RE: JetLegend F-16 (1/8) Testflight    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: JetLegend F-16 (1/8) Testflight
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: JetLegend F-16 (1/8) Testflight - 6/19/2007 12:56 AM
john agnew
Score: 100
Last Login: 4/15/2013
Status: offline
Eric
Glad to hear the F16 is now flying so well. Been in the same place as you with getting too far out! Luckily I got the Scorpion back without any damage, had to land on the grass but got the gear up in time and managed a good belly landing.
I enjoyed your review of the F16, your photographs are much better than mine!
Best regards
John
Hide Signatures
(in reply to Eric Banner)
       Post #: 51
RE: JetLegend F-16 (1/8) Testflight - 6/19/2007 2:56 AM
Eric Banner
Score: 100
Last Login: 5/5/2013
Status: offline
Hi John,
Thanks for the kind words. Thankfully you don’t know how many photos I’ve got to take before I get one that’s even half usable!
Your little Foxcub looks just the job for flying off the average club grass field. As you say a 44 gold would make it really sparkle.
My landing, if you can call it that, was with the fuselage flat and with a much larger vertical than horizontal speed component! I didn’t have the presence of mind to retract the undercarriage in time as I was desperately trying to reach the runway. In some respects I was very lucky that the undercarriage absorbed all the energy of the arrival and the rest of the plane survived undamaged.
Best regards,
Eric
Hide Signatures
(in reply to john agnew)
       Post #: 52
RE: JetLegend F-16 (1/8) Testflight - 6/19/2007 7:40 AM
ubirajaramarques
Score: 100
Last Login: 12/4/2008
Status: offline
Hi Eric, I bought a JL f16 and im mounting it for the first flight. Im intending to takeoff from a grass field. Do you recommend to fly it on grass? do you think the undercarriage will work great with grass fields?
Hide Signatures
       Post #: 53
RE: JetLegend F-16 (1/8) Testflight - 6/19/2007 11:56 AM
E.Banner
Score: 100
Last Login: 4/21/2009
Status: offline
Hi ubirajaramarques,
I’ve no actual experience of the JL F-16 off grass and only 4 flights off tarmac so far...
With the MW54 on tarmac the acceleration is rapid and the take off run short. If you keep the airframe drag low (no or few missiles), the grass is short and the ground hard, you’ll probable make it O.K.
It would, I believe, be better with an 18lbf+ MW SS off grass.
The undercarriage itself should be fine. The way the mains are mounted gives lots of extra cushioning without being soft. The springing on the mains themselves and the nose wheel is excellent and should easily cope with grass.
HTH
Eric
quote:
ORIGINAL: ubirajaramarques
< Message edited by E.Banner -- 6/21/2007 12:38 PM >
Hide Signatures
(in reply to ubirajaramarques)
       Post #: 54
RE: JetLegend F-16 (1/8) Testflight - 6/19/2007 12:14 PM
jeff sewell
Score: 100
Last Login: 5/16/2013
Status: online
Hi Eric,
Very pleased that you had success with the F16 - looking forward to the finished review too.
Well done!
Jeff
_____________________________
Exclusive UK JetLegend Dealer
Wren Turbines Dealer
Hide Signatures
(in reply to E.Banner)
       Post #: 55
RE: JetLegend F-16 (1/8) Testflight - 6/19/2007 8:49 PM
Eric Banner
Score: 100
Status: offline
Hi Jeff,
Thanks for your support in replacing the undercarriage, excellent service.
I’ll try to get John Wright to shoot a video in the coming weeks.
Best regards,
Eric
quote:
ORIGINAL: jeff sewell
Hi Eric,
Well done!
Jeff
Hide Signatures
(in reply to jeff sewell)
       Post #: 56
RE: JetLegend F-16 (1/8) Testflight - 6/21/2007 2:22 AM
ubirajaramarques
Score: 100
Status: offline
What kind of cylinders should I use for doors? Type, size, model, brand. Should I use a separated air bottle just for doors or can I use the retracts bottle? Im thinking to use one bottle for retracts and doors and other bottle for brakes. Should I use a sequencer for retracts and doors or is there any other solution without the electronic sequencer?
thanks
Hide Signatures
       Post #: 57
RE: JetLegend F-16 (1/8) Testflight - 6/21/2007 8:42 AM
Jeremy_D
Score: 100
Last Login: 5/18/2013
Status: offline
I'm using a UP3 valve on my Raptor - hasn't come yet so I can't comment on setup but all reports is that they are good.
