RE: JetLegend F-16 (1/8) Testflight    Gallery
Logged in as Guest
    Search This Thread
Printable Version
F-16 1/8 Advanced - ARF
Seller:  AndyAndrews
Details:   $2,800.00   |  6/17/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: JetLegend F-16 (1/8) Testflight
Page: <<   < prev  1 2 3 4 [5] 6 7 8 9 10   next >   >>
Login
RE: JetLegend F-16 (1/8) Testflight - 6/17/2008 5:53 PM
FalconWings
Score: 121
Last Login: 6/19/2013
Status: offline
Guys, I used a JR-9411 for the rudder and it barely fits, had to grind some material off of the support bracket. Use that as a reference.
Man can't wait to fly mine!
_____________________________
Buying Jet Legend? Read here: http://www.rcuniverse.com/forum/m_11372496/mpage_1/key_/tm.htm
Hide Signatures
(in reply to Asif)
       Post #: 101
RE: JetLegend F-16 (1/8) Testflight - 6/17/2008 7:57 PM
Jim Cattanach
Score: 100
Status: offline
quote:
ORIGINAL: Asif
Guys,
I would like to know if anyone is using flap for landing?
Regards
Asif
I used the ailerons as flaps & the elevator as elevons. I found that flaps did not help the landings, in fact they made it more awkward. It lands easily without flaps. I still have the flap/elevon setup, but do not use the flaps.
One point to watch. I did not like the rudder control setup. I had bad rudder flutter on mine & could not fix it. I ended up removing the servo & glueing the rudder in a fixed position. The JL L39 uses the same type of control & a friend at our club had flutter & lost the rudder on his. Some alternative control is required.
JET FLYING:- Resistance is futile. You will be assimilated.
Hide Signatures
(in reply to Asif)
       Post #: 102
RE: JetLegend F-16 (1/8) Testflight - 6/17/2008 8:10 PM
sweetpea01
Score: 103
Last Login: 2/28/2013
Status: offline
Can't do that here in the US. Rudder is required
www.hobbiesxtreme.com
Hide Signatures
(in reply to Jim Cattanach)
       Post #: 103
RE: JetLegend F-16 (1/8) Testflight - 6/17/2008 8:23 PM
Jim Cattanach
Score: 100
Status: offline
quote:
ORIGINAL: sweetpea01
An alternative pull pull wire setup would be better.
Hide Signatures
(in reply to sweetpea01)
       Post #: 104
RE: JetLegend F-16 (1/8) Testflight - 6/17/2008 9:13 PM
Asif
Score: 105
Last Login: 6/18/2013
Status: offline
Jascat100,
Thanks for your reply. Basically you have servos in the wing that are not being used as neither aileron nor flaps? If you have fixed you rudder, how do you combat cross wind? I used my rudder in cross wind. Is there an alternate to rudder mechanism?
I want to stick with concealed control throws, I will want to avoid pull pull, simply because of aesthetic looks.
Regards
Asif
Hide Signatures
       Post #: 105
RE: JetLegend F-16 (1/8) Testflight - 6/17/2008 9:40 PM
FalconWings
Score: 121
Status: offline
The rudder linkeage is similar to that of Tam's F-16. It works pretty good. The flutter must have been casued by the control pin not being properly lined up or not enough contact. Or........big gap between rudder and fin.
Hide Signatures
(in reply to Asif)
       Post #: 106
RE: JetLegend F-16 (1/8) Testflight - 6/17/2008 9:43 PM
FalconWings
Score: 121
Status: offline
quote:
ORIGINAL: Asif
Jascat100,
Regards
Asif
You can do a pull-pull internally. Stick an auminum .25 rod at the rudder leading edge. The rod should extedn down all teh way to just above the tailpipe inside the fuselage. You will have to drill a .25 hole for the rod to pass trough. Once the rod is inside the fuselage just be creative and make the pull-pull.
Click to see fullsize image.
