RE: Nitromodels PREDATOR RQ-1B    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Electric Aircraft Universe >> Electric Aerobatic & Sport Planes >> RE: Nitromodels PREDATOR RQ-1B Page: <<   < prev  14 15 [16] 17 18 19 20 21 22 23   next >   >>
Login
RE: Nitromodels PREDATOR RQ-1B - 1/7/2008 11:20 AM
junkjet
Score: 100
Last Login: 5/19/2013
Status: offline
Some cool new pics
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
AMA427952
Freddy Schneider
Hide Signatures
(in reply to chrishornby)
       Post #: 376
RE: Nitromodels PREDATOR RQ-1B - 1/7/2008 11:30 AM
junkjet
Score: 100
Status: offline
Here is the long awaited maiden flight of my Predator
http://www.youtube.com/watch?v=zxt2D8XGr_8
AMA427952
Freddy Schneider
Hide Signatures
(in reply to junkjet)
       Post #: 377
RE: Nitromodels PREDATOR RQ-1B - 1/8/2008 5:41 AM
papajeff
Score: 100
Last Login: 3/14/2013
Status: offline
quote:
ORIGINAL: Mr Ray
papajeff
Did you use a pusher prop?
Are brushless motors reversable?
Where did you find pusher props?
Did not receive my second predator yet, want to do this one right.
Ray,
Regarding the prop - Freddy is correct on both counts (use a 9x6 APC E {electric}) & normally (called tractor)
on every type of prop, the numbers or letters face front (away from the motor) now,
with a pusher, the numbers or letters face rear, but still away from the motor!
Brushless are reversable - just switch any two of the three leads between the motor & ESC.
Although some Mfg's do make special pusher props (Zinger, master Airscrew) regular (tractor) props
can be used as pushers, just as long as they are turned backwards.
On your "new" Predator, just take your time & basically follow the instruction booklet and use this build thread
as a guide with the knowledge that most of the mods suggested, are worth considering.
If you have a question.....just post it and I'm sure that you will get lots of help.
Hide Signatures
(in reply to Mr Ray)
       Post #: 378
RE: Nitromodels PREDATOR RQ-1B - 1/8/2008 6:13 AM
papajeff
Score: 100
Status: offline
Freddy,
Now you're talking.........I mean flyin!!!!! Very nice, and I will agree with brownlab when he said that the Predator is not all that easy to fly!
Your turns were very good and that's just a matter of more flying and getting the feel of adding in some opposite rudder ("V"tail) as you make your aileron turns. This will flatten out your turns and help make them a little wider, which is good for the long, narrow wings of the Predator.
On the landings, just line up on the runway, slowly cut the power to about 1/4 stick and let the plane lose altitude on it's own without a lot of down elevator. At about 10 feet high, or so, cut power to just about 1/8 stick and kind of fly & glide the plane down to the runway. If you practice landing in this manner you will avoid the up-down....up-down of your first attempt. It looked like you got it right on your second landing.
You did good and that gives me a lot of pleasure! Ohhhhhhhhhhhhhhhhhhhhh....................Yeahhhhhhhhhhhhh!!!!
One other thing, see that sort of loop on the rear under-fin, it's just a piece of 0.47 piano wire bent in a curve with both ends
CA'd into two holes drilled into the fin. This mod helps prevent the prop from striking the ground upon landing and it works!
Click for fullsize
< Message edited by papajeff -- 1/8/2008 6:19 AM >
Hide Signatures
(in reply to papajeff)
       Post #: 379
RE: Nitromodels PREDATOR RQ-1B - 1/8/2008 9:36 PM
PALLADIUM
Score: 100
Last Login: 2/27/2008
Status: offline
I welcome,
what of these models is better?
1 - http://store.bananahobby.com/gp1029.html
2 - http://www.bananahobby.com/1048.html
Thanks!
< Message edited by PALLADIUM -- 1/8/2008 9:37 PM >
Hide Signatures
       Post #: 380
RE: Nitromodels PREDATOR RQ-1B - 1/9/2008 12:57 AM
imwebbo
Score: 100
Last Login: 2/16/2008
Status: offline
Hey all interseting thread, the build photos are excellent - think i'm going to get one soon.
Can the wings be removed after its built for transportation?
I think the title of the thread and the model name is incorrect though, this model isn't a PREDATOR RQ-1B, as that is the name given to the baseline production configuration of the smaller Predator A (the tail is upside down). This is infact MQ-9 Predator B which has now been named the MQ-9 Reaper.
Check out this link if your interested in making the uav a little more autonomous - http://blog.wired.com/geekdad/2007/07/building-a-real.html
Anyway keep up the good work.