Global Jet Club Australia
www.aussiejet.com
Hide Signatures
       Post #: 58
RE: JetLegend F-16 (1/8) Testflight - 6/23/2007 3:59 PM
initref
Score: 100
Last Login: 6/3/2011
Status: offline
Hi,
I'm using the BVM #5751 door rams ( 1 inch stroke ) on the gear doors, with a Jetronic sequencer and actuating valves on my F-16. ( see Lasse's excellent build pics for approximate mounting location of the rams...)
Have spoke with Jeff Sewell the UK importer and he says that the single air tank supplied with the kit is sufficient to operate the gear/doors/brakes. Perhaps Eric and Lasse can confirm that they are using the supplied airtank.
Have figured out a way to tint the canopy too, model car spray for polycarbonate bodies.....sprayed on the inside of the canopy.
Barry
Hide Signatures
       Post #: 59
RE: JetLegend F-16 (1/8) Testflight - 6/23/2007 10:17 PM
Eric Banner
Score: 100
Status: offline
Barry,
Jeff is off course correct but I choose to use both tanks in parallel to increase system capacity. The tanks weigh next to nothing and there is plenty of space available.
For main gear doors I used Skymaster 40mm cylinders and standard offset hinges.
Nose door 1 5/16” door cylinder BVM#5752 and pin type hinges as Lasse's photo.
BVM#5753 Air switch feeds air to all doors.
A retract sequencer is not required with this arrangement as the air switch only switches air to close the gear doors when the retracts are actually up.
HTH
Eric
quote:
ORIGINAL: initref
Hi,
Barry
Hide Signatures
(in reply to initref)
       Post #: 60
RE: JetLegend F-16 (1/8) Testflight - 6/23/2007 10:49 PM
initref
Score: 100
Status: offline
Eric,
Did you get a pair (2) air tanks with your kit?
Barry
Hide Signatures
       Post #: 61
RE: JetLegend F-16 (1/8) Testflight - 6/23/2007 11:20 PM
Lasse Palm
Score: 100
Last Login: 5/10/2013
Status: offline
Hi Ubirajaramarques,
I use Bvm cylinders (5751) for main gear doors and Bvm cylinders (5752) for nose gear doors and Jet tronics J-ventile for retracts and one Bvm air micro switch (5753) for all gear doors.(watch picture! I use this air system diagram for Bvm air micro switch,) I think the best choice is if you can use a large air tank for retracts and standard air tank for the brakes, because the retracts and doors use a lot of air.
Barry,
I painted the canopy from the inside with yellow clear cote.
Lasse P
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Lasse Palm -- 7/11/2007 1:42 AM >
Hide Signatures
       Post #: 62
RE: JetLegend F-16 (1/8) Testflight - 6/24/2007 12:11 AM
Eric Banner
Score: 100
Status: offline
Ah. I’m not sure that I actually did. But I certainly used two tanks!
Initially I was going to use a separate tank just for the brakes but decided that I’d rather have the extra capacity available for the retracts.
Eric
quote:
ORIGINAL: initref
Eric,
Barry
Hide Signatures
       Post #: 63
RE: JetLegend F-16 (1/8) Testflight - 6/28/2007 1:09 AM
ubirajaramarques
Score: 100
Status: offline
Friends, what kind of material do you use for the transpass of the turbine? how is it made and installed inside the plane? what are the spaces between the turbine, the tailpipe and the transpass?
Hide Signatures
       Post #: 64
RE: JetLegend F-16 (1/8) Testflight - 6/28/2007 1:53 AM
Eric Banner
Score: 100
Status: offline
I didn't fit a turbine bypass as one isn't included in the kit. Turbine to tailpipe gap used was 25 mm, fairly standard for a Wren 54.
Rgds,
Eric
Click for fullsize
Hide Signatures
       Post #: 65
RE: JetLegend F-16 (1/8) Testflight - 6/28/2007 7:08 PM
drdoom
Score: 130
Last Login: 5/17/2013
Status: offline
I started Construction on mine Yesterday. It took 2 days to clean off my bench. I have the kit (Nothing Installed). So I am trying to figure out the best
sequence to build it. I don't want to have to remove something that is installed to get someting else in. Looks like the nose gear may be first. I glued the 2 tab that hold the radio board in , so I have begun.
AMA #70046 Jet Junkie!
Without Gravity, Your Lockout Jet becomes Space Junk.
