idea as to % oil, I have Modeltechnics Bekra mix, which is 5% nitro, 18% Klotz Technoplate, not a problem to add either to it as I have some in stock. Any ideas?
Thanks, Mike
_____________________________
mikg
Hide Signatures
       Post #: 1
RE: Saito 125 Fuel Mix - 5/7/2007 4:54 PM
DarZeelon
Score: 163
Last Login: 9/6/2011
Status: offline
Mik,
Despite Saito's recommendation, I do use some castor oil.
My mix is now 15% nitro, 18% Klotz Techniplate, 2% Klotz BeNOL castor oil and the remaining 65% methanol.
As soon as I receive the oil from Cooper Fuels, all the Techniplate will be replaced by 15% of this superior oil; and the methanol will be bumped to 68%.
Castor oil sticks to the bearings and protects against the increased tendency of these four-stroke engines to rust.
Dar Zeelon - ISRAEL - ddzeelon@gmail.com
MVVS - Jett - MS Composit - Rossi - Mejzlik
Hide Signatures
(in reply to mikuk)
       Post #: 2
NM2K
Score: 161
Last Login: 5/25/2013
Status: offline
The fuel you described as already having sounds good to me.
It would probably transition a little quicker/cleaner with more nitro, but some have reported that this engine does just fine on 5%. I'd give it a try and find out.
I'm surprised that your importer warns against any castor oil in the fuel. I wouldn't feel comfortable without at least 2 - 3% in the mix. Saito engines do not use bushed connecting rods these days. Plus the castor coats the ball bearings and prevents rust. With just a little castor in the fuel, I doubt if you will ever need to clean the exhaust valve and port.
Ed Cregger
< Message edited by Ed Cregger -- 5/7/2007 5:43 PM >
"Practice makes prefect"
Hide Signatures
(in reply to mikuk)
       Post #: 3
RE: Saito 125 Fuel Mix - 5/7/2007 5:58 PM
wcmorrison
Score: 105
Status: offline
Ditto on the Castor oil. I always make sure there is some in the fuel mix. The higher Nitro content may make the engine idle better but they should run just fine on the mix you have. Dispite what some magazine engine authors say, Castor is good for your engine, good protection for lean runs and good protection for your bearings.
Cheers,
Chip
Hide Signatures
(in reply to NM2K)
       Post #: 4
RE: Saito 125 Fuel Mix - 5/7/2007 6:10 PM
Hobbsy
Score: 650
Status: online
Here is my Saito 1.00 idling on Fox 5% nitro fuel with 20% castor.
Click to see fullsize image.
Click for fullsize
A young man knows the rules and an old man knows the exceptions.
Club Saito member #5
Hide Signatures
(in reply to wcmorrison)
       Post #: 5
RE: Saito 125 Fuel Mix - 5/7/2007 7:48 PM
blw
Score: 655
Status: offline
My Saito 1.25 manual does not suggest 10-20% nitro or fuel without castor.
What it does say is 20% oil and 10-15% nitro is recommended. If not available, then high quality 2 stroke glow fuel such as Hangar 9 Aero Blend, Omega, Cool Power, K&B, Power Master, etc.
Using fuel with entirely castro is not recommended.
A mix of synthetic and castor is acceptable.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
"It doesn''t take but one Auburn man to be a majority" -
Coach Pat Dye
Hide Signatures
(in reply to Hobbsy)
       Post #: 6
RE: Saito 125 Fuel Mix - 5/8/2007 1:43 AM
mikuk
Score: 100
Status: offline
Thanks for the replies guys, I must agree about the castor as I normally run with 2-3% of it in my OS 4-strokes, from what you have all said I'll take the middle road and add 2% quality castor to the Bekra mix and up the nitro to the 10% I normally use. Will stick with it if its happy on that. Regards Mike
mikg
Hide Signatures
(in reply to blw)
       Post #: 7
RE: Saito 125 Fuel Mix - 5/8/2007 2:25 AM
aussiesteve
Score: 216
Last Login: 5/29/2012
Status: offline
As BLW Said. The recommendation is not to use fuel that is entirely castor. I doesn't say to not use it at all.
I run 15% nitro in all my Saitos and they are all happy with that. I use 3% Castor and 17% Coolpower (20% total oil) and have never experienced a corrossion problem to date. (I'm also a little slack when it comes to using after run oil).
My sons accidentally filled my normal flight box fuel container with FAI fuel (0% Nitro and 20% Castor) a couple of years ago and all of my Saitos (including the 1.25 we had at the time) ran happily on it - yes we did have a tuning problem and the transitions weren't great but they ran happily all day nevertheless.
3W, BME and DA all the way. Proven power, Proven reliability and Proven support equals much cheaper in the long term.
Hide Signatures
(in reply to mikuk)
       Post #: 8
RE: Saito 125 Fuel Mix - 5/8/2007 4:18 AM
Hobbsy
Score: 650
Status: online
I only did that to see how it ran on the 5% stuff.
Hide Signatures
(in reply to aussiesteve)
       Post #: 9
RE: Saito 125 Fuel Mix - 5/8/2007 4:23 AM
aussiesteve
Score: 216
Status: offline
I only did it as a mistake - the teenagers (12 and 13 at the time) didn't twig to the fact that they were filling the flight box container with a different color fuel to normal and I didn't supervise them properly when they were doing the first fills for the day. I wouldn't recommend it to be done as a normal practice it sure plays havoc with the tuning and the power curve. - Great recommendation for one of our favourite engine brands though - they still ran OK on it.
Hide Signatures
       Post #: 10
Page:   [1]
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> Saito 125 Fuel Mix
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.344RCU1