Click for fullsize
< Message edited by FalconWings -- 6/17/2008 9:53 PM >
Hide Signatures
(in reply to Asif)
       Post #: 107
RE: JetLegend F-16 (1/8) Testflight - 6/17/2008 9:46 PM
drdoom
Score: 130
Last Login: 6/17/2013
Status: offline
I made a longer pin and used a METAL ARM. The new pin sticks 3/8 of an inch deeper than the stock pin.
AMA #70046 Jet Junkie!
Without Gravity, Your Lockout Jet becomes Space Junk.
Hide Signatures
(in reply to FalconWings)
       Post #: 108
RE: JetLegend F-16 (1/8) Testflight - 6/17/2008 9:50 PM
Asif
Score: 105
Status: offline
drdoom,
can you post picture of you rudder mods?
Asif
Hide Signatures
(in reply to drdoom)
       Post #: 109
RE: JetLegend F-16 (1/8) Testflight - 6/17/2008 9:54 PM
FalconWings
Score: 121
Status: offline
prvious post, I added a graphical representation of what I had in mind.
Hide Signatures
(in reply to Asif)
       Post #: 110
RE: JetLegend F-16 (1/8) Testflight - 6/17/2008 10:17 PM
sweetpea01
Score: 103
Status: offline
quote:
ORIGINAL: Asif
drdoom,
Asif
ditto
Hide Signatures
(in reply to Asif)
       Post #: 111
RE: JetLegend F-16 (1/8) Testflight - 6/17/2008 10:18 PM
sweetpea01
Score: 103
Status: offline
Can anyone suggest what JR servos will fit in this plane?
I've got lots of 8411 and 8611A's laying around.
I know the wings are thin
I don't fly any other type servo so please don't suggest other brands
Hide Signatures
       Post #: 112
RE: JetLegend F-16 (1/8) Testflight - 6/17/2008 10:27 PM
FalconWings
Score: 121
Status: offline
I then suggest you go for an Avonds or a Yellow Aircraft!
I have 8717's (freaking lightning fast!) on elevators. Had to trim the bracket some to make them fit. 8411 on rudder.
And as for the ailerons, go get an Avonds or a Tam !!
Hide Signatures
       Post #: 113
RE: JetLegend F-16 (1/8) Testflight - 6/17/2008 10:39 PM
sweetpea01
Score: 103
Status: offline
So are you saying that no JR servo will fit in the wing? Tell me it ain't so!!!!
what is an 8717 and 9411 from your posts #101 and #113?
Did you actually mean 8711 and 8411? Or are these the foreign versions?
Ok, so for the wings what servo is fitting? And does anyone happen to have the dimensions of the servo along with speed/torque
I'm not buying another jet so I'll have to do some searching (and soul searching) to find something or mod the plane to fit.
Hide Signatures
       Post #: 114
RE: JetLegend F-16 (1/8) Testflight - 6/17/2008 11:49 PM
FalconWings
Score: 121
Status: offline
I could only fit an HS-5125's (thin wing). There seems to be a JR foreign servo that WILL fit. It's on an issue of Jet Mag. I'll try to find out for you.
JR8717 is the fastest servo so far I know of. .05 sec at 150 oz-in. Perfect for Elevators!! it is a little bit larger than an 8611. 8611 should fit almost perfect.
Hide Signatures
       Post #: 115
RE: JetLegend F-16 (1/8) Testflight - 6/18/2008 12:07 AM
sweetpea01
Score: 103
Status: offline
Thanks for the info. If you can find the JR foreign servo I'd appreciate it......I don't have any jet mags to research
Hide Signatures
       Post #: 116
RE: JetLegend F-16 (1/8) Testflight - 6/18/2008 12:21 AM
sweetpea01
Score: 103
Status: offline
Here is what I found so far
JR
DS168 Digital Thin Wing MG Servo Specs
Torque: 47oz @ 4.8V ; 53oz @ 6.0V
Speed: .17sec/60° @ 4.8V; .14sec/60° @6.0V
Dimensions (WxLxH): 0.34 x 1.33 x 1.18 in Weight: .7 oz
Bearing: Dual
Motor Type: Cored
Gears: Brass, Alloy, and Plastic combo
Deadband: less than 1us
Hitec
HS5125MG Digital Super Slim Wing Servo
Motor Type: 3 Pole Ferrite
Bearing Type: Dual Ball Bearing
Speed: 0.17 / 0.13 sec @ 60 deg.