Hide Signatures
       Post #: 66
RE: JetLegend F-16 (1/8) Testflight - 7/3/2007 7:18 AM
ubirajaramarques
Score: 100
Status: offline
Dear friends, Im having problems with the main retracts. I installed the robart 5 ports air control valve for maind and nose retracts, but every time I close or open the retracts their is a linkage thru the valve and the main retract doesnt work. Just the nose retracts works but just once because all the air from the bottle had linkage because the main retracts. The air scapes thru the valve because the retracts doesnt rwach the final positions. I think their are too much Y fittings in the main retracts air line wich reduces the air flow thru the cylinders.
Is their anything I can do to fix the problem? Can anybody send me a drawing squeme showing how to install all the valves, y fittings and air tubbings for the main and nose retracts?
thanks
Hide Signatures
(in reply to drdoom)
       Post #: 67
RE: JetLegend F-16 (1/8) Testflight - 7/3/2007 11:07 AM
extra 300
Score: 100
Status: offline
Hi guys,
I am very interested to acquire a F-16 1:8 and the Jet Legend seems very nice. My concern is to know if this jet would be suitable to fly on a short paved runway (300 ft). would appreciate receiving some details for take off and landing caracteristics, how slow can you fly with this plane before stalling, what would be the minimum distance you could land the F-16 on?
Thanks for you feedback.
B. Regards. Dany
Hide Signatures
       Post #: 68
RE: JetLegend F-16 (1/8) Testflight - 7/3/2007 1:58 PM
Jim Cattanach
Score: 100
Status: offline
What servo are you guys using for the nose steering?
JET FLYING:- Resistance is futile. You will be assimilated.
Hide Signatures
       Post #: 69
RE: JetLegend F-16 (1/8) Testflight - 7/3/2007 2:55 PM
E.Banner
Score: 100
Status: offline
Had a similar problem which I eventually cured by lubricating the main cylinder, internally, with a little thick Silicon grease. A drop or two of very thin silicon lubricant injected into the cylinder may work and is worth a try before going to the trouble of stripping the cylinder out.
Do the retracts work if you directly supply them with air?
The number of Y connections should have no bearing on retract operation provided they are not leaking.
The “air throttle” in the main cylinder “up” air supply line is to allow time for the strut un-locking cylinders to operate before the main cylinder shaft starts to move.
HTH
Eric
thanks
Hide Signatures
       Post #: 70
RE: JetLegend F-16 (1/8) Testflight - 7/3/2007 4:00 PM
Gary Szetlak
Score: 100
Status: offline
I have had the same issue with the Cermark F16 gear. The air was bleeding through the cylinder on one of the main retracts. I actually opened the cylinders and added a 26gauge loop of wire in the groove of the piston and then put the original O ring back on over it. I think the groove for the O ring was machined to deep and the O ring was not able to hold the air preasure. I originally added O ring lube and that held a couple cycles but quickly gave up.
Gary Szetlak
Hide Signatures
       Post #: 71
RE: JetLegend F-16 (1/8) Testflight - 7/3/2007 4:28 PM
Achillesfilho
Score: 100
Status: offline
Hi Eric,
Do you think the F-16 will fly ok with a RAM 500 ?
Thanks.
Achilles.
Hide Signatures
(in reply to Gary Szetlak)
       Post #: 72
RE: JetLegend F-16 (1/8) Testflight - 7/3/2007 9:23 PM
Eric Banner
Score: 100
Status: offline
Hi Achilles,
I’ve no direct experience with a Ram 500. Though I believe it develops close to 14lb thrust?
My JL F16 finished up at 17.5 lb dry and with the MW54 at 14lb is more than adequately powered. Depends on personal taste – some won’t be happy with less than 18lb from an MW54 SS while others will find it fast enough with 12lb turbine.
In short… Yes!
Eric
quote:
ORIGINAL: Achillesfilho
Hi Eric,
Thanks.
Achilles.
Hide Signatures
(in reply to Achillesfilho)
       Post #: 73
RE: JetLegend F-16 (1/8) Testflight - 7/3/2007 9:32 PM
Eric Banner
Score: 100
Status: offline
Hi jim,
I used a HS81MG servo with an "ox bow" in the control rod for cushioning.
Eric
quote:
ORIGINAL: Jascat100
Hide Signatures
(in reply to Jim Cattanach)
       Post #: 74
RE: JetLegend F-16 (1/8) Testflight - 7/3/2007 10:37 PM
Jim Cattanach
Score: 100
Status: offline
Hi Eric, Many thanks. I have had the F16 sitting here in its box for a few months. I decided to make a start, having made the effort to complete some other projects that never seemed to get finished.
The F16 looks a fairly easy build.
Regards
Jim
Hide Signatures
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.469RCU1