P.S. Just found another build thread for the same model which has some interseting mods - steerable nosewheel and canopy attachment for those who are still building/going to build - like me! http://www.rcgroups.com/forums/showthread.php?t=552246&highlight=nitro+predator
< Message edited by imwebbo -- 1/10/2008 1:03 AM >
Hide Signatures
(in reply to PALLADIUM)
       Post #: 381
RE: Nitromodels PREDATOR RQ-1B - 1/10/2008 1:35 AM
junkjet
Score: 100
Status: offline
Hi, Jeff. I do have the tail skid mod on my predator. its hard to see in the pics. Havent skinned the prop yet!!!
AMA427952
Freddy Schneider
Hide Signatures
(in reply to imwebbo)
       Post #: 382
RE: Nitromodels PREDATOR RQ-1B - 1/10/2008 6:17 AM
brownlab
Score: 100
Last Login: 1/10/2009
Status: offline
that brusless pred is the one i had but mine had a brushed 290 in it. and 4ch is a lie ,it is 3ch
the wind is a planes worst enemy
Hide Signatures
       Post #: 383
RE: Nitromodels PREDATOR RQ-1B - 1/10/2008 7:24 AM
Pappy-86
Score: 100
Status: offline
Ch1. Throttle
Ch2. Rudder
Ch3. Elevator
Ch4. Ailerons
Not in that order but that are the 4 Ch. needed to fly the Predator.
Typically a 3 Ch plane doen't have Ailerons and a 4 Ch does.
< Message edited by Warbird-Dave -- 1/10/2008 12:56 PM >
Hide Signatures
(in reply to brownlab)
       Post #: 384
RE: Nitromodels PREDATOR RQ-1B - 1/10/2008 1:07 PM
Pappy-86
Score: 100
Status: offline
Hello Just wanted to show you a pilot figure a friend of mine caved out of a chunck of balsa. I looked all over for a pilot for my Zero and couldn't find one I liked and he said he would make me one and did a nice job of it.
Click for fullsize
Hide Signatures
(in reply to Pappy-86)
       Post #: 385
RE: Nitromodels PREDATOR RQ-1B - 1/11/2008 12:49 AM
papajeff
Score: 100
Status: offline
quote:
ORIGINAL: PALLADIUM
I welcome,
Thanks!
For me, with knowledge of both planes, I truly believe that you will be happier with
the #1 (camo) above, which is the same one as in this thread.
Click for fullsize
Click for fullsize
< Message edited by papajeff -- 1/11/2008 12:51 AM >
Hide Signatures
       Post #: 386
RE: Nitromodels PREDATOR RQ-1B - 1/11/2008 12:58 AM
papajeff
Score: 100
Status: offline
quote:
ORIGINAL: junkjet
Good move, Freddy, and you're right as I could not see it on the video.
Hide Signatures
       Post #: 387
RE: Nitromodels PREDATOR RQ-1B - 1/11/2008 1:18 AM
papajeff
Score: 100
Status: offline
imwebbo,
Thank you for both links! I really liked that almost real UAV, silver Predator. I did see one of the UAV
sites that had photos of the many variations and we'll just remane this thread the new and improved
MQ - 9 Reaper. I like it!!!!!!!!!!!! Ohhhhhhhhhhhhhhhh.................Yeahhhhhhhhhhhhhhhh!!!!!!
Thank you for your comments which are greatly appreciated! I thought the same about the Predator's
63" wing span and decided to figure out a way to make the wings removeable. You can go to post
#116 then Ryan's idea see post # 294 & the next few to # 303. Now, I think that Ryan's mod is the best.
Hide Signatures
       Post #: 388
RE: Nitromodels PREDATOR RQ-1B - 1/11/2008 1:20 AM
papajeff
Score: 100
Status: offline
quote:
ORIGINAL: Warbird-Dave
Dave,
I wish that I had such talented pals. Nice custom pilot! Hey, happy New Year and remember;
'08 is going to be GREAT!!!!!!
Hide Signatures
       Post #: 389
RE: Nitromodels PREDATOR RQ-1B - 1/11/2008 1:48 AM
brownlab
Score: 100
Status: offline
Ch1. Throttle
Ch2. Rudder
Ch3. Elevator
Ch4. Ailerons
it doesnt have rudder, it has a nosewheel that is connected to the elevons, and it has elevons
ch1 throttle
ch2 ailerons
+ mixed=elevons THAT IS THE WHITE PREDATOR
ch3 elevator
Hide Signatures
       Post #: 390
RE: Nitromodels PREDATOR RQ-1B - 1/11/2008 8:41 PM
georgee
Score: 105
Last Login: 5/12/2013
Status: offline
Hi Papajeff,
My Predator is ready for the 1st mission.Its a nice looking ****,so I"m very exciting how its gonna fly.Thx for the building tips.
Georgee
I"m tired of airplanes.I just want one more.
