RE: JetLegend F-16 (1/8) Testflight    Gallery
Logged in as Guest
    Search This Thread
Printable Version
King Tech K180G
Seller:  Modellbau USA
Details:   $2,895.00   |  5/24/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: JetLegend F-16 (1/8) Testflight
Page: <<   < prev  1 2 3 4 5 6 7 [8] 9 10   next >   >>
Login
RE: JetLegend F-16 (1/8) Testflight - 6/2/2010 2:54 PM
Alex wong
Score: 100
Last Login: 5/21/2013
Status: offline
My F16 Maiden Flight....Fuel run out.. too long on ground ...Lucky only front landing gear need to change some small part..
http://www.youtube.com/watch?v=ZNC6WTTtZrY
Thanks for watch..
Hide Signatures
(in reply to hymie42)
       Post #: 176
RE: JetLegend F-16 (1/8) Testflight - 6/2/2010 5:23 PM
extra 300
Score: 100
Last Login: 5/25/2013
Status: offline
Next time, try to use an external tank for start up and a timer for your flight toprevent flame out from running out of fuel.
Glad to see that your damages were minimal. Nevertheles, check fuse and internal parts for hidden cracks to be on the safe side.
Regards,
Hide Signatures
(in reply to Alex wong)
       Post #: 177
RE: JetLegend F-16 (1/8) Testflight - 6/2/2010 5:42 PM
AndyAndrews
Score: 151
Status: offline
alexwong1878 — April 26, 2010 — 11-04-2010 Flying Field Kuala Baram. and Thanks to Camera man : Syafiq Dahlan
Really? omg...
Hide Signatures
(in reply to extra 300)
       Post #: 178
RE: JetLegend F-16 (1/8) Testflight - 6/3/2010 2:51 PM
Alex wong
Score: 100
Status: offline
quote:
ORIGINAL: extra 300
Regards,
Thank you:... Extra 300
Hide Signatures
       Post #: 179
RE: JetLegend F-16 (1/8) Testflight - 6/3/2010 2:55 PM
Alex wong
Score: 100
Status: offline
quote:
ORIGINAL: AndyAndrews
Really? omg...
Yes. AndyAndrews.... really Oh my god.....n lucky is small damage..order part at JL Mr Yang..
Hide Signatures
(in reply to AndyAndrews)
       Post #: 180
RE: JetLegend F-16 (1/8) Testflight - 11/14/2010 12:36 AM
carl.huxford125
Score: 105
Last Login: 5/24/2013
Status: offline
Hi,
I am in the middle of building the jetlegend F16, i have got to the point of testing the undercarriage and one of the small un-lock rams on the mains is leaking , can anybody tell me how to remove it from the leg,
Cheers
Carl
Hide Signatures
       Post #: 181
RE: JetLegend F-16 (1/8) Testflight - 11/14/2010 1:04 AM
hymie42
Score: 100
Last Login: 5/19/2013
Status: offline
Hi Carl,
I struggled quite a bit with mine initially, eventually squirted some 'O' lube in the system and now I retain enough air to cycle the gear 3-4 weeks after the last pump.
Depends how bad the leak actually is.
You could also look at one of the new JetTronic valves - they switch off the air 15 seconds after cycling, which is a nice safety net
I also use a gear failsafe in all my air up/down models - worth it.
The UK dealer - zedjet.com - should be able to help too.
Good luck,
Dave
Hide Signatures
(in reply to carl.huxford125)
       Post #: 182
RE: JetLegend F-16 (1/8) Testflight - 11/14/2010 12:49 PM
carl.huxford125
Score: 105
Status: offline
Cheers Dave,
I have tried putting lube in the system, but the leak is bad enough to stop the u/c from cycling.
If i put side pressure on the the leak does stop and the undercarriage functions ok.
Carl
Hide Signatures
       Post #: 183
RE: JetLegend F-16 (1/8) Testflight - 11/14/2010 1:03 PM
jeff sewell
Score: 100
Status: offline
Carl,
I have the spare complete locking arm for these....drop me a mail.
Cheers
Jeff
_____________________________
Exclusive UK JetLegend Dealer
Wren Turbines Dealer
Hide Signatures
       Post #: 184
RE: JetLegend F-16 (1/8) Testflight - 11/14/2010 1:37 PM
carl.huxford125
Score: 105
Status: offline
Cheers Jeff, mail sent
Hide Signatures
(in reply to jeff sewell)
       Post #: 185
RE: JetLegend F-16 (1/8) Testflight - 11/14/2010 8:00 PM
FalconWings
Score: 121
Status: offline
I need a new nose gear. Called GJC they took my info but never gave me a quote.
Does anyone know where else I can procure one?
So much for Global Jet Club.
Buying Jet Legend? Read here: http://www.rcuniverse.com/forum/m_11372496/mpage_1/key_/tm.htm
Hide Signatures
       Post #: 186
RE: JetLegend F-16 (1/8) Testflight - 11/14/2010 11:07 PM
jeff sewell
Score: 100
Status: offline
Odd...GJC are usually pretty hot - try Camlex?
