RE: Nitromodels PREDATOR RQ-1B    Gallery
Logged in as Guest
    Search This Thread
Printable Version
ParkZone F-27Q Stryker - RTF
Seller:  nrthwing
Details:   $150.00   |  6/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> Electric Aerobatic & Sport Planes >> RE: Nitromodels PREDATOR RQ-1B
Page: <<   < prev  30 31 32 33 34 35 36 37 [38] 39   next >   >>
Login
RE: Nitromodels PREDATOR RQ-1B - 9/10/2010 3:29 PM
Ferenium523
Score: 100
Last Login: 4/27/2011
Status: offline
I dont think it does. Each one has one big hole and one small hole and you plug them together big to small?
Hide Signatures
(in reply to lejongleur)
       Post #: 926
RE: Nitromodels PREDATOR RQ-1B - 10/3/2010 2:36 AM
Ferenium523
Score: 100
Status: offline
Sorry! I just realized I've been calling you Papa John the whole time. Papa Jeff, 1 more question, for the predator, the two servos that control pitch. When I plug them in both to one channel using a y connector, they go opposite ways, any way I could program them or do something to make them go in the same direction when I move the stick up or down?
Hide Signatures
       Post #: 927
RE: Nitromodels PREDATOR RQ-1B - 10/3/2010 2:37 AM
Ferenium523
Score: 100
Status: offline
Hide Signatures
       Post #: 928
RE: Nitromodels PREDATOR RQ-1B - 10/3/2010 2:39 AM
Ferenium523
Score: 100
Status: offline
Hide Signatures
       Post #: 929
RE: Nitromodels PREDATOR RQ-1B - 10/3/2010 4:42 PM
Ferenium523
Score: 100
Status: offline
Hide Signatures
(in reply to papajeff)
       Post #: 930
RE: Nitromodels PREDATOR RQ-1B - 11/6/2010 5:31 AM
WordyBirdy
Score: 100
Last Login: 12/14/2010
Status: offline
Papa Jeff,
This thread is probably the longest reaching at 38 pages+ and years and years long. Thank you for your tutorage. I hope you will continue to share your expert in the UAV planes (pred. reap.), as a great favor to us all.
Now, I have a few questions regarding Tx Rx configuration. Simple questions that tech support at nitro-planes couldn't answer, correctly.
Hope you will be ofhelp?
Hide Signatures
(in reply to Ferenium523)
       Post #: 931
RE: Nitromodels PREDATOR RQ-1B - 11/6/2010 7:45 AM
lejongleur
Score: 100
Last Login: 3/18/2013
Status: offline
Wordy - What do you need to know?
Hide Signatures
(in reply to WordyBirdy)
       Post #: 932
RE: Nitromodels PREDATOR RQ-1B - 11/6/2010 3:20 PM
WordyBirdy
Score: 100
Status: offline
lejongleur,
I have the predator fully assembled and ready to fly. I did not re-disign the front landing gear, nor add another servo and make a rudder out of the back stab...so I am at the mercy of mother nature during take off.
Typically (as been the case for most of my puller-planes during take off) trimming the rudder a click or two leads to a very straight runway path.
The problem I am facing is correctable, as the v-wing elevators are functioning on two different servo's. With a Y-harness, I place both servo leads into channel 2. But I can't seem to figure out how to mix channel 2 with channel 1 in my Ct6 Rx. I have experimented with nearly every concievable solution (both in electronics, and Ct-6 program software) but remain mystified...
Hide Signatures
       Post #: 933
RE: Nitromodels PREDATOR RQ-1B - 11/6/2010 4:11 PM
papajeff
Score: 100
Last Login: 3/14/2013
Status: offline
quote:
ORIGINAL: Ferenium523
No need to be sorry.........you got the PAPA part and that's all that's necessary!   When this happens,
you need to get a "reversing Y connector" and your problem will be solved.
Hide Signatures
       Post #: 934
RE: Nitromodels PREDATOR RQ-1B - 11/6/2010 4:22 PM
papajeff
Score: 100
Status: offline
WORDY,
Since I use a DX7 (Spektrum 2.4), I am not  familiar with your radio.  However, let me check my setup
and I think that between Lejongleur and me, we can get you going in the right direction.