Hide Signatures
       Post #: 391
RE: Nitromodels PREDATOR RQ-1B - 1/12/2008 5:26 AM
papajeff
Score: 100
Status: offline
quote:
ORIGINAL: georgee
Hi Papajeff,
Georgee
Be sure to let us know how it goes. Also, post some photos if possible.
Hide Signatures
(in reply to georgee)
       Post #: 392
RE: Nitromodels PREDATOR RQ-1B - 1/12/2008 8:28 AM
Pappy-86
Score: 100
Status: offline
Hello guys need some help. I'm fortunate to work for a company that give out to its employees a $250.00 American Express card for Perfect attendance for a year which I did last year. Now my question is I always need just 1 more War Bird but having a problem finding one. Looking for one that can be EP powered with nothing bigger then a .25 and with a wing spawn of 42 - 48 inches. And I want to stay in the 3 cell lipo battery range. Wanting a War Bird I don't already have is the problem here is what I alredy have
1. Corsair x 3
2. P-47 x3
3. P-40
4. A-26
5. P-38
6. P-51 x 2
7. ME 109
8. FW 190
9. Stuka
10. A6M Zero x2
11. Predator
12. U2
13. AT6
14. T-28
15. Cub
16. Bird Dog
17. Spitfire x 2
Looking for ARF or kit I would like to find a F4F , F6F , F8F or a Dauntless SBD but what I have found are either to big or to small. If any one knows of one of these planes or any other War Bird not listed in the 42-48 WS area please let me know. O and I'm only looking for prop driven plane.
Thanks for any help
Dave
< Message edited by Warbird-Dave -- 1/12/2008 8:40 AM >
Hide Signatures
       Post #: 393
RE: Nitromodels PREDATOR RQ-1B - 1/13/2008 1:41 AM
brownlab
Score: 100
Status: offline
try nitromodels or raidentech they have some nice warbirds that can be gas or electric, maybe hobby-lobby.com all they have is electric, make sure you put the hyphen in the middle or it will send you to the other hobby lobby
Hide Signatures
       Post #: 394
RE: Nitromodels PREDATOR RQ-1B - 1/14/2008 5:29 AM
junkjet
Score: 100
Status: offline
1. Corsair x 3
2. P-47 x3
3. P-40
4. A-26
5. P-38
6. P-51 x 2
7. ME 109
8. FW 190
9. Stuka
10. A6M Zero x2
11. Predator
12. U2
13. AT6
14. T-28
15. Cub
16. Bird Dog
17. Spitfire x 2
Thanks for any help
Dave
Hi, Dave. Here is one of my next brushless projects and would be a great addition to your collection also
http://www.estarmodels.com/
Click for fullsize
< Message edited by junkjet -- 1/14/2008 5:30 AM >
AMA427952
Freddy Schneider
Hide Signatures
       Post #: 395
RE: Nitromodels PREDATOR RQ-1B - 1/14/2008 12:10 PM
Pappy-86
Score: 100
Status: offline
I really like that plane thanks much for the tip. Have you put any of there kits togeather? if so what do you think of them?
Dave
Hide Signatures
       Post #: 396
RE: Nitromodels PREDATOR RQ-1B - 1/14/2008 12:35 PM
chrishornby
Score: 100
Last Login: 12/29/2010
Status: offline
Those kits look nice, I really love Broncos, I already got 2!
What comes down must always go up!
Hide Signatures
       Post #: 397
RE: Nitromodels PREDATOR RQ-1B - 1/22/2008 1:47 AM
papajeff
Score: 100
Status: offline
Junket,
E-Star kits sure look fine and the Storch is a good example! Great suggestion for Dave's next Warbird!
Hide Signatures
       Post #: 398
RE: Nitromodels PREDATOR RQ-1B - 1/22/2008 1:52 AM
papajeff
Score: 100
Status: offline
quote:
ORIGINAL: chrishornby
Hey, Chris, how have you been? I just might have found a real interesting UAV for us Predator nut-cases. I have a little more checking to do and I will be sure to let you know the result. We just could end up with a number of unusual UAV's to do some air-recon whenever we want.
All we have to be careful about is to make sure that we do not fly them too close to any airport, right???????????????
Hide Signatures
       Post #: 399
RE: Nitromodels PREDATOR RQ-1B - 1/22/2008 12:41 PM
chrishornby
Score: 100
Status: offline
Hi Jeff, I look forward to seeing your new UAV idea. The weather is awful here right now, floods all over the country so no flying, but I will be taking a couple of planes to South Africa with me in February so looking forward to some aerial photography. I have got me a couple of gyros to put on the elev and ailerons of my predator to stabilise it for camera shots. Even more like the real thing then? Nice to hear from you. I guess it is sunny and warm down in Texas?
Chris
Hide Signatures
       Post #: 400
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.641RCU1