Jeff
Hide Signatures
(in reply to FalconWings)
       Post #: 187
RE: JetLegend F-16 (1/8) Testflight - 11/15/2010 5:17 AM
mikedenilin
Score: 114
Status: online
Hi Falconwings,
Like Jeff said, we are pretty good in replying to any request. What's your name so I can search our customer service's file and let you know? We can get you any JL parts. Thanks,
Mike
Global Jet ARF PRO- Air-C-Race-Germany, CNC-Italy, Feibao, Gryphon/Redwings, Der Jet, Jet Legend, & more - globaljetclub.com
Hide Signatures
       Post #: 188
RE: JetLegend F-16 (1/8) Testflight - 11/15/2010 5:21 AM
mikedenilin
Score: 114
Status: online
Hi Falconwings,
Try this email globaljetclub@gmail.com so your request is sent to me directly instead of going through our customer service. Thank you.
Mike
Hide Signatures
(in reply to mikedenilin)
       Post #: 189
RE: JetLegend F-16 (1/8) Testflight - 11/15/2010 6:07 AM
FalconWings
Score: 121
Status: offline
Mike I called directly and a lady took my info.
I will email you directly.
David Rosado
Hide Signatures
       Post #: 190
RE: JetLegend F-16 (1/8) Testflight - 11/15/2010 8:04 AM
mikedenilin
Score: 114
Status: online
Hi Dave,
That explains it. Sometimes the air space between 2 ears is bigger than expected.
Mike
quote:
ORIGINAL: FalconWings
David Rosado
Hide Signatures
       Post #: 191
RE: JetLegend F-16 (1/8) Testflight - 11/15/2010 5:01 PM
FalconWings
Score: 121
Status: offline
I'm standing down, we've got positive contact.
Thanks Mike!
Hide Signatures
       Post #: 192
RE: JetLegend F-16 (1/8) Testflight - 11/15/2010 5:18 PM
sweetpea01
Score: 103
Last Login: 2/28/2013
Status: offline
Man.....I still need to finish my GJC F-16.
Damn life needs to stop getting in the way of my R/C
www.hobbiesxtreme.com
Hide Signatures
       Post #: 193
RE: JetLegend F-16 (1/8) Testflight - 11/15/2010 7:55 PM
Mark Huffman
Score: 100
Last Login: 12/11/2011
Status: offline
Does anyone have a picture of how they did the hinges on their flight controls? This is the first build I've done where the ailerons and rudder fit inside a shelf area. I have another set of ailerons and rudder coming as I was not happy with the hinge job I did on my first set. It appears that some material needs to be removed from the leading edge of the flight control so that the hingepin can sit further in the control surface and allow the control to move without binding on the shelf it sits in. I don't want to mess up another set.
Hide Signatures
(in reply to sweetpea01)
       Post #: 194
RE: JetLegend F-16 (1/8) Testflight - 11/16/2010 12:30 AM
marineA4
Score: 100
Last Login: 2/27/2013
Status: offline
Hi Mark,
Orlando here!
You shouldnt need any removal of material on the control surface. Sometimes all it takes is taking the paint under the cuff section that is exposed on the T/E portion of the wing where the control surface goes. Try sanding some paint and working it little by little to get a little more movement.
You can always shoot me an email and I can help you out.
marineA4@gmail.com
Name sounds familiar and I think I might have helped you out with the sale of your F-16 if not mistaken. Correct me if i'm wrong
I can give you more info if you'd like. My F-16 has been my favorite all time airframe at the moment.
Regards,
Orlando
Orlando Ortiz
Hide Signatures
(in reply to Mark Huffman)
       Post #: 195
RE: JetLegend F-16 (1/8) Testflight - 11/16/2010 7:44 PM
Mark Huffman
Score: 100
Status: offline
Orlando,
Thanks. You are correct. You helped me late last year with some questions regarding aileron servo placement. I will try the sanding idea and see how that works.
I have another question about the nose gear. Mine will turn 45-50 degrees to the right and stay there. But to the left, it will only go about 20 degrees and that is with constant pressure to get it there. It appears there is a shimmy damper but it is in a fixed position. Is there any way to adjust this or even it out? Or is this normal?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to marineA4)
       Post #: 196
RE: JetLegend F-16 (1/8) Testflight - 11/17/2010 2:48 AM
Countryboy
Score: 114
Status: offline
quote:
ORIGINAL: Mark Huffman
Without a picture of your existing hinge job, my speculation is that there were no existing hinge slots in the control surfaces and you merely drilled the leading edges and flushed the hinge pin to the leading edge. Is this correct or were your hinges installed like the ones shown in this photo?
< Message edited by Countryboy -- 11/17/2010 3:38 PM >
Hide Signatures
       Post #: 197
RE: JetLegend F-16 (1/8) Testflight - 11/17/2010 4:03 AM
Mark Huffman
Score: 100
Status: offline
You are correct in your speculation. Your picture is what I was thinking is the correct way. I saw a different model F-16 that had the hinges done as shown in your picture and that's what made me think there was a better way.
Hide Signatures
(in reply to Countryboy)
       Post #: 198
RE: JetLegend F-16 (1/8) Testflight - 11/17/2010 3:38 PM
Countryboy
Score: 114
Status: offline
Mark,
With your previous description of your problem, I sort of thought that may have been the problem. The hinge pin needs to be in the center of the radius and even then, it is not uncommon for one to have to trim the skins back that create the pocket for the leading edge of the control surface. Sometimes this has to be done to allow enough throw even when the hinges are correct.
Hide Signatures
       Post #: 199
RE: JetLegend F-16 (1/8) Testflight - 4/1/2011 11:12 AM
Heatseeker_Hill
Score: 100
Last Login: 3/11/2012
Status: offline
would this bird be ok on just elevons ? No flaps or rudder ? I am just nailing one together so any tips or changes I could make ?
Hide Signatures
       Post #: 200
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.719RCU1