Hide Signatures
       Post #: 935
RE: Nitromodels PREDATOR RQ-1B - 11/6/2010 4:40 PM
WordyBirdy
Score: 100
Status: offline
I am thankful for any help regarding the radio, servo mixing obsticle...I found two very informative posts (video & written) that allowed me to access and program the Rx and Tx - binding both. However, neither included info regarding channel mixing on a v-wing tail. My Tx is programmed at the basic 4 channel ACRO, with mixing potential.
Regards
Hide Signatures
       Post #: 936
RE: Nitromodels PREDATOR RQ-1B - 11/6/2010 4:58 PM
papajeff
Score: 100
Status: offline
Wordy,
My DX7 has a setup screen for "WING TYPE" and a several choices which include V-tail.  When this
choice is activated, my V-tail operates properly.  Does your radio have this option?
Look at what I just found and tell me if this helps at all with setting up your Tx for V-tail.
http://www.mycoolheli.com/t6config.html
< Message edited by papajeff -- 11/6/2010 6:02 PM >
Hide Signatures
       Post #: 937
RE: Nitromodels PREDATOR RQ-1B - 11/6/2010 9:44 PM
lejongleur
Score: 100
Status: offline
Wordy - If I read your prior post correctly, you are joining the vatail servos with a y-connector, right? If that is that case, you will not be able to use any rudder function, as they will both move in the same direction all the time (if they move in the opposite directions, perhaps you can use the opposite servo horn on one of them, or use a special Y-connector as Papa J suggested.
If you only have 4 channels, and can program for a V-Tail, I suggest you use the Y-connector on the ailerons, and use a separate channel for each of the two vtail control surfaces (one rudder, one elevator.) If you find that the tail does not perform as expected, switch the rudder and elevator connections.
Optimally, if you can program for VTail (built-into your radio), and have 5+ channels, here's the configuratrion for a Spektrum setup:
Right wing - Aileron
Left Wing - Aux1
Vtail1 - Rudder
Vtail2 - Elevator
Vtail1 & 2 may need to be swapped. When you pull back on the elevator, both Vtails go up. Rudder left - left Vtail goes up, right Vtail goes down. Rudder right - vice versa.
Potential bad news - If your radio is the CT6 equivalent from Hobbycity:
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=8338
If specifically states that is is unsuitable for mixing or vtail. In that case you are definitely limited to coupling the two vtails together (as elevator only), and using the ailerons to turn the plane. Perhaps you already knew all this!
Hope some of this may help...Chris
Hide Signatures
       Post #: 938
RE: Nitromodels PREDATOR RQ-1B - 11/8/2010 5:04 AM
MotherPlaneRC
Score: 100
Last Login: 1/17/2011
Status: offline
Hey guys, I'm doing some build videos on the predator with a little help from this thread. Check it out and give some suggestion etc.
http://www.youtube.com/watch?v=Z3_CUto3v3g
http://www.youtube.com/watch?v=g-3hT_d3zz8
Thanks.
Hide Signatures
       Post #: 939
RE: Nitromodels PREDATOR RQ-1B - 11/9/2010 8:51 PM
MotherPlaneRC
Score: 100
Status: offline
How well do these things glide if at all and what is the longest flight time you have gotten out of these uav's?
Thanks, Ace.
Hide Signatures
       Post #: 940
RE: Nitromodels PREDATOR RQ-1B - 11/10/2010 2:32 AM
WordyBirdy
Score: 100
Status: offline
Papa Jeff, I watched that video link several times, and checked into the written manual. I finally figured it out. I now have the servos opporating as designed.
Hide Signatures
       Post #: 941
RE: Nitromodels PREDATOR RQ-1B - 11/10/2010 2:57 AM
WordyBirdy
Score: 100
Status: offline
lejonguer. Thanks, I finally got the correct program and my tx/rx is working fine. However, the predator weighs alot more than the 1.75 lb recommended fly weight. I had to continue adding lead weight to the nose (about 6 oz ) to get the CG right.
I then jumped on a bicyle (holding the plane at the CG) and took off peddling to nearly 20 miles an hour before the wings began to generate enough lift to counter the planes weight.
So I put the bike away, found an abandoned parking lot and taxied off, but the darn plane wouldn't stay straight long enough to gain flight speed. Even with rudder working, I guess I need to put in a working front steering gear. I was very tempted to just toss the plane (as I have done with a many motored glider) but having that prop in the back raises a more cautious approach. I will work on the nose gear.