English Metric
Torque: 41.66 / 48.60 oz.in (4.8v/6v) 3.0 / 3.5 kg.cm
Size: 1.18" x 0.39" x 1.33" 30.00 x 10.00 x 34.00mm
Weight: 0.84oz 24.00g
This JR servo appears to be very close. (infact smaller)
JR Hitec
53oz Torque 48oz Torque
.14speed .13speed
1.18x.34x1.33 1.18x.39x1.33
so if your Hitec is fitting than this one should as well (I hope)
Hide Signatures
       Post #: 117
RE: JetLegend F-16 (1/8) Testflight - 6/18/2008 7:12 AM
FalconWings
Score: 121
Status: offline
Found it, sorry bro, thought it was JR. They used an S3150 (Futaba). I thought S was for foreign versions. That's how much Futaba I know.
Yes your shall fit. The 5125 is a comfortable fit.
I also purchased this from Dreamworks (Saves you 3 servos and 3 valves):
Hide Signatures
       Post #: 118
RE: JetLegend F-16 (1/8) Testflight - 6/18/2008 7:25 AM
sweetpea01
Score: 103
Status: offline
I saw that.........was thinking about it very closely. I'm going to order up the JR wing servos and use 8611A's on the other surfaces
Hide Signatures
       Post #: 119
RE: JetLegend F-16 (1/8) Testflight - 6/18/2008 9:49 AM
mikedenilin
Score: 114
Status: offline
Sam,
Try these servos for ailerons.
http://www.horizonhobby.com/Products/Default.aspx?ProdID=JRPSDS3301
DS3301 Digital Wing Servos
Mike
Global Jet ARF PRO- Air-C-Race-Germany, CNC-Italy, Feibao, Gryphon/Redwings, Der Jet, Jet Legend, & more - globaljetclub.com
Hide Signatures
       Post #: 120
RE: JetLegend F-16 (1/8) Testflight - 6/20/2008 11:58 AM
Lasse Palm
Score: 100
Status: online
Hello Andrew!
Send some pictures on my JL 1/8 F-16
I have flown JL F-16 approximately 150 times and are really happy with the model.
Regards
Lasse Palm
Team Jet-Sweden
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 121
RE: JetLegend F-16 (1/8) Testflight - 6/20/2008 7:21 PM
drdoom
Score: 130
Status: offline
quote:
ORIGINAL: FalconWings
Im using 125 Analog. in the wings, work very well
Let us know how well you like that new valve setup.
Hide Signatures
       Post #: 122
RE: JetLegend F-16 (1/8) Testflight - 6/20/2008 7:57 PM
mikedenilin
Score: 114
Status: offline
Hi Lasse,
Really nice looking photos.
How did you set up the background? Looks like a studio quality photo.
The golden canopy looks really nice. Could you tell me how to do that, please?
Mike
Hide Signatures
(in reply to Lasse Palm)
       Post #: 123
RE: JetLegend F-16 (1/8) Testflight - 6/20/2008 8:05 PM
FalconWings
Score: 121
Status: offline
I'm going to do the plumbing tonight so I can test the EV5U. I can tell you this, it will make the setup simpler, but you will not save weight. The valve weighs at least tas much as 3 mini servos and 3 small independent air valves put together.
If there are no signs of a Rabbit soon, I will test fly mine with my P-70. I cn't wait any longer!
David
Hide Signatures
(in reply to mikedenilin)
       Post #: 124
RE: JetLegend F-16 (1/8) Testflight - 6/20/2008 11:21 PM
drdoom
Score: 130
Status: offline
David
Did you get the Festo version or the hose barbed?
Hide Signatures
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.625RCU1