Hide Signatures
       Post #: 942
RE: Nitromodels PREDATOR RQ-1B - 11/10/2010 3:36 AM
lejongleur
Score: 100
Status: offline
Wordy - My Predator comes in at 32 ounces - almost 40 ounces with the two batteries I use in it. I am using a 1000mah 3S and a 1300mah 3S (in parallel) to get the cg right, with no added weight. I would say that takeoff speed is less than 10mph. When you were testing using a bike, it was probably not possible for you to assess the angle of attack that the airplane was at, was it?
Mine has a small outrunner generating around 220 watts with a 8.5x6 or 9x6 counter rotating prop. This gives it an easy takeoff in about 10-15 feet and lets it climb very steeply. the ESC is in the tail with an extension to the batteries right up front. I am using a Spektrum AR7000 receiver, and Hobbycity HXT900 servos. No separate BEC is needed as I am only running 3S.
My only problem with this plane is that it is so hard to tell what it is doing in the air - it looks freakish from most angles, and I keep thinking its rolling one way when its actually doing the opposite. Painting it yellow would help, but how many Predators are out there intended to be visible? It would probably fly for close to 20 minutes, as it seems to use about 100mah/minute.
By the way, I did not bother to put on a steerable nosewheel, although that would be helpful. I fly at a club which has a min airport with two blacktop runways, wide enough even for my limited skills to line up and put the Predator down once per flight. NO touch and go practice, though.
Hope this helps...Chris
Hide Signatures
       Post #: 943
RE: Nitromodels PREDATOR RQ-1B - 11/10/2010 9:42 PM
papajeff
Score: 100
Status: offline
Wordy,
My Predator flies just the same way as Chris has explained in his post.  Since I fly off grass fields,
I really have not had the need for any nose wheel steering as the plane just rotates in about 30 -
50 feet with no problems.  I also needed some extra weight in the nose.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 944
RE: Nitromodels PREDATOR RQ-1B - 11/11/2010 5:04 AM
WordyBirdy
Score: 100
Status: offline
lejongleur, Thanks for the feedback. I agree that the bicycle method was not truly reliant, but I also manuevered the predator as I peddled to create a best case scenerio. I believe the 20 mph (maybe I had a tail-wind; I failed to check at the time)  was about what it would take to off-set the weight. SO, after reading your and Papa Jeff's reply, I gutted out the 500 motor, 50a esc, and replaced it with a 400 rimfire, and a 25a esc. That certainly lightened the rear, and hopefully I wont have to add any weight to the front nose to get correct CG.
Explaining to me the liftoff and flight characteristics of your predator eases my concern. I have heard too many horror stories regarding this model plane.
Wordy
Hide Signatures
       Post #: 945
RE: Nitromodels PREDATOR RQ-1B - 11/11/2010 5:08 AM
WordyBirdy
Score: 100
Status: offline
Papa Jeff, I decided not to go with a steerable front gear. I think I'll go on grass too. I thank you for the input. I plan on flying this plane tomorrow...now that I have lightened the load.
Hide Signatures
       Post #: 946
RE: Nitromodels PREDATOR RQ-1B - 7/12/2011 9:30 PM
dditch
Score: 270
Last Login: 6/14/2013
Status: offline
Nice detail on the thread PapaJeff!
Hide Signatures
(in reply to Charan)
       Post #: 947
RE: Nitromodels PREDATOR RQ-1B - 7/19/2011 1:07 PM
orbjeff
Score: 100
Last Login: 7/20/2011
Status: offline
Hi there,
Thanks for the great post. It has been very helpful!
Jeff
< Message edited by orbjeff -- 7/20/2011 4:40 AM >
Hide Signatures
       Post #: 948
RE: Nitromodels PREDATOR RQ-1B - 7/20/2011 2:25 AM
alanwf
Score: 100
Last Login: 2/18/2013
Status: offline
I recently picked up this plane, but the carbon wing tube is missing. Can someone give me the specs on the tube so I can order one? I need the diameter and length, and perhaps the wall thickness. Thanks in advance.
Hide Signatures
(in reply to orbjeff)
       Post #: 949
RE: Nitromodels PREDATOR RQ-1B - 9/27/2011 6:05 PM
jeskimo5
Score: 100
Last Login: 11/2/2011
Status: offline
 Hello everyone,
I am building RQ-1 as my first 'big' R/C aircraft ( I know, I know,  not a trainer... I'll deal with it) So I just want to run my list of components past the experts to see if they are good enough:
 I am going to use a Spectrum DX6i controller How does that look?
Hide Signatures
(in reply to alanwf)
       Post #: 950
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.000RCU1
